Page 1 of 11 1234 ... LastLast
Results 1 to 25 of 260
Thread: ABIT NF7/S Rev2.0 Modded Bios : D26 Black Mantaray
    Fused
    Dec 2003
    Malaysia
    Cool ABIT NF7/S Rev2.0: Where MantaRays Bios Species Live
    D26 BLACK-MANTARAY
    Features:
    - Base on D26 bios structure
    - Changed the Disable and Enabled CPU Interface Table 133, 166 & 200 MHz FSB: (ABIT Stock ROMSIP Tweak by tictac)
    - DISABLE CPU Interface : Unchanged
    - ENABLED CPU Interface : Fix Unstable Timing in D26 SplitFire with 3D Application
    - Vcore Revised same as D23 3D Fire R1 & R2
    - New Small ABIT Logo at Boot Up
    - 3D Fire Ingredients : Included
    - Bios Layout : Stock ABIT Bios
    - CPU Disconnect Function Patch as Recomended by nVidia Tech
    - Side Band Addressing : Enable by Default ( Depends on VGA Driver. It might overwrite the setting to Disable)
    - Dimm Driving Stregth & Slew Rate : Stock ABIT Configuration
    - Alpha Memory Timing : Stock ABIT Configuration
    - Unknown Processor -> Renamed to AMD XP Mobile for Athlon Mobile User
    - New Full Screen Logo on BootUp( Press Tab to show POST screen , Press Delete to enter Bios)
    - Improve 3DMark2001SE & 3D Application stability at high FSB
    - SATA Bios Version 4247
    a)Command Per Clock Enabled
    http://forum.abit-usa.com/attachment...&postid=417785
    http://www.geocities.com/nastechxtre...ckMantaray.zip
    http://home.doramail.com/tictac/D26-BlackMantaray.zip
    b)Command Per Clock Disabled
    http://forum.abit-usa.com/attachment...&postid=417786
    http://www.geocities.com/nastechxtre...ntaray-CPC.zip
    http://home.doramail.com/tictac/D26-...ntaray-CPC.zip
    :thumb:
    D26 BLACK-MANTARAY L12
    Features:
    - Fix Unmodded Athlon Mobile & Tbred 133MHz FSB CPU Interface to 166MHz Interface
    http://forum.abit-usa.com/attachment...&postid=418788
    http://www.geocities.com/nastechxtre...ntaray-L12.zip
    http://home.doramail.com/tictac/D26-...ntaray-L12.zip
    http://forum.abit-usa.com/attachment...&postid=418798
    http://www.geocities.com/nastechxtre...ay-L12-CPC.zip
    http://home.doramail.com/tictac/D26-...ay-L12-CPC.zip
    D10 MANTA RAYS XT
    Features:
    - Base On Abit Stock D10 bios
    - CPU Disconnect function patch as recomended by nVidia Tech
    - EXT P2P Discard time set 1ms by default (to prevent SATA corruption)
    - SBA Enabled by default(VGA Driver might overwrite the setting)
    - New small ABIT logo
    - New Full Screen boot up logo (Manta Rays XT Logo by HouseRats @ OcForums.com)
    - L12 Softmod for Tbred & Mobile to run on 166MHz Interface
    - Beta 4x4 Ingredients : Included
    - Command Per Clock : Enabled (ABIT D10 Stock BPL)
    - Dimm Driving Strength & slew Rate : ABIT Stock D10 Configuration
    - Alpha Timing : ABIT Stock D10 Configuration
    - CPU Interface Enable & Disable : ABIT Stock D10 Configuration
    - Bios Layout : ABIT Stock D10 Configuration
    - SATA Bios Version : 4247
    http://forum.abit-usa.com/attachment...&postid=420399
    http://www.geocities.com/nastechxtre...ntaRays-XT.zip
    http://home.doramail.com/tictac/D10-MantaRays-XT.zip
    http://www.sparks.speedlinq.nl/files...ntarays-xt.zip
    http://forum.abit-usa.com/attachment...&postid=426571
    http://www.geocities.com/nastechxtre...ayS-XT-CPC.zip
    http://www.sparks.speedlinq.nl/files...ays-xt-cpc.zip
    D26 MANTA RAYS XT
    Features:
    - CPU Interface Table 166 & 200 MHz FSB: (ABIT Stock ROMSIP)
