So, most of you are builduing theyre own Systems. And the most time while building a Phase Change you spend on Brazing.
Ok this is going to be my Guide
Im using a A/O Torch System, as most of you know. You can see it in the Thread "Good bye MAP Torch":
http://www.xtremesystems.org/forums/...threadid=36325
The first part of the Guide is about the Setup.
Well ill start with the Bottles and the Pressure-reducing valves.
1. Oxigen-Bottle Valve (watch out! high pressure!), G3/4 connection
2. Acetylene-Bottle Valve Handle connection
3. Pressure-reducing valves, 1 Interstage, 2 Manometer
4. Flaming barriers, you dont need this but i recommend it
