Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 109
Thread: Asus Striker Extreme vDroop Mod
    May 2006
    Canada
    To make things easier I thought I'd edit the first post and put the mods there so it's easier to find.
    These pencil vmods should work on the Asus Striker Extreme and the P5N32-E SLI.
    I've done the vDroop mod on my own board so I know it works perfectly.
    One important tip. If you decide to get rid of the mod you can erase it with an eraser but MAKE SURE you do not accidentally rub the pencil lead onto the stuff around the modded resistor.
    Tip 2: Do NOT solder or use a conductive ink pen on the resistors!!!! The point is to REDUCE the resistance not get rid of it altogether.
    *EDIT*
    I updated the pic because jonbass kindly donated it to me. I hope this makes everything clearer.
    ***********NOTE**************
    The vCore mod is in question right now TRY AT YOUR OWN RISK
    The vDroop is 100% working so far.
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
    Xtreme Guru adamsleath's Avatar
    Nov 2006
    Brisbane, Australia
    i remember seeing one...i thought kunaak had one in a p5n32-e thread???....maybe the one i saw was for p5n-e now that i think about it.
    [i have just set nb to 1.4v and i think im at my cpu limit...same limit for 9x and 8x.]
    so...do these voltmods lower the volts that your cpu neeeds or something?? what is it?..how does it work?
    i7 3610QM 1.2-3.2GHz
    May 2006
    Canada
    Its supposed to prevent the voltage from sagging as low. Sometimes your voltage is stable but the droop voltage is not. So if you get rid of the droop u don't have to set the normal voltage as high to compensate for the droop.
    Also the extra voltage causes more heat and well u get the picture.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
    Mar 2004
    I can't assure you that this one work 100% because my board died before I could test it but persivore help'd me with it and he knows his stuff so I assume that it works. The vcore mod works 100% though.
    Intel FTW!
    Beanna
    May 2006
    Canada
    Woot thanks a ton for this mod. Hmm i dunno if i have the soldering skills to do that tho. I think i might practice a bit or wait for something easier. Trying 2 c if there's a pencil mod if not then i guess i have no choice.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
    May 2006
    Canada
    Wooooooot after staring at the damn mobo pics for hours I decided to try my own vdroop pencil mod and BANG its confirmed working.
    I did about 3 strokes where the green line is with a 4B pencil and now there is 0 droop.
    Sorry 4 the bad quality pic, it was taken with a camera phone.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by ineedaname
    You sure the green line is drawn correct...? Is it supposed to be in the same place as NiCKE^ soldering mod pics above? If so the green line is on the wrong row. It looks like it should be on the row right next to the chip. Please clarify.
    *** H0RM0NE ***
    "Fight's on; Fight's on."
    Current Build:
    * Asus P5N32-E SLI PLUS Rev A2 BIOS 0602
    * E6400 L629B642
    * Crucial Ballistix 2GB PC2-8000 CL5
    * Corsair HX620W
    * XFX GeForce 7900GS XS 256MB GDDR3
    * 2 x Seagate Cudas 400GB SATAII RAID 0
    * Creative SB X-Fi Platinum 7.1
    * Onboard Nic/Lan
    * Scythe Infinity P/p & TT CL-C0034
    * Antec P180B
    * NEC Multisync FE2111sb
    Xtremely Retired OC'er
    Dec 2006
    Yeah asus gettin known to make extra mods&home
    May 2006
    Canada
    Quote Originally Posted by H0RM0NE
    I'm 100% sure it is where i put the green line. The spot that is soldered in NiCKE^'s pics is just an empty space.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
    Oct 2006
    Sydney, Australia
    ahah Hmm.. do you think this same pencil mod will work on the P5N32-E SLI? =D
    ASUS W7S-3P100E
    * Intel Mobile Core 2 Duo T7500, 2.2 GHz 4MB L2 Cache 800MHz FSB
    * Santa Rosa Intel Mobile PM965 Express Chipset + ICH8M
    * 1.5 GB RAM DDR2-667MHz
    * Nvidia GeForce 8400M G
    * 160 GB HDD Hitachi Travelstar 5400rpm
    * 13.3” WXGA (1280x800) ColorShine TFT-LCD Asus Splendid Video Intelligent Technology
    * 8X DVD Super Multi drive with LightScribe
    May 2006
    Canada
    NiCKE^'s board is a P5N32-E SLI and they're the same so yes it'll work.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
    Mar 2004
    Portugal
    Anyone has tested this vmod ?
    I want to do it but want to have certain about doing it the right way
    May 2006
    Canada
    Like i said i've done it already and its working for the Striker Extreme.