    - ENABLED CPU Interface : Improved 3D Handling & Bandwith Efficiency multiplier lower than 10
    Bandwith Peak @ Multiplier 10.5
    - Vcore same as D23 3D Fire R1 & R2
    - Bios Layout : Manta Rays XT Edition
    - AMD XP Mobile -> Renamed to AMD Athlon XP-M for Athlon Mobile User
    - New Full Screen Logo on BootUp by HouseRat@OcForums.com( Press Tab to show POST screen , Press Delete to enter Bios)
    - Soft L12 for Unmodded Tbred & Mobile
    http://forum.abit-usa.com/attachment...&postid=421118
    http://home.doramail.com/tictac/D26-MantaRays-XT.zip
    http://forum.abit-usa.com/attachment...&postid=421121
    http://www.geocities.com/nastechxtre...ays-XT-CPC.zip
    http://home.doramail.com/tictac/D26-...ays-XT-CPC.zip
    Credit to:
    - Rabbi : Beta testing on Micron 5B Chips (2 x 512MB = Max 254Mhz 2.5-2-2-11 multiplier 10.5)
    - Uwackme : Beta Testing on KVR PC2100 , Winbond CH5 , BH5
    - HouseRats @ OcForums.com : D10 Manta Rays XT splash screen
    - Sparks : Hosting bios files
    Dec 2003
    Sweet, i'll try these right after I reformat.
    Jan 2003
    Sweden
    Tictac i have a problem i have a dead nf7-s bios(i can not hotflash =error), And i have a winbond bios chip from a dfi lp but i have a problem. I get a error some thing like this(this bios don´t support flash lock) when i´m trying to flash a nf7-s bios to the winbond chip. Do you know any fix for it
    ?remove flash lock in bios or something.
    Banned
    Oct 2003
    Canada, eh?
    @LV - I believe that using awdflash with /tiny switch removes the lock. It did for me.
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by Lastviking
    Lastviking.... i dont have winbond bios chip... all my backup bios chip(3 chips) is PMC bios chip ... no problem flashing it with Abit flashmenu V1.30
    havent done any hot swapping yet... 1 of chip just corrupted.. after 20+ flashing... will do it if another chip die... :banana4:
    Jan 2003
    Sweden
    Quote Originally Posted by tictac
    Any link to flashmeny or awdflash?do it work to hotflash with awdflash and flashmeny?.
    Fused
    Dec 2003
    Malaysia
    what awdflash version u are using then? they said 8.24F version do better job in hot swapping give that a try....
    Aug 2004
    Firstly Hello XS. I've been regged and lurking for sometime now. My first poast is a lil Fanx to Tictac for some excellent modded BIOS. A buddy pointed me to your work some 4 months ago when I got my NF7s and XP-M. I have used the D23 subzeros and the 3Dfires with OK results. lastnite I flashed to the first set(I have a hard modded L12 for 166 default). I'm now running a 220x11 and they are more than 3D stable, Prime and SuperPI also. Fanx again for your great work Tictac. I hope you start doing DFI bios when I go for the LanpartyUT/3400+A64-M.
    DFI Lanparty UT
    A64 3400+dtr (CG) stock speed for now
    watercooled DD RBX acc nozzle #5
    PNY GF6800GT @ 405/1.1
    stock cooling
    1024 Corsair pc3200LL
    Fused
    Dec 2003
    Malaysia
    Thumbs down
    Tested By Rabbi
    2 x 512MB = 1giga
    Micron 5B Chips
    254Mhz 2.5-2-2-11 CPC ON
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    Nice results!
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    Apr 2004
    Sweden
    First of all: TicTac, thnx for all the great bioses you've done over the ages, if I can use that kind of expression And thnx for still supplying them to us that still uses the "old" 32bit cpu's
    Second : What kind of geforce 2 are you running on? :P Mine is an Asus Ti.
