Intel P4 3.2E
Asus P4C800 Deluxe modded
OCZ Powerstream 520W
Radeon X800 Pro
OCZ PC4200 5:4
Chilly1 cascade @ -95c
More to come...
Intel P4 3.2E
Radeon X800 Pro
OCZ PC4200 5:4
More to come...
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
Nice speeds man, 5ghz, feel the speeeed! Up until what is it benchable??
.:. X2 @ 2.9 .:. E6600 L628 @ 4.73 .:. AB9 @ 512 FSB .:. E6300 @ 100% OC Stable
U.K. overclockers: Represent your country, bench for EP-UK! Unite and show the world there IS a U.K. scene!
Moving up some
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
Why not a 2.8A?
For those of you about to post:
I need to get one, this is my 3.2e ES
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
Higher FSB = more performanceOriginally posted by craig588
Why not a 2.8A?
2.8A has stock 133 FSB which means that @ 5GHz it would only be running 238 FSB
Plus there is nothing wrong with a 3.2E engineering sample...
NICE ! cant wait to see some benchies at stable speeds, or is that stable ? oh dear god i hope not
ES = 14-21X multis avalivble.Originally posted by DaveX
wow can you do a 2001 and even 2003 run with 5GHz of prescott power? could easily be over 30k in 2001.......
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
I currently have the video card with stock HSF on it, I will bolt it up to the cascade. Im gonna shut down and thaw out for some serious 3D runs tonight and tomorrow.
I can bench around 4.9Ghz
My expansion valve is frozen at 27 PSI ~95c +- 1c, Ill start over and I should be around 15 psi @ -105c
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
14 ~ 16 multiples on this chip
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
congrats
someone needs a x800 xt
nice stuff...
There could be a few notable FIRSTS!!!
Noone has ever ran 3Dmark2001 @ 5gHz+ yet...
And noone has hit 30K on Pressie....
G/L FUGGER!
C
Not neccessarily true....Originally posted by DaveX
The 2.8A is the IDEAL supercooled processor.
21 x 245 = 5145@ 1:1 2-2-2-5 is VERY powerful, moreso than 300fsb @ 5:4...
C
That with a 6800U or X800XT
CPU : Intel Core 2 Extreme QX9650
MB : Asus P5E X38 Rampage bios
RAM : Team Xtreem 4x1GB DDR2 OPB handpicked
VGA : Sapphire 4870
Power : Antec Quattro 850w
Storage : 1 x 60GB OCZ Vertex + 2 x 750gb WD 32Mb
DVD : Samsungs DVDwriter Sata + Liteon DVD
Sound : Creative XFI Xtrememusic
Cooling : D-Tek Fusion + D-Tek Fusion GFX
Monitor : Samsung 226BW
Errorcode : An error occurred at address AC 20 DE AE FF BC ...... System halted.
Mobo is FSB limited @ 320, I dropped the multiple down to 14 and tried to break 320 FSB
The CPU wants to go higher...
I guess it is time to go get a 2.8e from Fry's (in stock D0)
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
wish I still had my 2.8A, I'd send it to ya'
C
Wow only 1.6V
yeah, they don't need/use the juice...Originally posted by jfr0
Wow only 1.6V
they do 90% of their OC within .10v of default. Even the 5.5gHz LN2 guys only fee them 1.72-1.77v
C
lol I am just used to bartons. I Give them suckers around 2v.
xxxxxxxtremely nice clocks..
ES has 14-16x multi's. And you didn't say ES...Originally posted by craig588
charlie, how would 245x21 running 1:1 be faster? 320x16 (memory 256MHz @ 2-2-2-5) has the advantage in FSB and memory speed, not to mention HT. Unless the 2.8A can clock significantly higher compared to the 3.2E ES.