    Some1 still has 2 test it for the p5n32-e. On the other hand if u look at the pics they're the exact same so it should b fine.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
    Oct 2006
    austria
    thank you very much ineedaname-works flawless
    info or pics on vtt-mod ??
    greets from austria
    May 2006
    Canada
    This should be the vCore mod.
    Its pretty much where NICKE^ has it up there cept you can pencil it if you want to.
    Just to double check. Make sure its the resistor connected to the 4th leg from the left on the bottom of the chip.
    I personally don't really need a vCore mod cuz my board already gives me more voltage than what i put in the bios.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
    Feb 2007
    Weesp, Netherlands
    I think I need this mod as well. Vcore in Asus Probe II is 1,48 but when running orthos it drops to 1,44.
    Can you show where on the motherboard this needs to be done. It seems like it's close to the memory slots or am I wrong? Perhaps you can make a larger picture of the motherboard as a whole and point out where it is. Will save a lot of time searching!
    thanks in advance.
    - Asus P8P67 PRO
    - i5 2500K - L103A965
    - Intel Postville X25-M 80Gb SSD
    - MSI HD6950@6970
    - Thermaltake Toughpower 750W.
    - EK Supreme HF Full Copper
    - Laing DDC3.2 /w Petrastech top
    - Feser Xchanger 360mm
    May 2006
    Canada
    Here's a better pic donated to me from jonbass.
    I'll change the pic uptop too.
    I hope it helps.
    The actual location of this is at the top of the board to the left of the ram slots.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
  18. #18
    Nov 2005
    i did this pencil mod..
    on load.. the vcore jump by 0.02 instead thr i have use lesser vcore now. probably going to rub off some extra carbon and hope to rectify it
    [vRz] Nexus
    CPU: Intel Q6600 - 3600Mhz - 1.4v Motherboard: DFI X38 T2R LT - Memory: Cellshock CL4 PC2-8000 2 x 1GB
    Display
    : Dell 2407WFP-HC A00 | Powercolor PCS 3870 Crossfire - 512MB
    Storage: Western Digital 2 x 36GB Raptor ADFD SATA (Raid 0) | Western Digital 250GB SATA II | Hitachi 80GB SATA II | LG 20x SATA DVD-RW
    PSU
    : Thermaltake Toughpower 1200W Enclosure: SilverStone TJ09 B-W Input: Logitech G15 Keyboard | Logitech G5 Mouse
    3DMark06
  19. #19
    Mar 2007
    Moose Jaw, SK CA
    Arrow Micro Tip Conductive Pen
    Nice thread ineedaname
    Thinking of using my trusty conductive pen (CW2200MTP) to do this mod, havn't used since the old days when connecting L1 bridges on my old AMD cpu
    Do you see any issues using a fine point conductive pen vs pencil ?
    Thanks in advance
    RIG 1: Asus Rampage Extreme X48
    RIG 2: Foxconn BloodRage X58
    E8600 Q820A349 @ 4.75Ghz: http://valid.canardpc.com/show_oc.php?id=596270
  20. #20
    Oct 2005
    U.K.
    do not use conductive ink, it will just create a bridge with no (or very very little) resistance, shorting the circuit and probably killing something
    i950 (3035B684)
    Gigabyte EX58A-UD3R
    3x4GB G.Skill PC3-12800 7-8-7-24
    HIS Radeon HD 6970 2GB & Dell 3007WFP-HC
    Asus Xonar DX
    128GB C300, Velociraptor & Sammy F3's
    Corsair AX850W
    Windows 7 Ultimate x64 SP1
  21. #21
    Mar 2007
    Moose Jaw, SK CA
    Quote Originally Posted by Pyr0 View Post
    Thanks for the heads up Pyr0
  22. #22
    Mar 2007
    Moose Jaw, SK CA
    btw how many passes are you guys making on the modded resistor with the pencil ?
    EDIT: Nevermind I see in previous post, 3 strokes
  23. #23
    Mar 2007
    Moose Jaw, SK CA
    Quote Originally Posted by ineedaname View Post
    I assume you used the 4B cuz it's harder led with more graphite making it more conductive then say a 2B or HB ?
  24. #24
    May 2006
    Canada
    Yea I've heard you can use different pencils but i used a 4b.
    The only difference would probably be the number of strokes.
    If you wanna be exact u can use a multimeter and test how much resistance you've taken off.
    And yea like pyro said the point is to take away SOME resistance NOT ALL so the circuit pen is a no no.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
  25. #25
    Oct 2005
    Milton Keynes, UK
    Talking
    *EDIT*
    What resistance did you change it to? ANd what was the initial measure?
    TIA
