Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: [Denny]handpick QX6850 ES G0 power
    X.I.P
    Mar 2005
    Andre handpick some QX6850 ES G0for me
    P5K-D no mod can do up to 4.84G 1M with dryice
    P5WDH can do 4.73G 3Dmark06 passed with dryice
    Mar 2007
    Italy
    Quote Originally Posted by guess2098 View Post
    Impressive score with QX6850 under DI
    Apr 2006
    Cairo
    Come on Denny we want LN2 , we know that you are too busy but that chip worth it
    Xtreme Cruncher
    Jan 2007
    Stara Zagora,Bulgaria
    I think that if FSB:RAM is 1:1 it can go under 10sec...
    Greetings from Bulgaria
    Xtreme Guru
    May 2007
    Ace Deuce, Michigan
    I agree, if you set the memory to 1:1 and run it at something like 3-3-3-8 or so, then you could get under 10sec easily
    but you're going to need apply a lot of voltage for 3-3-3-8 at 440mhz
    Quote Originally Posted by Hans de Vries View Post
    JF-AMD posting: IPC increases!!!!!!! How many times did I tell you!!!
    terrace215 post: IPC decreases, The more I post the more it decreases.
    until (interrupt by Movieman)
    Regards, Hans
    Admin
    Dec 2003
    Hillsboro, OR
    Guys, Denny is a very experienced Pi bencher, and the asynchronous operation only helps the time. (it's already very efficient, and dropping to 1:1 no matter what the latencies would hurt it) Sub-10 isn't nearly as easy as it looks like at first glance. It takes around 5.1GHz with most hardware combinations. So far the lowest clock to achieve it was 5040MHz.
    Nice chip there Denny...you're making many of us jealous I'm sure.
    Xtreme Guru
    May 2007
    Ace Deuce, Michigan
    Yeah, many of us can only dream of ever getting a cpu worth $1400 or so, not to mention an es chip before everyone else
    What I'm wondering if using an e6850 instead on an x38 board would allow for under 10sec, as I read somewhere that the dual core counterparts surpass their quads at most benchmarks (plus it would be easier to clock a native chip instead of a dual die in theory)
    Regards, Hans
    Jan 2007
    Portugal
    very nice cpu, I want to see 5ghz with LN2
    G0 rules
    regards
    X.I.P
    Mar 2005
    Quote Originally Posted by AliG View Post
    i probably not going to use E6850 to run Super pi. since P35 over FSB499 doesn't do so well. that just my 2c
    Xtreme Guru
    May 2007
    Ace Deuce, Michigan
    Yeah, but I said x38 because aren't those supposed to have fully unlocked mults, or is that just the rumor that intel wants people to think?
    Regards, Hans
    Apr 2005
    Calgary, AB
    Nice one denny
    MB Reviewer for HWC
    Team OCX Bench Team
    Nov 2005
    sweden
    really nice
    SYSTEM: |QX9650 | DFI P35 / EVGA 780I | CRUCIAL 2*1GB | 9800GTX | SILVERSTONE 1KW |
    HOMEPAGE
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Denny: Any idea what that beast will run at on air for a 24/7 loaded situation?
    Yea, your reading my mind..
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    I think that will change once ClockGen is out for P35 Set 498FSB in BIOS and clock past it in windows to hold the strap?
    you sigged that?
    why?
    ______
    approaching aphelion
    Nov 2005
    Aix-en-Pce | France
    Nice one! Really impressive.
    Best Regards,
    Xavier
    "I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
    May 2006
    Serbia-Belgrade
    Nice man, to deam nice
    one question Can help 1.75V-1.8V to get 4.8-4.9GHz for 3DMarks, or this is to high voltage for quad and DI , because i will get one today? This GO steping is so criminal god !
    OC Jedi (on stand-by)
    Jan 2005
    Germany
    Nicce chip Denny!
    Quote Originally Posted by Movieman View Post
    My guess is 4Ghz on air with a relatively safe vcore.
    オタク
    "Perfection is a state you should always try to attain, yet one you can never reach." - me =)
  18. #18
    Feb 2007
    Thailand|ราชอาณาจักรไทย
    ้handpicked the ES chip. i wish i could
    nice result
    My E6300 2nd WR
  19. #19
    May 2006
    Philippines ^_^
    denny your so lucky..
    waiting for more of your results..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
  20. #20
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    hell this baby looks sweet - under LN2 this chip is a '06 beast
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
  21. #21
    X.I.P
    Mar 2005
    i wasn't able to run 3Dmark06 @ P35 motherboard over 4.6G but my 1st pretest on P5WDH can do 4.72G.
    i decided to re-run on P5WDG2 WS PRO...... the 1st two times i was able to run @ 4.8G+ ..... but later on not able to
    i am going to buy a dewar soon.....
  22. #22
    X.I.P
    Mar 2005
    3.9G for 24/7. 4G you need 1.52v and not sp2004 stable... also if runs it inside the case... not a good idea XD
    to other people
    thanks
  23. #23
    Xtreme Recruit
    Jan 2007
    Thats a crazy overclock.
  24. #24
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    lol, score on 975x is too low, this is results on asus striker.
    4793mhz=7108
    boot at 333*14=4.66G with ram=ddr2-667 5-4-4-9-2T loosen timings
    clkgen to 4793mhz, so ram about ddr2-710.
    intel chipset should be about at least 500score higher than this
    see this 320*14=4.8G ram=ddr2-853 3-3-3-8, cpu score=7610.
    if fsb and ramclk higher, 7700 so easy.
    so, maybe that's why ur chip are running higher clk on ws-pro than other mobo, 'coz not 4core full loaded, or maybe only 3cores enabled.
    4.9G should be about 7850 cpu score.
    Uni Hardware:
    http://www.unihw.com
    Team China
  25. #25
    Jan 2005
    belgium
    try Wprime
