Results 1 to 12 of 12
Thread: E4300 BSEL Mod to 1066 fsb
    May 2005
    Hello
    I am searching for sure guide for BSEL modding E4300 to run from 800 to 1066 FSB default.
    I found this: http://www.ocforums.com/showthread.php?t=498167
    First it was and idea on first post:
    http://www.ocforums.com/showpost.php...21&postcount=1
    Some dude made this, and it didnt worked like he did first:
    Then he did it other way - and this time it looks like it works:
    http://img178.imageshack.us/img178/9697/success1xz8.jpg
    Can anyone confirm? That this can be done like he did?
    so it would look like this.......
    Is that correct?
    Aug 2005
    Very bottom BSEL pin you show connected shouldn't be. Just the second and fifth BSEL pin up from the notch should be bridged. Remember, that picture is of the LGA775 socket and if bridging on the CPU the location of the pads is mirrored if looking at the underside of the CPU.
    May 2005
    so that what this dude did - why is it working? :>
    he connected 1,2,and 5 th from the notch
    Aug 2005
    Quote Originally Posted by qba_dx
    Which dude? I see no link between those pins, just the bottom one slightly discolored cos he USED to have it covered with copper ink.
    Why not do some research into what the mod actually does instead of just jumping on the bandwagon totally uninformed and just going from pictures.
    EDIT: BTW I bridged just second and fifth on my E4300 and it is working @ 1066. So even if it works with it 1,2 and 5 bridged it isn't necessary.
    Dec 2004
    2nd and 5th from the notch definitely works. I have done it also.
    Apr 2005
    So this will jump them automagically back to 1066FSB? NICE!!!
    Core 2 Duo E8400 @ 4ghz
    2GB PC2-6400 @ 445/890 4, 4, 4, 12
    ATI HD4850 @ stock
    Gigabyte P35-DS3L
    El Cheapo 500w PSU with dual 12v rails
    16X DVD+/- R/W
    May 2006
    Canada
    This has already been covered a bunch of times in this thread.
    Also Nephilim is right only the 2nd and 5th from the notch are supposed to connect.
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
    May 2005
    ok thx for answers then - i wasnt sure - so its better to ask than to fry a conroe, huh?
    Sep 2005
    @Nephilim
    may i know what board are you using with this proc? thanks.
    May 2005
    Gigabyte GA-P965-DS4 rev 3.3
    E6600 runs easily 430+ fsb on the same mobo - so i think low fsb may be only cpu's fault. I'll try to mod it for 1066 - maybe i'll help.
    Jan 2004
    Saskatoon, SK
    Very nice mod.
    Has anyone seen E4300's not able to run at 266x9 out of the box with all stock voltages? If so I'll definitely try and get this done before I boot up the first time and save myself some OC work.
    EDIT: It has been brought to my attention that most all E4300's will get pretty close to 3GHz on stock voltages, so 266FSB is a no brainer it seems. Can anyone confirm that there are overclocking benefits to this mod, increased FSB ceilings or anything of the sort?
    • Intel Core i7 875K @ 3.86GHz 1.35v /w Intel Extreme Tower Heatsink
    • Intel Extreme DP55KG
    • 2x2GB Kingston HyperX PC3-10666
    • ATI HD5970 2GB @ 850/1,200
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    Sep 2006
    Does this mod work on Morem (specifically the T7200)? Thanks.
