Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Switching between thermal sensors in Brisbane core
    Aug 2003
    Exclamation Switching between thermal sensors in Brisbane core
    Hi, there!
    As we can see, a topic about the broken CPU temperature sensor in Brisbane core is extremely popular today. And I decided to pour some oil on the flames too.
    So, in short. Everybody knows that the AMD64 processor has an internal thermal sensor to measure a CPU die temperature. But according to the latest BKDG document the dual-core NPT processor family has the second thermal sensor in the CPU core. This means the dual-core AMD64 processor revision F and later has 4 thermal sensors - each core has a pair of thermal sensors. Unfortunately, we can’t find any software that could provide a selection for the thermal sensor. I created the simplest app that enables you to switch between two sensors of the CPU core. I want to believe that one from the sensors is really working. So, here is the link to CoreSensor.
    Good luck and thanks!
    Jun 2003
    just tested it , and reports only 2 sensors , sensor #0 , sensor#1 , same results with coretemp
    Aug 2003
    papatsonis, Please, read carefully! Each core of the dual-core CPU has two sensors. I mean Windsor and Brisbane.
    Aug 2005
    That's pretty cool. Now we can see exactly how calibrated the sensors are.
    .:: Gaming PC Specs ::.
    Case: Antec Nine Hundred
    CPU: Intel Core i7-2600K @ 4.6 GHz, 1.44v (cooled by Xigmatek GAIA) [IntelBurnTest{Linpack} stable]
    GPU/Monitor: VisionTek HD 6950 @ 6970, 950 MHz/1375 MHz 1.30v + Sony BRAVIA 32EX400 1080p
    Motherboard: GIGABYTE Z68XP-UD4 F5
    Memory: 16 GB (4x 4 GB) Corsair Vengeance LP DDR3 1600
    Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
    Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
    PSU: Corsair AX-1200 (1500W PSU!)
    O/S: Microsoft® Windows 7 Ultimate SP1 X64
    Jun 2003
    i messed around with the two sensors/core and only thing i observed was the temperatures from 0C/10-11C were reported reversely , 11C/0C , may try again later (not this pc..)
    Feb 2004
    it doesnt work with vista x64, message "Could not install system driver"
    Can you solve it?
    Jun 2003
    hmmm
    Fired it up on a new Windsor 5600+. Sensor 0 is fine on either core, sensor one comes up with a (-) number. The sensor 0 result matches coretemp.
    GA-MA790GP-D4SH, 965BE, 3.8Ghz
    Ultra120E, 4x2G Gskill 1066
    2x 150G VRaptor raid, WD640AALS
    8800GT 735/940/1685, LG-BluRay
    Xtreme Mentor
    Nov 2005
    Devon
    For my single core Lima (rev. G) it's working fine.
    Sensor '0' reports temps around 6.5-7.5C and sensor 1 reports temps around 7-8.5C. Looks like both sensors are broken.
    PS. Thanks for sharing this nice util VVJ!!
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Quote Originally Posted by PetNorth View Post
    Can you solve it?
    It's not as easy as you may think, Vista x64 requires the author to digitally sign their driver, which is rather expensive.
    There is a workaroung. Your can read about it here:
    http://www.alcpu.com/forums/viewtopic.php?t=211
    Member of Overclockers.com Folding @ Home team
    "<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
    Main rig:
    AMD Ryzen 7 2700X / Mobo: Asrock Fatal1ty X470 / EVO 970 500GB + WD Blue 250GB + HDD / GPU: Dell RX 570 4GB / Mem: 2x16GB DDR4-3200 G.Skill 32GTZKW TridentZ - 32GB total / PSU: Seasonic Prime Ultra Gold 650W
    Secondary rigs:
    Core i7 2600K 3.4GHz @ 4.3GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / 2x Inland Pro 120GB / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 8GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
    Core i3 540 3.06GHz @ 4.0GHz (Freezer 7 Pro) / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: Antec 380W.
    Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
    Apr 2007
    Interesting development. When I switch between core 1 sensors, it switches the reading in speedfan, also. At idle shows 8 c or 12 c. Core 0 sensor -5 c or 6 c.
    Feb 2004
    Quote Originally Posted by The Coolest View Post
    This is not the problem. I can install permanently unsigned drivers in my Vista x64, with this trick (it must be executed in command line with admin rights):
    C:\windows\system32\bcdedit -set loadoptions DDISABLE_INTEGRITY_CHECKS
    With this, you can ever install unsigned drivers in vista x64. It's not necessary the F8 each time you boot.
    The problem with VVJ driver is different. It's not a signed or unsigned issue. It simply refuses to install.
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    I just ran the app on my X2 3600+ Brisbane and got same reading with both sensors
    around 7-8C on core 1
    around 16-17C on core 2
    Main rig:
    Secondary rigs:
    Aug 2005
    I got identical readings with any sensor too.
