DFI RD600 maybe the most ever complex mobo for overclker.
real challenge, especially it's bios setting
and pi/sis results.
max fsb reached = 515mhz, but cpuz 1.39 validation seems have prob atm.
Thanks for the post Victor. Nice numbers.
Gaming rig
CPU.........................Intel QX6850 @ 3800, 8x475
Motherboard.............DK P35 Dark
Video.......................8800 Ultra
RAM.........................4x1 OCZ Titanium Alpha VX2
Hard drives...............2 Raptors in RAID0
Sound card...............X-Fi Fatal1ty, Medusa 5.1 headphones
PSU.........................PCP&C 1KW(custom build)
CPU cooling..............Liquid
Hardware cooling.......Liquid cooled card and NB
Case........................Custom 22" cube by M.M.
OS...........................XP Pro
I added it to my sticky in Intel Info & Support, thnx Victor
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
i cant get my g skill gbhz 8000 to post past 574 mhz @ 4.4.4. or @ 5.5.5 which is pissing me off any ideas =/ maybe some sub timing i have to tight i have tryed alot of setting also oddly when i left the mobo powered down all night then turned it on it posted @ 600 mhz once which seems weird .. any ideas would help thx
mmm... for me vdroop is huge in vcore and vdimm.. hope DFI can fix this..
Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
X6800 , E6750 es
Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
Ati FireGL V5100, Elsa FireGL V3100
water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
Silverstone OP650
raptors, baracuda
humm i only get like .02 v droop but maybe its a lie
I'll have more tips for this mobo in few days.Originally Posted by NickS
finally got a 10days holiday and 60L LN2 waiting for me
Oh finally someone will try LN on this board!Originally Posted by VictorWang
Me still waiting for w/c! It was quite easy to reach 3,6Ghz with my Xeon 3060 (looks like there is still nice headroom), but hadn't much time for ram tweaking so its running at 500 4-4-4-8!
Thank you!!
Core2Duo E6600 with Tuniq Tower120 | ASUS P5B Deluxe | 2x1 GB G.Skill HZ DDR2-800 | Winfast GF8800GTS 320MB | WD Raptor 36GB | Seagate 320GB 7200.10 | Zippy 500Watt Gamer Edition | CM Stacker 810
www.unlimitpc.com
hopefully there are some records for this board yet... wish the issues would get worked out though.
very usefull tips fore the people with this mobo i'm sure its very appriciated
Good tips there. I´m waiting for a new bios....
[SIGPIC]http://techsweden.org[/SIGPIC]
Gigabyte Z87X-OC, Haswell 4770K, 8GB Team Group 2666mhz, Asus HD7970
So the vdimm does crap out after a cmos clear. Thats a problem. No wonder i have C1 errors after a cmos clear.
Core i7 920 @
MSI X58 Eclipse SLI
6GB Mushkin Blackline
GTX295
cmos resets to 1.84 vdimm or so..
3d mark 05 and 06, best on nb 266 strap, with fsb as close to 464 point as you can get it, ram needs to be wide as possible, with pcie up to near 150mhz on 8800's.
If I eencounter a C1 error.. I use one memory module.. and then set the right voltage and settings again..
I'll try DIMM 2&3 is Dual Channel.. ^_^
X6800 , E6750 es
Silverstone OP650
raptors, baracuda
Its the or so on the vdimm that i worry about. Everything i have boots at 1.8 on my Aw9d-mAX but not on the DFI.
Core i7 920 @
MSI X58 Eclipse SLI
GTX295
