Page 1 of 4 1234 LastLast
Results 1 to 25 of 83
Thread: Recent water block (GT/Fuzion/Storm) test results...
    Jul 2006
    Vancouver, BC
    Here is a summary of the recent Fuzion, Apogee GT, and Storm test results that I've found to date...
    Notes:
    - If multiple mounts were done and results provided, I've indicated that and averaged the mounts/runs.
    - Review the test methodology details and test result details by clicking the links
    - All values are in deg C unless otherwise stated
    - DT Values are from Core Temp to Air (unless otherwise stated)
    - Quad core load temps as reported by core temp or TAT were averaged by the testers and sometimes the difference between cores was as much as 10 deg C. According to Philly_boy lapping seemed to reduce difference in cores significantly.
    H20 Frag-monger (Apogee vs. Storm R2 vs. Fuzion)
    CPU: X6800 OC to 3.8GHz
    WC Gear: MCP-655, MCR-220
    Test SW: TAT
    DT Results: Apogee = 55.8, Storm = 51.7, Fuzion = 49.5
    Winner: Fuzion beats Apogee by 6.3 and Storm by 2.2
    Link: http://www.xtremesystems.org/forums/...&postcount=152
    CPU: N/A - 30x30mm 100W die
    WC Gear: Lytron chiller
    Test SW: N/A
    DT Results: N/A (C/W Curves)
    C/W Results @ 1GPM: Apogee = 0.064, Storm = 0.059, Fuzion = 0.057
    Pressure Drop @ 1GPM: Apogee = 2PSI, Storm = 5PSI, Fuzion = 0.5PSI
    C/W Winner: @100W/1GPM Fuzion beats Apogee by 0.7 and Storm by 0.2
    PSI Winner: @1GPM Fuzion has 25% and 10% of the pressure drop of Apogee/Storm
    Link: http://www.xtremesystems.org/forums/...&postcount=304
    Nikhsub1 (Storm G5 vs. Fuzion vs Apogee GT)
    CPU: E6700 OC to 3.85GHz @ 1.56Vcore
    WC Gear: 2xDDC Ultra, PA-120.3
    Test SW: TAT
    DT Results (avg of 3 mounts each): Storm G5 = 39.08, Fuzion = 43.06, Apogee GT (flat) = 44.54
    Mount variation in DT: Storm 2 deg, Fuzion 2 deg, Apogee GT = 4.5 deg
    Winner: Storm G5 beats Fuzion by 3.98 and Apogee GT by 5.46
    Link: http://www.xtremesystems.org/forums/...1&postcount=10
    FreeCableGuy (Storm R2 vs Apogee vs Fuzion vs Apogee GT)
    CPU: X3220 Quad Core
    WC Gear: D5, PA120.3
    Test SW: Prime95 x4
    DT Results (@150W): Apogee = 25, Storm = 26.5, Fuzion = 24, Apogee GT 24
    Winner: Fuzion and Apogee GT very close and beat Apogee by 1 and Storm by 2.5 (@150W)
    Link1: http://www.thetechrepository.com/showthread.php?t=85
    Link2: http://www.thetechrepository.com/showthread.php?t=78
    Link3: http://www.thetechrepository.com/showthread.php?t=84
    Philly_Boy CES Showdown Part 1 (Apogee GT vs. Fuzion)
    CPU: X6700 Quad Core OC to 3.6GHz @ 1.425Vcore
    WC Gear: MCP-655, MCR-320
    Test SW: CPU Burn 5
    DT Results: Apogee GT (Bow?) = 42.1 (1 run), Fuzion = 38.2 (avg. of 3 runs on 2 mounts)
    Winner: Fuzion beats Apogee GT (Bow?) by 3.9
    Link: http://www.xtremesystems.org/forums/...0&postcount=84
    Philly_Boy CES Showdown Part 2 (Apogee GT vs. Fuzion)
    CPU: X6700 Quad Core (lapped) OC to 3.466GHz @ 1.5Vcore
    Test SW: CPU Burn 5
    DT Results: Apogee GT (flat) = 41.7, Apogee GT (Bow) = 34.1, Fuzion = 37.3 (using D-Tek mounting hardware and methods)
    Winner: Apogee GT (Bow) beats Apogee GT (flat) by 7.6 and Fuzion by 3.2
    Link: http://www.xtremesystems.org/forums/...d.php?t=130142
    Shamino (VR-Zone) (Apogee GT vs. Storm Vs. MCP-05 Pro)
    CPU: X6700 Quad Core OC to 3.615GHz @ 1.7Vcore
    WC Gear: D5, 2x120mm Rad?
