Page 1 of 4 1234 LastLast
Results 1 to 25 of 83
Thread: MSI K8N NEO Plat Vdimm & Vdd Mods
    Xtreme Mentor
    May 2003
    Engineering Lab - NCSU
    A thread about the Vdimm mod for this board is already underway, but I thought posting both mods on a new thread would make things easier for members to get the info they needed without having to read the entire thread.
    The original thread can be found here.
    Now, the Vdimm mod can be done 1 of 2 ways. You can do the Vdimm = 3.3v Rail Mod, or you can do the method that allows adjustment via a VR.
    One odd note to make is that with the VR, the highest I could achieve was 2.936v. Keep in mind that I worked on this board without a cpu to test with. The stock Vdimm was 2.5v, so we are almost a solid 0.5v above stock without the ability to check other settings to see how the Vdimm responds. Once someone does this mod that has the ability to change the bios settings, we will know more. I dont know what the max Vdimm setting is in the bios, but I am wagering that this mod allows well over 3v once the cpu and ram are in the loop and bios settings are available.
    On to the pics:
    The preferred method, IMHO, allows the user to adjust the Vdimm to their preferrence. This involves cutting a trace on the back of the board and adding a resistance in this location to force the W83304D to supply more juice to our dimms.
    The following pic provides an overview of whats going on on the back of the board. The "may" be a way to do this on the front of the board, but I have to move onto other things, and pretty sure there is not a place on front to do this mod.
    Here are my wires quickly soldered in place for this pic:
    This next pic simply shows where I mounted the VR and the voltage reading points for Vdimm and Vtt. Note that Vtt track properly well past 3v as I tested it with the Vdimm = 3.3v Rail Mod and at a Vdimm of 3.35v, the Vtt was perfectly 1/2 of Vdimm.
    Now, here is the Vdd Mod as well:
    Cheers
    I like my women the way I like my processors...naked.
    I am not the HellFire that writes bios files. I work strictly on voltage modifications.
    Xtreme Mentor
    May 2003
    Another important note is that the Vdd FET will have increased voltage on both of its legs running into the pcb. I would recommend adding a sink to it just to be safe.
    Basically, the actual leg reading Vdd is 1/2 of the voltage of the top leg in the above pic. So, when approaching a Vdd over 1.8v or more, the top leg is reaching almost 4v.
    I also recommend adding active cooling the NB if you plan on more than 1.85v Vdd. Or atleast securing the sink with thermal epoxy so better contact is made.
    May 2004
    (If anyone has 2-Pin or 3-Pin fans that they can do without? I am in need. The fan doesnt have to work or even be useful at all. Basically I want the plugs.)
    I have plenty of these 2pin 3pin I will be sending. I also have a friend that is suppost to be able to get any fan cheap(works in apliance repair) he say he will get me 3 or 4 dozen of asorted fans for tuning his car, shouldnt be no prob to thro some your way if you need some fans to. I see your need in the connectors I also have a few dead power supplies you can salvage.
    Keep you some good pics of the board & when I get a CPU in it I will try to figure the LDT voltage mod(with your advice of course.
    I figured it was eating a lot of time & you need to get on with things.
    I finally got some bills payed today which will let me order some boards, if this one want do its thing now will just give MSI the boot.
    The board in your AV is it a Infinity, do you run the DFIs.
    DFI NF3-250 LanParty UT A64 3200 1m DTR @2550(10x255) - mushkin 222 -3dmark01 - 26424
    Shuttle SN85G4 V2 - A64 3200 1m @2525(10x252) - mushkin 222- 9800pro -3Dmark01 - 26379
    DFI Ultra B - 2600+ Mobile@2604(10.5x248) - mushkin 222 - 9800pro - 3Dmark01 - 21445
    Abit NF7 - 2600+Mobile@2520(10.5x240) - mushkin 222- 9800pro- 3Dmark01 - 21166.
    DFI P5BV3+ - K6-III+ 450@600(6x100)@2.4 vcore - Ati 8500 - 2x 4gb Quantan FireBall
    *DFI NF3-250GB UT Beta Bioses w/ 4.0vdimm and works w/ mobiles*
    *NF7 modded BIOS Vault*
    *If you have a DFI NFII MoBo read this
    Xtreme Mentor
    May 2003
    Hey man.
    Naw, thats the trusty ole NF7 doing 245 fsb.
    I would apprec any connectors you can send my way.
    I am almost positive that the Vdimm mod is correct, and the Vdd is certainly working properly.
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    hm what are those blue connector thingys u used
    also, if anyone has those 3 pin plugs with wires already stuck in em ill pay shipping for you to ship em to me, pleeeeease
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Xtreme Mentor
    May 2003
    The blue connectors are what I stick my multimeter plug into to check the voltages. Keeps me from causing a short circuit.
    May 2004
    Hum , no stability. I figured we would here from you after the testing yesterday
    Xtreme Hardware Killer
    Jan 2004
    Behind you
    Cutting a trace for vdimm? That mod is entirely too hard.
