This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
Doom 3: Setting AA to 4x and AT to 8x along with the display resolution to 2560x1600 no longer results in display corruption being noticed. Further details can be found in topic number 737-25520
Corruption is no longer noticed during fast motion of DVD playback when using MCE/WMP. Further details can be found in topic number 737-23550
Catalyst™ Control Center->Display Manager: Connecting only a CRT display device to a system running Windows Vista no longer results in TV display modes being available. Further details can be found in topic number 737-24467
The Microsoft Vista operating system no longer fails to resume from an S3 state on systems containing an ATI Xpress 200 series product. Further details can be found in topic number 737-25506
A flickering display is no longer noticed when playing a DVD using the Windows Media Player in full screen and resuming from a standby state after disconnecting a CRT display device. This issue was known to occur when using a system containing an ATI Xpress 1100/1150 series product. Further details can be found in topic number 737-25507
Catalyst™ Control Center: The Help Launching Dialog is now localized for all supported languages. Further details can be found in topic number 737-25508
Hot plugging or un-plugging a third display device when CrossFire™ is enabled no longer results in the primary display device being swapped and identified as the display device connecting to the primary port on the master card. Further details can be found in topic number 737-25509
Connecting a TV to a system containing an ATI Xpress 200 series and setting it to PAL no longer results in the user not being able to control the display resolution on the LCD display when using the Catalyst™ Control Center.
Further details can be found in topic number 737-25511
The Windows Vista software driver for ATI Radeon™ products no longer fails to install if copied to a directory with a long name or to a directory with a long file path location. Further details can be found in topic number 737-25514
Display corruption is no longer noticed when watching TV under the Windows Vista operating system when using an ATI Radeon™ X1600 series product. Further details can be found in topic number 737-25515
The Catalyst™ Control Center no longer fails to launch under the Simplified Chinese version of Windows Vista. Further details can be found in topic number 737-25516
Connecting two display devices with one display device using the HDMI connector (secondary) no longer results in faded colors being noticed on the HDMI display device when swapping (primary and secondary) between the two display devices. Further details can be found in topic number 737-25793
The display mode of 1440X900@75Hz is now available within the Catalyst™
Control Center when using a system containing an ATI Radeon™ X1600/1650 series of product. Further details can be found in topic number 737-25794
Disconnecting the primary display device when the Windows Vista operating system is in a standby state may result in the log-in screen failing to appear when resuming. Further details can be found in topic number 737-24470
Hot-unplugging a secondary CRT display device while the Vista screen saver is active no longer results in corruption being noticed on the LCD display when ending the screen saver activity. Further details can be found in topic number 737-25795
The PowerPlay option is no longer available on systems that do not support the option under the Japanese version of the Windows Vista operating system. Further details can be found in topic number 737-25796
Changing the PowerPlay setting to either Power Saving or High Performance under Windows Vista, followed by rebooting the system no longer results in the PowerPlay setting displaying Battery Life mode regardless of the system being on AC power. Further details can be found in topic number 737-25797