    Test SW: CPU Burn
    DT Results (from Asus Probe): Apogee GT (flat) = 58, Storm = 60, MCP-05 Pro = 56
    Winner: MCP-05 Pro beats GT (flat) by 2 and Storm by 4
    Link: http://www.vr-zone.com/?i=4476&s=1
    Budwise (Storm G4 R1 vs. Fuzion)
    CPU: E6600 OC to 3.6GHz @ 1.45Vcore
    WC Gear: MCP-655, PA120.3
    Test SW: Orthos
    DT Results (from CoreTemp): Storm = 54, Fuzion = 51
    Winner: Fuzion beats Storm by 3
    Link: http://www.xtremesystems.org/forums/...1&postcount=30
    Philly_Boy (Apogee GT vs Fuzion)
    CPU: E6300 OC to 3.7GHz @ 1.6V Vcore
    WC Gear: MCP-355, PA120.3
    Test SW: TAT
    DT Results (from CoreTemp): Fuzion = 37, Apogee GT = 34
    Winner: Apogee GT (Bow) beats Fuzion by 3
    Link: http://www.xtremesystems.org/forums/...7&postcount=54
    David D. at CoolingMasters.com (Rosco?) (No Fuzion tested)
    CPU: E6300 OC to 3.01GHz @ 1.59 Vcore
    WC Gear: AquaX150Z, MCR220
    Test SW: TAT
    DT Results Original IHS (Core to Water @ 350lph): Apogee = 47.1, Apogee GT = 44.4, Apogee GT (bow) = 42.1, Storm = 49.6, MP-05 SP = 48
    Winner: Apogee GT (bow) beats Apogee by 5, GT Flat by 2.3, Storm by 7.5, MP-05 by 5.9
    Link (translated): http://translate.google.com/translat...language_tools
    Kunaak (Fuzion vs Storm)
    CPU: X3210 (quad core) OC to 3.6GHz@ 1.48V Vcore
    WC Gear: MCP-655, Old BIX Extreme(?)
    Test SW: Wprime
    DT Results (Avg. from TAT): Fuzion = 42.9, Storm= 52.8
    Winner: Fuzion beats Storm by 9.9
    Link: http://www.xtremesystems.org/forums/...d.php?t=136703
    To see results of a MCW6002a compared with a Fuzion see post #59
    My conclusions so far:
    Given the fact that all tests by the same testers varied by up to 2-4 degrees just by remounting or doing another run and the fact that all blocks are typically within a few degrees of each other (and often much less) I would say it's impossible to declare any block definitively superior to another so far.
    Given this, I think any testing without multiple and equal number of remounts for each block can be very misleading. For example, Nikhsub1's tests show that the Fuzion could win by 4 degrees or lose by 1 degree to the GT depending on which mount and run you used to compare. With the mount making as much as a 5 degree difference on blocks that typically only differ by a couple of degrees it makes drawing conclusions from limited runs/mounts dubious at best.
    The only thing that everyone seems to agree on is that the Fuzion flows significantly better than any other CPU block giving it a distinct advantage in multi-block loop performance.
    BTW, if I've made a mistake in summarizing the results or there are other tests that can be added to the list above, please let me know. Keep in mind that if multiple runs or mounts were reported, I averaged the results of those runs/mounts in the summaries above.
