Results 1 to 11 of 11
Thread: mc 371!
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Thumbs up mc 371!
    does anybody remember the old mc 371? an air cooled 80W tec from swiftech from the pentium3 days.
    there are still some of them floating around and they are dirt cheap now! i bought a new sealed one for 20$
    Xtreme X.I.P.
    Nov 2002
    Shipai
    great quality except for the thin tec wires! and it comes pre insulated and ready for plug n play
    Xtreme X.I.P.
    Nov 2002
    Shipai
    they even used arctic silver termal grease between the tec and the heatsink and ebtween the tec and the copper base!
    after 5 minutes:
    Xtreme X.I.P.
    Nov 2002
    Shipai
    after 10 minutes:
    Xtreme X.I.P.
    Nov 2002
    Shipai
    the lowest temp i reached with 23C room temp was -12C.
    not bad
    im sure it will do a good job cooling my nforce2 nb
    Xtreme Hardware Killer
    Jan 2004
    Behind you
    I like how until now you were talking to yourself in this thread
    Level 80 UD Death Knight on Murmur (Beta)
    Xtreme Mentor
    Nov 2003
    Nice find Saaya, wouldn't mind a couple of them myself..
    Banned
    Jun 2003
    Broomfield, CO
    NB cooler? Condensation might be a problem though...
    Xtreme X.I.P.
    Nov 2002
    Shipai
    naaaaaaahhh they are insulated already, very good work, all you need is some more neoprene for the back of the board and around the nb
    se if you can find them somewhere, they are usually dirt cheap!
    Xtreme Cruncher
    Dec 2002
    NW Ohio
    Nice find sayaa I'm surprised it got that cold. Begin air cooled 'n all.
    You going to get some pics of it mounted for us?
    Donate to XtremeSystems!
    Workstation: Intel Core i7 4770, Asus Maximus VI Gene, 32GB Corsair Dominator Platinum DDR3-1866, eVGA SC GTX Titan, 256GB Crucial M4, Corsair HX850, Corsair H100i. Corsair Carbide 350D
    Fileserver: 2x AMD Opteron 2425HE, Supermicro H8DME-2, 24GB DDR2-667, Supermicro 846TQ 24bay Chassis, Redundant 920w, 256 Crucial M4 boot, 20TB Storage
    Notebook Asus Zenbook UX32VD-DH71, Intel Core i7 3517u, 10GB DDR3-1600, 256GB Crucial M4, Geforce GT 620M
    Xtreme X.I.P.
    Nov 2002
    Shipai
    sure, put i think i will lap the nb first and before that ill mount the watercooling setup again and get the gpu and cpu watercooled and all, so it might take a while.
    about the mounting, i will just drill two holes into the base of the heatsink, shouldnt be a problem, ive dont it to several heatsinks already to make them fit on the gpu.
