Got my P5K today Can't build till 6/14 but I read the very uninformative manual.
=Project "Dark Side"=
^Clicky
Should i get this motherboard? My current motherboard can't overclock past 358mhz FSB...
I just bought myself a Tuniq Tower, so i was thinking of getting a new motherboard as well so i can overclock my e6300.
And is using the pencil mod safe?
It looks so easy to do, well it does in the thread about pencil modding posted a few hours ago...
Any precautions?
Also, how easy was the pencil mod for the vDroop?
anyone experiencing different readings for bios and everest under 12v after doing pencil vmod on the p5k vanilla?
do NOT trust software readings
use a DMM to find out exact voltages
Well, are you experiencing different readings?
Nice. After doing the pencil mod, I'm getting 1.320 in everest with 1.3375 set in bios coming from 1.40 in bios and 1.312 in everest. So it was a huge improvement.
Unable to do anything else at the moment, I just did 2-3 strokes over the mod point...
^Clicky
is this mobo works with OCZ SLI Edition PC8500 2gb kit ?
| i7 2600K | GA P67A-UD4 | Team Xtreem PC1600 DDR3 16Gb | DA GTX 570 | Team S1 120Gb SSD | Corsair 650W |
| X-Fi Xtreme Music | Altec Lansing CS21 | Dell U2711 | Samsung 32"A550 | Armor Silver with 25cm fan |
Old Celly L 430
E4300
E6300
Q6600
I'm getting my mobo tomorrow mate, will keep ya posted if they work with the OCZ 8500 SLI , I have the same as you... keep ya posted
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
are there any differences between the vanilla and deluxe as far as voltage options and clockability go?
Rebuilding
hey guys here is an update
ok so i got to the bottom of the pc4200 ram issue not booting
basiclly it needed spd to have at least pc5300
and now it runs pretty sweet
http://valid.x86-secret.com/show_oc?id=205422
ah 2.5GB!
yup
all 4xslots occupied
2x1GB corsairs
2x256MB microns
and still 600MHz no worries even 620MHz 1M
nice.. P5K is a nice series
2GB Super Talent T1000UB1G5 Micron D9GKX Singles
@625Mhz 5-5-4-9
CPU Validation
Super Pi v1.50
Single 32M
wPrime v1.43
I have been working with ASUS the past couple of days here in Taiwan. We should have a beta BIOS in a week or so that will open up memory strap changes on this board plus a couple of other surprises. Running DDR2-1333 at 5-5-6-18 with 2.4V at this time without an issue for one.
Ncix is having great sale on RAM .
http://www.ncix.com/products/index.p...o&promoid=1060
Buffalo Firestix FSX1000D2C-K2G 2GB 2X1GB PC2-8000 DDR2-1000 CL5-5-5 240PIN DIMM Dual Channel Memory $189 Regular $374 (canadian funds)
Yep works fine mine is orthossing now with a new batch CPU (30F and 44G) at 3200mhz (8 x400) and ram at 1000mhz ( intel divider ) 5-5-5-15 2T.
Ram worked fine for 4 hours of Orthos under stock FSB speeds (1066 5-5-5-15 2T 2.2 volts)...
Will see if I can get the same DDR800 speeds with 3-3-3-9 1T as on my Striker...
First let me say thanks to the OP for all the great info.
This really is a fantastic board and so far I'm getting 200mhz better OC than on my DS3 board, I'm up to 3150 @ 9x350 now but I think it can do better, esp with the voltages sorted out. So now that I've played with this a few days I think I see what the dreaded vdroop is. I can see in CPUZ my volts are about .04 lower than I set in BIOS and under load sometimes its as much as .1 lower. It definitely drops a lot under load.
So all I have to do is scratch the mod point in the picture above with a #2 pencil a few times and I'm good to go? Are there any precautions here?
BTW, is CPUZ as good as Everest for checking this? I don't have a DMM so I'll have to make due with software...
And also, while on the topic, what would you guys say is the max volt that I should safely set in the BIOS for an E4300?
Thanks in advance.
Oh yeah, and just in case anyone wonders, I got this Patriot 6400 RAM and it seems to work fine with the board, though I'm sure not nearly as good as your guys spendy stuff
http://www.newegg.com/Product/Produc...82E16820220144