    Jan 2007
    I agree
    I agree with your assessment both Apogee GT and Fuzion blocks are so good either one is a good choice but as I have found out lapping the CPU makes them even better as seen at the swifttech challenge. Here is my review of the fuzion after installing, now I am not afraid of summer time temps with OCd quad core.
    http://www.xtremesystems.org/forums/...d.php?t=131298
    Xtreme Mentor
    Sep 2004
    my pants
    Clearly we should all get G7's and call it a day lol...
    French Duron Poof
    Every time you lap a swiftech block a kitten dies
    "Extreme Systems, yes. But it could also mean Extremely creative, Extremely resourceful and on and on. Please don't use the name of this site as an excuse to do stupid things" -situman
    HEAT
    Banned
    Apr 2006
    Portishead, Bristol, England
    The mount..is this with better bolts being used?
    Apr 2006
    Hong Kong
    The fact that it is apparent no clear winner has emerged...
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
    Mar 2005
    Virginia
    The world would be a better place if more people understood statistics.
    This is not a dig at the OP, I agree with him.
    I don't think all of the reviews are complete in part because they haven't accounted for the mounting variations mentioned.
    What is needed is at least 50 different tests each with the same blocks and different mounts. So the same 10 blocks with different reviews, for example, but each block is remounted five different times.
    The aggregate data can then be analyzed and the spread can be computed.
    Here is an old but fair example of testing methodology.
    I can't spell, but I am working on it.
    Feb 2003
    Greece
    Why isn't anybody focusing on mounting between Storm vs MCP-05 Pro.......???
    But of course............ because nobody touches the Storm.
    And now that Swiftech has a new block that from day one has to be modded to give equal or better results compared to another contender, a lot of people are talking about bad mounting.
    Excuse me but if a block can not be mounted properly isn't that a defect for that block?Or do i have to be a GURU of mounting just to mount a waterblock? If the block's base is flat or concave(Apogee GT) isn't that Swiftech's design or fault?
    Why for some people is so dificult to believe that maybe just maybe there is a better block out there, better than Swiftech's blocks?
    i7 920 3922A436 W/C HEATKILLER | DFI LP UT X58-T3EH8 W/C Swiftech MCW30 | Corsair 6GB DDR3-1600 Ram Kit (3 x 2GB, PC2 12800, 7-7-7-20, TR3X6G1600C7) | Sapphire HD4870 X2 W/C (EK) | PC P&C 750 Quad Cf |1 x Intel Postville 80GB SSD | 2 x Raptor 36Gb Raid0 | 2 x Seagate 500Gb Raid0 | 2TB Western MYBOOK STUDIO EDITION II Raid0 | PHILIPS 42PFL8404H | WIN 7 Ultimate x64 | CoolerMaster CM Stacker | ThermoChill PA120.3, Swiftech MCP 355 with XSPC v3 top
    Sep 2006
    DENMARK
    Quote Originally Posted by Varsos
    I would to ask that exact same thing.
    According to VR-Zones review, the MP-05 was the best block.
    CPU: Core i7 (D0) @ 4.2GHz.
    Mobo: Asus P6T Deluxe V2 crossed flashed 0006.
    RAM: Corsair TR3X6G1600C7D @ 1600MHz 6-7-6-20.
    HDD: 2 * Corsair P128 SSD RAID 0.
    GFX: Sapphire Ati 4670 Passively cooled.
    PSU: Seasonic M12-700Watt.
    Case: Corsair Obsidian 800D.
    Monitor: BenQ FP241W 24" 1920*1200 Soyder3 calibrated.
    OS: Windows 7 Ultimate x64.
    Watercooling: EK Supreme, Laing DDC+(18W) EK top , Black ICE Pro II Radiator + Black Ice GTX360, EK Multi Option Res 150 v2, EK 3/8" fittings, Clearflex 60 3/8".
    Digital SLR: Nikon D300 - Nikkor AF-S DX 17-55mm f2.8 - Nikkor AF-D 50mm f1.4 - SB800 Flash.
