Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 84
Thread: amd's rev F3 silicon
  1. #51
    Feb 2007
    Quote Originally Posted by ozzimark View Post
    that IS really weird. my sempron has the opposite problem.. i can bench 32m up to about 3100mhz, but within 100mhz of that, the computer will just reboot
    What motherboard are you using? I think it's my RAM that's limiting me, but with my Asus Crosshair (Nforce 590 SLI) the DDR2-400, 533, and 667 dividers stop working past 280 HTT. I think I could clock mine higher except I'm stuck with /5 which stresses my RAM. The other weird thing is Memtest86+ 1.7 goes through 1 pass fine (so I don't suspect RAM) and 1M SuperPi works, but Orthos blend fails, but Orthos small FFT works. So I'm leaning towards the problem being RAM, but given all the other weird stuff I've encountered, I don't know.
  2. #52
    Jan 2007
    Stephens City,VA
    what are the timings, voltage, and speed of your ram?
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  3. #53
    Feb 2007
    Quote Originally Posted by hstuehmeyer2000 View Post
    OCZ Platinum Rev 2 PC2-6400 2x1GB @ 2.2V. I know these sticks can do 490 @ 5-5-5-15 for sure (ran 24hr Orthos blend with X2 3800+) however with this new Sempron, it can boot and go through at least 1 pass of Memtest86 at 520 @ 5-5-5-15. With the old CPU, it would refuse to POST past 500, and even 495 would error out Memtest instantly (test #2).
    Anyway the fact that the CPU doesn't stabilize at all even with very high voltage makes me lean to the RAM, but the damned dividers don't work properly at high HTT so I can't be sure
  4. #54
    Jan 2007
    Stephens City,VA
    why don't you just run a divider to find the max of your cpu and tweak your ram later?
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  5. #55
    Feb 2007
    That's the problem, with this motherboard, the higher dividers don't work with high HTT. Of the four I have available to me, DDR2-400, DDR2-533, DDR2-667, and DDR2-800, only the DDR2-800 divider (/5) works when the HTT gets past 260 or so. Which is weird again, since with the Sempron's 8x multiplier, both the 667 and 800 dividers are the same /5 divider. So I can't clock my RAM any slower.
    With my previous X2 3800+ CPU, I was able to solve this issue by using clock skew (advance 600ps) so the DDR2-533 (/8) divider worked but the DDR2-400 divider (/10) still did not work. With the Sempron, NOTHING works. I've tried clock skew, drive strength, a dozen different subtimings, etc.
  6. #56
    Jan 2007
    Stephens City,VA
    are you using a rh mod bios
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  7. #57
    Feb 2007
    Nope. AFAIK there is no RH mod bios for the Asus Crosshair. I've tried the 0502 and beta 0602, same thing.
  8. #58
    Jan 2007
    Stephens City,VA
    i don't know why i though you were using a tforce 550 , i use to have a crosshair to and i had no problem using the ddr 400 divider with my sempron 3000+
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  9. #59
    Feb 2007
    What RAM were you using? I have this problem only with 2x1GB of ProMOS based RAM. I have 2x256MB of generic Micron RAM and it works fine all the way to 370 HTT. When I was using the X2 3800+, it was also fine at the DDR2-400 setting with 2x1GB Micron based Corsair 6400C3DF, so I'm leaning towards something funny in the BIOS that doesn't like the ProMOS RAM.
  10. #60
    Jan 2007
    Stephens City,VA
    i had micron d9dcn that would do about 450@5-5-5-5-T2 2.3v
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  11. #61
    Feb 2007
    It is my RAM! I set the RAM termination manually to 50 ohms and 528MHz or DDR2-1046 (330x8) is perfectly Orthos blend stable after 45 minutes, previously it would error out instantly. I'm keeping my fingers crossed, the last time I tested this RAM it topped out at 490, the last set I had a few months back topped out at 460. Off to play with the drive strength timings now!