    Going to try the new bios this week I think.
    Happy OC to everyone!
    AMD Turion MT34 @ 250*9=2250MHz 24/7
    ATI X800PRO
    MSI K8NM FISR BIOS Rev 1.5 My first BIOS modification
    2x80GB Maxtor drives @ RAID-0
    1x160GB Seagate
    Everything in a mATX case.
    Jun 2002
    Earth/France/Corrèze
    tictac, your latest bios rocks for me
    learn A.K.A JP
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by LorD_Kvadd
    mine is GeForce2 MX 200 32Mb ....
    Prolink version if i still remember
    Max overclock... hehehe
    GPU : 200Mhz
    MEM : 376MHz
    3D Mark 2001 : 1971
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by Learn
    nice :thumbsup:
    Fused
    Dec 2003
    Malaysia
    Some result from my friend on my modded bios
    Techno fanatics rig
    Bios : D10 Manta Rays XT
    Mem: 2 x 256MB Hynix BT-D43
    Timing : 2.5-3-4-11
    Stability : 3 hours prime
    Proc: tbred b l12
    FSB : 250Mhz
    Sep 2003
    Question:
    Using one of merlin's bioses, i was able to get into windows at 240mhz. However, there was no 3d stability at all. Do you think this bios would help out there? It posts at 246, but is only windows stable up to about 227.
    Right now i'm using the modbios3(for the 227mhz stable), is the mantaray xt a better tweaked bios?
    Q6700 | P5W DH | 2GB Corsair XMS DDR2-800 4-4-4-12 | 512 MB X1900XT | WinXP Home
    May 2004
    Minneapolis
    tictac, recommend a bios for me, I want over 265
    edit- tried the D26 XT version... same results as merlins bios. must be the board holding it back at this point. to compare - http://www.finaldrivemagazine.com/andy/biostesting/
    Dual 1.6 Xeons @ 3.3ghz | Asus PC-DL | 9800pro | watercooled
    Mobile 2600+ IQYHA: 0351MPMW | Abit NF7-S | 2x256 Mushkin BH6 | 9800 Pro | retired
    3DMark01: 24413 3DMark03: 7993 Aquamark3: 56521 SuperPi 1M: 34s PiFast: 49.16s[/SIZE]
  18. #18
    Nov 2002
    SoCal
    I'm using the D26 BLACK-MANTARAY L12. I wanted a recent BIOS that was same/better than the stock D16; lost OC stability with the stock D24 and D26 BIOS. Thanks for the great work Tictac.
    Unmodded NF7-S v2.0, 2x512 Corsair and Kingston BH-5, 1700+ Tbred-B JIUHB, 11x218, 2-2-2-6, DC, CPU Interface Enabled.
  19. #19
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by FDM
    nice fsb m8... :thumbsup:
    over 265.... ehehehe... later i think... if god send me the abilities to do so...
  20. #20
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by scottk
    D26 Manta Rays Xt is improve version of D26 black mantaray l12
  21. #21
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by speedyaxon
    Question:
    i dont know how it perform compare to any other bios... but xt work better than black mantaray & black mantaray l12
  22. #22
    Xtreme 3DTeam Member
    Aug 2003
    Germany
    @ TicTac
    Had ur friends NF7 a Vdd Mod ?
    PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
    Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
    Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
  23. #23
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by GravdiggA
    @ TicTac
    no i dont think he did vdd mod.
    vdd depends on mobo itself.. some like higher voltage some even do well @ 1.5V
  24. #24
    Aug 2003
    Germany
    Ahh, Ok. I asked bcs of this Thread : http://www.xtremesystems.org/forums/...2&goto=newpost
    Maybe u can help me there too
  25. #25
    Jun 2002
    nice :thumbsup:
    damn good bios
    it's odd, testing the 5:3 ratio, it's 3dmark01 stable @ FSB280 DC.
    this bios increase my max fsb DC by 16mhz in windows 2000
    learn A.K.A JP