    HT: Panasonic 42" PZ800, Yamaha DSP-Z7, ROTEL RB-1572, Dali Mentor Series Speakers, PS3.
    Jul 2006
    Vancouver, BC
    Keep in mind the VR-Zones review is perhaps the most flawed of all. It didn't mount the blocks multiple times or even do multiple runs and it used ASUS Probe for the temperatures!?
    I suspect that the MP-05 is right up there with the other blocks... like I said, they are all within a few degrees of each other and when subjected to variations in mounting, real world loops, etc. all perform similarly well.
    Jan 2007
    where can you buy one?
    Quote Originally Posted by epion2985
    Ive looked online cant find where you could buy the G5 or G7.
    Jan 2007
    have you checked your motherboard
    Quote Originally Posted by CedricFP
    Oh man, and I just purchased an Apogee GT over a D-Tek Fusion
    I do take solace is the fact that it is apparent no clearn winner has emerged...
    Have you checked your mother board for bowing? The convex shape of my Fuzion block was enough to cause bowing with minimal pressure from the pressure bolts. The Apogee has a greater bow to the base then the Fuzion block does with the fatter O ring installed. See my pic here and check your motherboard.
    http://www.xtremesystems.org/forums/...=1#post1970470
    Jan 2007
    Base is convex
    Both the Apogee GT and DTEK Fuzion have convex bases. The Apogee GT comes shipped with flat base to start but if you want to make it convex for better temps you add the fatter O ring to bow the base. This bowing of the cpu water block bases is going to cause lots of bowing in the motherboards too! The water block companies should send out a back plate so the motherboard does not bow.
    Mar 2005
    Cologne, Germany
    Mounting variations has been criticized in the past, its not a new point. Some die-sims do take this issue seriously and (plan to) use or varying methods to minimize the effects, from centrally applied weights, 2 to designs with load cells measuring the force applied to the die.
    With "bowed" bases and bumpy IHS this issue plays a much bigger role. How do you measure the actual block performance when the mounting methods create a larger tolerance than internal design?
    Dec 2006
    Hopkins, Minnesota
    Iam surprised MCP-05 Pro is up there, yet seems like its the underdog since nobody talks about it anymore ever since GT and Fuzion is out. I wonder if the MCP-05 LE gets 1C or better temp?
    Intel Xeon E5645 95W @ 4.40GHz 1.28v || EVGA X58 3x SLI Classified 3 EK-FB || GeForce GTX 670 1250/3800 HEATKILLER GPU-X Ni-Bl || 24GB G.Skill DDR3 PC-2400
    Mountain Mods UFO2 || CPU Loop : MCP355 Koolance Top. XSPC AX360 || GPU/NB Loop : MCP355 Koolance Top, XSPC AX360 || Fans: 10x Scythe Gentle Typhoon AP-15
    Jun 2006
    Corinth, MS
    Considering the small tolerances that constitute the "best" components, I wouldn't worry too much. Personally I prefer the Apogee at the moment, because its cheaper and seems easier to get your hands on.
    Why is it drug addicts and computer afficionados are both called users?
    | AMD Phenom II X6 & Xigmatek Dark Knight
    | ASUS M4A89GTD PRO
    | Sapphire HD 5770 1GB
    | Mushkin BL 2 x 2GB
    | WD Caviar Black 1TB
    | Corsair TX650
    | Lian Li PC-K7 Black
    Feb 2003
    Greece
    Quote Originally Posted by Fairydust
    So you mean that you can't compare two waterblocks that have different mounting methods?
    Sorry but when i buy a block iam using it's own mounting kit and i want to know it's performance compared to another block with it's own mounting kit too.
    Now if one of the two blocks has better mounting method then for me the credits go to that waterblock or even the company that designed it.
    Jul 2006
    Vancouver, BC
    At least according to the test results I compiled above, even the same block, mounted using the same mechanism, mounted in the same way, by the same person, on the same system, did not even provide consistent performance from one mount to the next.