  12. #62
    Jan 2007
    Stephens City,VA
    yea, when i had mine i didn't even know what that did, lol
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  13. #63
    Jan 2007
    More cheap opterons from the ebay seller hstuehmeyer2000 got his from. 1210s for $70. Don't know if they're F3s as I haven't got mine yet. Better move quick if you want one, they go fast. 4 left as of right now.
  14. #64
    Jan 2007
    Stephens City,VA
    i wonder who bzo is
    if you watch this ebay seller, every couple of weeks he/she has opterons by it now very cheap, here is the ebay seller, shannonbug06 , don't be like some of the people i posted the original deal to that bought them to resell, just get a good deal and let others to, thats what i tried to accomplish and it failed, thats why i didn't post the $70 deal, because people just buy them and resell them
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  15. #65
    Love and Peace!
    Dec 2004
    hiding somewhere!
    http://eclipseoc.com/index.php?id=3,82,0,0,1,0
    for those who are too lazy to read, important "stability" screens:
    Got a fan over those memory sticks? No? Well get to it before you kill them
  16. #66
    Jan 2007
    Stephens City,VA
    nice oc, but i guess i am a traitor because i went core 2
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  17. #67
    Jan 2007
    i wonder who bzo is
    I'm just a guy into budget OCing. I don't have any association with the ebay guy if that's what you are implying. If you search out my posts, I have a few but relevant posts stretching back at least a few months.
    I dislike the reselling too, which is why I posted it to this thread as opposed to a more general deal area. I figured people reading this would more interested in using it for themselves and would appreciate an F3 if they lucked out with one.
  18. #68
    Jan 2007
    Stephens City,VA
    i thought you might have been someone else i know
    i am also into buget ocing
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  19. #69
    Jan 2007
    I suppose these ebay opterons are not quite the incredible buy for the budget overclocker like they were a few weeks ago, now that Newegg is selling the Brisbane X2 3600 for $73. I like having the extra cache of the Opteron though. Now if only mine would get here, this ebay guy does not seem to be the fastest shipper.
  20. #70
    Xtreme Cruncher
    Sep 2005
    Cincinnati, Ohio
    Really nice chip Ozzimark. Is the full six hours at 3327???
    Ply
  21. #71
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by Plywood99 View Post
    Ply
    of course
    i started with it at 3242mhz, but it failed after a little while, so i dropped it down and did the full 6 hours at 3327mhz. why bother posting the shot otherwise?
  22. #72
    Xtreme Mentor
    Nov 2005
    Devon
    Congrats ozzimark!!
    Excellent chip you have there
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
  23. #73
    Jan 2007
    I finally received my cheap ebay opty 1210 yesterday and it was an F3! It seems like it's a decent core because it will do 9x300 at 1.15v. This low multiplier is holding me back though. I can't seem to post at much above 300 on my M2N-SLI Dlx. I tried upping the chipset voltages +.1 and the max async latency up to 9, but it didn't help. I'm running the ram at the 533 setting, which my sticks should be handling fine. I can't post at even 300 with the ram at the 400 setting so maybe some ram timing is automatically being set too low for an 800+ speed? Any ideas?
  24. #74
    Jun 2006
    stuck in Bloomington, IN right now
    FYI I changed my mind from a DFI INFINITY CFX3200-M2/G to a GIGABYTE GA-M57SLI-S4 but it also supports Opteron 1210 and probably 1212 etc. I should receive it sometime early next week. It will be a bit before I can buy the rest of the components and start overclocking.
    I'm wondering though if the Opteron 1210 or X2 6000+ would be a better overclocker?
    DistroWatch - find your flavor of Linux
    Petra's Tech Shop - for all your watercooling needs
  25. #75
    Xtreme Mentor
    Nov 2005
    Devon
    Quote Originally Posted by AzraelDarkangel View Post
    I'm curious too, so as soon as you get your bits start new thread!!
