Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: 6000+ Simple and Short OC Test
    Dec 2004
    Seoul, South Korea
    I've experienced 6000+ shortly. It was impressive in that SPi 1M scored 29.XXs with just default setting.
    Here is OC test results under winter advantaged air-cooling. 32M SPi could be run with lower clock. Sorry for my crappy chip photos.
    My current rig info,
    CPU: Intel Core 2 Duo 6600 Retail (Maleysia Packing L632F047)
    Mainboard: ASUS P5W 64 WS Pro (BIOS Version: 0402)
    Memory: SuperTalent DDR2 5300 1G*4 or A-DATA 6400 Extreme Edition 512M*2
    VGA: Nvidia 7600GT or Matrox G200
    HDD: Seagate sata2 320G*2 in raid0 and Samsung sata2 250G
    Power: Enermax EG701AX-VE
    Case: Nude in action when overclocking!
    Cooler: Nowpug.com DI/LN2 2.5' Copper Container or Tuniq Tower 120
    Monitor: UP-M23U or 10'4 dedicate display for overclocking
    OS: Windows XP or 2003 Server
    Jan 2007
    Brisbane, Australia
    Very nice.
    OUCH @ vcore though :P
    won't be doing that in anything but freezing weather. what is the load temp? and what sort of air cooling
    Nov 2005
    WOw! that's an awesome overclock for aircooling and an AMD 90nm cpu.
    BTW, could someone explain to me why there are more than 48 weeks according to AMD's stepping's system? I'm sorry I'm sure it's been asked a lot, but boggles my mind every time I see an 0651 or an 0653. =P
    -Cpu:Opteron 170 LCBQE 0722RPBW(2.87ghz @ 1.300v)
    (retired)Opteron 146 (939) CAB2E 0540
    -Heatsink: Thermalright XP-90
    -Fan:120mm Yate Loon 1650 RPM @ 12V, 70.5 CFM, 33dB
    -Motherboard: DFI Lanparty nF4 UT Ultra-D
    -Ram: Mushkin High Performance blue, 2gigs(2X1gig kit) PC3200 991434
    -Hard drive: Seagate 400GB Barracuda SATA HD 7200.10(AS noisey model)
    -Video card: evga 6800GS @520/1170
    -Case: P180
    -PSU:Enermax 535Watt EG565P-VE FMA (24P)
    Sep 2006
    Wow 3.5ghz, that's impressive. At what clock speed is it 32M Super Pi stable?
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    thats pretty dang good result.
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Dec 2005
    Poland
    May 2005
    [EU] Latvia, Jelgava
    Why you bought Windsor, while you can buy Brisbane?
    Jan 2006
    revision f3 90nm is a better process for now than brisbane, assuming as it is f3, as that part is cut out of the screenshot... give it time, and brisbane will be worth it, but not yet. ultimately, they will both ofcourse be put to shame by star.
    Core i7 920 3849B028 4.2ghz cooled by ek hf | 6gb stt ddr3 2100 | MSI HD6950 cf cooled by ek fc | Evga x58 e760 Classified | 120gb G.Skill Phoenix Pro | Modded Rocketfish case + 1200w toughpower | mcp 655 pump + mcr 320 + black ice pro II
    KiSUS
    Nov 2006
    Russia / Moscow
    Amazing OC
    Try to use Dry ice for example.Maybe 3.8-4G is possible ?
    Lights, Music, Camera, Action !
    Jan 2005
    NJ
    wow 3.5 is sick on air but i agree those volts are brutal
    CPU Z:2700 2k1:27952 2k3:12282 2k5:5763 PCM05 AQ3
    Opteron 165 s939_____OCZ RAM/PSU_____BBATI X800xl
    Jan 2006
    that vcore isnt that bad, ive gone to 1.6 on my chip, only reason i didnt go further was diminishing returns... anything up to 1.65 isnt that crazy, considering its chilled air.
    Xtreme Mentor
    Nov 2005
    Devon
    I want CZ CPU! I have pretty nice custom made (my design with plenty of little spikes inside to maximize heat dissipation surface, done in year 2003, revision No.3) water block waiting for something HOT so it can be utilized properly!
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    as long as super pi isnt your thing, a CPU capable of 3.5 ghz on air, is definatly worth noting.
    definatly a interesting CPU.