    Dec 2003
    Blacksburg, VA
    Pretty much identical readings on my side as well.
    Gigabyte MA790X-UD4P//Dell Latitude D620
    Phenom II BE 940//Core 2 Duo 2.0Ghz
    2x2GB OCZ Reaper//1GB PC5400
    640GB WD Blue//80gb 7200 rpm hdd
    Radeon 4850//Geforce 7300 Go
    Aug 2003
    Quote Originally Posted by Lightman View Post
    Howdy!
    I’ve got the latest Revision Guide for AMD NPT Family 0Fh Processors from AMD, but I didn’t find any mention about broken thermal sensors in Revision DH-G1. I doubt that the sensors are “broken” as users suppose.
    Xtreme Mentor
    Nov 2005
    Devon
    Quote Originally Posted by VVJ View Post
    Howdy!
    Then we can say 'wrongly calibrated' because it is unusual to get around 7-9C inside CPU when ambient temperature is around 22C.
    You might be right saying they are not broken, because temperature readings are increasing under load about right amount... (another 5-7C)
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    I agree
    Main rig:
    Secondary rigs:
  18. #18
    Jul 2005
    London, UK
    Here is a quick comparison I made between CoreSensor and Speedfan (please see link). The programme seems to work as both it and Speedfan report the same kind of temperature rise from idle to load (about 20 degrees). However, the sensors within the chip seem to be broken as at idle CoreSensor gives a temperature in the mid to high teens with an ambient of around 21 degrees.
    I MSI P67A-GD65 I Intel i5 2500K I 8Gb Samsung I
    I Corsair F3 60Gb I AMD 6850 I Dell SP2208WFP I Windows 7 x64 I
    I Current Speed: 4.5Ghz I RAM 1866Mhz @ 9-9-9-27 1T I
    I Laptop I Acer 1830T I Intel i5-470UM I Crucial M225 I 4Gb DDR3 I
  19. #19
    Xtreme Mentor
    Sep 2005
    Netherlands
    got a x2 3600 wich is atm running at 2400mhz default voltage.
    speedfan says: 20 degrees
    AMD64CT says: 11.5 and 12 on sensor 0
    and Sensor 1 says 7 and 2 degrees
    i watercool my CPu but them 12 degrees are to low..
    Time flies like an arrow. Fruit flies like a banana.
    Groucho Marx
    i know my grammar sux so stop hitting me
  20. #20
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    Working on 939 opteron 165
    it is working on my Opty 165
    temps are not the same like what coretemp reports
    and it can detect 2 sensors for every core but the temps are the same
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
  21. #21
    Xtreme X.I.P.
    Apr 2005
    Thermal sensors aren't broken. It's just software that cannot read the data correctly.
    Now you can only monitor CPU temperature using existing apps like Sandra, Everest and SpeedFan. S&M scales very good but has wrong zero point.
  22. #22
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Quote Originally Posted by Cooper View Post
    Why can't the software read the sensors properly? Can you please elaborate? From what I saw programs like Sandra and Everest, etc. gave the same kind of readings as Core Temp and CoreSensor/NextSensor. Or are you reffering to the old fashioned way of reading CPU temperature using the motherboard diode?
    I'm getting the information like explained in the K8 BIOS designer's guide. We all use the same kind of method to read CPU temps.
    Quote Originally Posted by SaFrOuT View Post
    This thread is about the new Brisbane cores, they're the only CPUs which give weird readings. Other CPUs give correct readings in most of the cases.
    Main rig:
    Secondary rigs:
  23. #23
    Mar 2005
    Cairo, Egypt
    ah sorry didn't notice that
    Soon to be :
    Used to be: SaFrOuT
  24. #24
    May 2007
    Sweden
    Very interesting, should be great to find a way to read coretemp. Both sensors can't be broken.
    Ivy Bridge 3770K @ ????MHz
    6c Intel Xeon X7460 24MB cache 16GB RAM 22TB HDD fileserver
    Dual Intel Xeon E5620 workstation
    SB 2600K @ 5016MHz 1.37v HT on AIR primestable
    AMD Athlon X3 425 @ B25 4GHz+ AIR
    AMD Athlon X2 6400+ @ 3811MHz AIR
    AMD Athlon X2 3600+ @ 3200MHz AIR
    AMD Athlon XP 1700+ @ 2714MHz AIR
    Thermalright Ultra-120 Extreme
    Corsair 8GB XMS3 2000MHz
    ATI Radeon HD5850 @ 1000MHz+/1200MHz+
    Windows 7 Enterprise x64
    Corsair HX750W
  25. #25
    Banned
    May 2006
    Quote Originally Posted by roadie View Post
    The right temp there is 61º.