  18. #18
    Mar 2005
    Cologne, Germany
    If there was a mounting mechanism that consistently gave the same performance on different platforms of the same type I'd agree, even on the exact same platform it's a feat. Tests with a single mounts are luck of the draw.
  19. #19
    Jan 2007
    your right
    Quote Originally Posted by virtualrain
    I plan on mounting mine at least three times and see if I can get lower temps then now. The first mount that gives a lower temp then the one I have now Ill just keep. Im gonna wait a week in between mounts to let the ACS5 break in.
  20. #20
    Apr 2006
    Hong Kong
    Quote Originally Posted by redcorn
    I do plan on testing both bowed and flat bases, with several remounts. What I do need to do is find a backplate for the motherboard, for fear of bowing it too much and kaput.
    I'm rather happy with the performance results of the Apogee GT, particularly for the (rather cheap) price. I am hearing that a lot of retail GT's didn't come with the fatter gasket, though, and that is scaring me a little.
    Living in Hong Kong, for anything in America to get shipped here it can take at least 7 days... a real PITA when being forced to wait.
  21. #21
    May 2006
    Amen.
    Core2Duo E6600 @ 3.0 - Load @ 32c°| Gigabyte P35 DS3P | 2gb Crucial Ballistix Pc2-8500| eVGA 8800GTX| X-fi Fatal1ty | OCZ GameXStream 600w | Custom Watercooled | Custom-built Case
    Dtek Fuzion | DD Maze4 Acetal | Swiftech MCR-320 | DD D5
    3dMark01 3dMark05 3dMark06 Aq3 SuperPi
    Quote Originally Posted by Movieman View Post
    I don't beleive in passive cooling.
  22. #22
    Jan 2007
    i just got my apogee gt today, it looks good, some small pins in there, i wish it had a thiner base (3mm compared to fuzions 1.5mm)...it came with the extra oring, damn it took along time to put that oring in (took an hour, the dam thing is just too big for the groove) anyway...after puting it back togeter i could really notice a bow...the fuzion definly does not have nearly this much bow...i wonder if some more bow was induced into the fuzion if it would perform better,...im gonna run another set of tests:
    1. Apogee GT
    2. Apogee GT Bowed (nikhsub1, im a little worried to break my MB or CPU by moutintg this, anything i should no? i will be using the springs so im hoping that will help)
    3. Fuzion
    4. Fuzion with a nozzel ( i have made 2 diffrent ones)
  23. #23
    Feb 2006
    SoCal
    could you give us a little more info on the nozzles??
    peace
    ~~~Intel C2D 6600 (L29B) @ 3.2 - Asus P5W64 WS Pro - 2gig Team 667mhz (3-3-3-8) - eVGA 7900GT (580mhz x 800mhz) - X-Fi Fatal1ty - 150gig Raptor - 200gb WD hd - OCZ 700w GameXstream - Black Stacker 830 - Dell 24" 2407 A03 || X-fi > CI Audio VHP-1 > Grado HF-1 #90
    Petra's DDCT-01s on DDC-2 > MCR-220 w/ 2 coolinks > hardmounted Apogee GTX with backplate > BIP 1x120mm rad w/ scythe fan > MCW 60 + ramsinks > EK 150 multioption res containing Distilled water + pt nuke + cool-cases-usa uv orange dye || all connected with Tygon 7/16ID 11/16OD
    PROJECT LOG
  24. #24
    Jul 2006
    Vancouver, BC
    Quote Originally Posted by h20 frag-monger
    Check out Redcorn's solution... http://www.xtremesystems.org/forums/...d.php?t=131415
  25. #25
    Xtreme Mentor
    Sep 2004
    my pants
    That was sort of a joke. The G5 and G7 blocks are made by cathar, they are a refined version of the storm with a silver base that he never stops perfecting. Pretty much the best you can get and not cheap. However they are not for general public purchase. He only makes a batch when he has time and only for limited sale to limited people he chooses.
    Quote Originally Posted by Pete
    No its just a bigger o-ring. It causes the base to bow a little and seems to improve performance.
    French Duron Poof
    HEAT