    I am Xtreme
    Aug 2003
    Assuming it's actually 1.63v like CPU says... How is that brutal? I ran 1.65-1.68 24/7 on ambient air for almost a year on my 165 and ran my 146 up to 2.05v on dry ice.
    Nice CPU man. How high can it run dual 32m on ambient temps? 3.2-3.3 I'm guessing?
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Sep 2006
    Quote Originally Posted by Kasparz
    Brisbane will not be worth because of AM2 Still id love to see numbers. Im using AMD processors for more than 7 years, but AM2 is worst thing AMD ever made. 3.5Ghz with chilled air is impressive on 90nm, nothing more to say. Even best of the best s939 dualcore Opterons cant do that
    Id bet itll be coldbugged. Maybe chilled water or mild phase can do better.
    And why again is AM2 the worst thing AMD ever did? I usually hear this from 939 owners because there mad AMD ended 939 early, in their opinion.
    AM2 is still early and growing, it will be around for awhile and compatible with AM2+. AM3 wont be here for a long while.
    AMD Athlon 64 x2 4600+ AM2-currently @2700mhz
    MSI K9N Diamond 590 SLI
    2x1 GB Mushkin HP2-5300 - 4-4-4-10
    Seagate 320GB Barracuda 7200.10 SATA II w/ NCQ, 16MB Cache
    eVGA e-GeForce 7900 GS KO 256MB PCI-E - 589/790
    OCZ 600W GameXStream Power Supply w/ Quad +12V
    Zalman CNPS9500 AM2 Cooler
    I am Xtreme
    Apr 2005
    Upstate, NY
    Quote Originally Posted by Magnj
    Guys, cmon. 1.63v is nothing.
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Xtreme Guru
    Dec 2006
    Philly/NJ
    Why you bought Windsor, while you can buy Conroe?
    fixed.
  18. #18
    Oct 2006
    Ontario
    Wow, great stuff there. Thanks for sucking it up and getting a 6000+!
  19. #19
    YouTube Addict
    Aug 2005
    Klaatu barada nikto
    cpuz validation?
    Fast computers breed slow, lazy programmers
    The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
    http://www.lighterra.com/papers/modernmicroprocessors/
    Modern Ram, makes an old overclocker miss BH-5 and the fun it was
  20. #20
    Xtreme Guru
    Dec 2006
    Philly/NJ
    Quote Originally Posted by nn_step
    cpuz validation?
    dont trust anyone huh nn?
  21. #21
    Feb 2006
    Vienna, Austria
    cpuz validation?
    hehe i asked myself when nn_steps in and asks about validation
    but you're right that there are ALOT of fakes out there, but i see no point in faking an 6000+ result....
    Core i7 2600k|HD 6950|8GB RipJawsX|2x 128gb Samsung SSD 830 Raid0|Asus Sabertooth P67
    Seasonic X-560|Corsair 650D|2x WD Red 3TB Raid1|WD Green 3TB|Asus Xonar Essence STX
    Core i3 2100|HD 7770|8GB RipJawsX|128gb Samsung SSD 830|Asrock Z77 Pro4-M
    Bequiet! E9 400W|Fractal Design Arc Mini|3x Hitachi 7k1000.C|Asus Xonar DX
    Dell Latitude E6410|Core i7 620m|8gb DDR3|WXGA+ Screen|Nvidia Quadro NVS3100
    256gb Samsung PB22-J|Intel Wireless 6300|Sierra Aircard MC8781|WD Scorpio Blue 1TB
    Harman Kardon HK1200|Vienna Acoustics Brandnew|AKG K240 Monitor 600ohm|Sony CDP 228ESD
  22. #22
    Jan 2003
    Sweden
    Any coldbug?, try to lower multi and see it it got coldbug plz...
  23. #23
    YouTube Addict
    Aug 2005
    Klaatu barada nikto
    Quote Originally Posted by Spawne32
    I do but achievements deserve validation.
  24. #24
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by generics_user
    plus the 1M time matches up with the speed the chip and ram is running at..
    Got a fan over those memory sticks? No? Well get to it before you kill them
  25. #25
    Xtreme Cruncher
    Sep 2005
    Cincinnati, Ohio
    Woot! Nice Windsor dude. Can't wait for Amd to get the sauce right for 65nm. 3.3+ may get to be a norm for over-clocks...
    Ply