    Level 80 UD Death Knight on Murmur (Beta)
    May 2004
    If you have a better mod for it tell us.
    Xtreme Mentor
    May 2003
    There is a resistor in the Vdimm loop, but I couldnt register a change in Vdimm when working with it.
    I am going to take another quick look at it before shipping back to the owner.
    May 2004
    The question is how did it do when you tested it at the local shop.
    May 2004
    yep good question
    Newcastle 3200+ destroyed
    DFI Lanparty UT destroyed
    Geforce 6800 GT
    Adata Vitesta 4000
    Aug 2004
    Kind of a newbie on this. Would this mod work on a K8N Neo2 Platinum?
    May 2004
    The mod is not for sure yet, wait till it gets tested or if you wish test it your self.
    May 2004
    Bump
    May 2004
    Hell whats the word.
    Xtreme Mentor
    May 2003
    Guys, I have been pretty sick the last few days. I wont get into specifics, but it wasnt pretty.
    Doc was confused as to what it may have been, but after telling him that I spent a ton of time soldering, he sid it was most likely solder and flux fumes.
    I didnt have time, nor did I feel like, testing as I would have had to gone to a computer shop to do so since I dont have the cpu needed for this.
    I am shipping out tomorrow back to Jess and he will post his findings I am sure.
  18. #18
    c[_]
    Nov 2002
    Alberta, Canada
    Those fumes are bad for ya.. I have a small fan I use to create a negative air pressure opposite my head which pulls the air in that direction enough to keep it out of my face and not cool my iron or bug me...
    12v fan, 120v fan.. whatever you can find that will work is a good idea!
    All along the watchtower the watchmen watch the eternal return.
  19. #19
    May 2004
    Take care Dud,
    I have more & more of the 3 pin connectors gathering here,still digin. I will cut the harnesses off the died PSU(there older ones).
    When it gwts here I will throw them in the box you shiped me & send it back with all the connectors. Dont forget the return address or PM it back to me. I clear my mail out regulor so probably dont have the address still.
    I will post results back for everybody as soon as I get it back.
  20. #20
    Sep 2003
    hell fire i cant understand the 3.3rail mod....
    Should i simply connect those 2 points on the pic with a piece of wire???
    If i do what voltages will i get max???
    thanx
    Nforce3 K8nnxp Athlon64 3200+ @2.6GHZ 10x260 2-2-2-11 no mods) @ 8x290 2.5-3-3-6(no mods)
    Nforce2 A7N8X Barton 2500+ @2.4GHz 10x240 2-2-2-3
    Tbreadb 2400+ @2.5GHz 12.5x202 cas 2-2-2-3
    Pentium IT7Max2 2.26 @3.1GHz (air)
    1.6a @ 2.58GHz (air),samsung pc2700 @230fsb CAS 2.5 (3.0v)
    MSI KT266pro2RU 1600+ @2000+
    FIC KT133 TB 1GHz
    XFX 6800GT @ 430/1200
    2X 36GB WD Raptor 10,000rpm
    1x 120GB seagate 7200.7
    Hercules Rad9800pro @ 411/378
    19'' Sony G420 1280x1024 @ 100hz
    corsair 256mb pc3500 3.23V
    Leadtek ti4400 315/661
    LianLi pc-75
    COOLING: Prometia cooled
  21. #21
    Xtreme Mentor
    May 2003
    thanx
    Yes, connecting a wire between those 2 spots will make the Vdimm equal to whatever the 3.3v power rail is running. I would keep the wire as short as possible.
    The max voltage will depend on your power supplies 3.3v rail.
  22. #22
    Oct 2003
    Albuquerque,NM
    have you had a chance to verify that the 3.3 vdimm mod dont kill the mem controller yet as i seen that to be a similar factor in most of the deaths.
    DFI NF4 Ultra D/3800 x2 @ 2.5ghz/2x512 BH-5/ EVGA 7800 GT /OCZ 600W PowerStream
  23. #23
    May 2004
    I have beeen running 3.45 for a long time, I have seen others run more with no probs.
  24. #24
    Sep 2003
    Ok thanx for the reply....
    So what i can understand is just get any wire.... will the wire from the IDE cables do??? and connect the 2 spots and wola! the mod is done....
    Now dont u think 3.3 for a start is toomuch for the ram???
    I have had my corsair pc3500 BH-5 running @ 3.28v 24/7 but more i am a bit hastly.....
    So what if i want the ram only to run @ say 3.28v? will i have to lower my 3.3vrail to 3.28v???
    FIC KT133 TB 1GHz
    LianLi pc-75
  25. #25
    c[_]
    Nov 2002
    Alberta, Canada
    No, a wire from an IDE cable is not nearly thick enough...
    Yes, you will have to lower your +3.3 rail to lower your ram voltage. Your ram voltage will be equal to whatever your +3.3 rail is set to.
    Always use a DMM to measure!!
