Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Thermalright HR-07 "Heatpipe Ram Cooler" Quick Review.
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    I like gadgets, I have fun trying new things, and its not often I get to really try a completly new type of hardware.
    a active heat pipe cooling system for ram, is definatly a new one for me.
    when I first heard about it, I was pretty excited by the idea of having more then a simple fan blowing over my ram, cause I have always believed in direct contact cooling, I am not much a fan of passive cooling in any real form, and for me, while a fan over my ram is better then nothing. its not much...
    so when I saw these, I was definatly curious.
    but more to my surprise, was how quickly it was showing up instock at various places around the net, and the price was definatly something I could live with, at $25 a piece and a few bucks for shipping.
    so I made my order with "the heatsink factory" and I am glad to say my first order there went well. no problems, and the item arrived in a few days.
    so here it is.
    the Thermalright HR-07.
    And the Heatsink itself.
    The Hardware You Get.
    And the Instructions.
ID:	54700   Click image for larger version.
ID:	54701   Click image for larger version.
ID:	54702   Click image for larger version.
    Nov 2002
    Juneau Alaska
    Mounting the Heatsinks.
    In total, mounting the heatsinks took me about a hour total.
    its definatly alittle harder then it seems and I will explain why later with the conclusion.
    The Hardware Used.
    This is my D9GMH. 2 Gigs of it.
    and this is how I personally chose to use the Thermal Pads.
    I didn't like how the pads were nearly twice as big as the D9 chips, which is why I cut them down to fit alittle better. Whether or not this is recommended, isnt mentioned in the instructions, and I still dont know if this was a good idea, but I did it anyways, cause I didn't want the thermal pads just "blanketed" over the ram chips.
    My First Problem.
    The Thermal Pad used, are pretty thin, and easily removable, which is a very good thing, should you deciede this item wasnt for you, or you wanted to remount it, or use a different cooling option.
    however, it also means, the thermal pads dont really "stick" into place all the time, which is what you can see in the pics here.
    see, the HR-07 slides onto the ram, and is held in place with tension.
    but while sliding the HR into place, the thermal pads might have a tendency to wanna move around too.... which you can see here.
    And a side view to show just how much it really slid off the ram chips.
    The bottom pad stayed in place just fine, but the top pad, slid quite far outta place.
    However, once I realized how easily these pads move around, I simply took alittle more time putting them on, and didnt try to rush through it, and then I got both heatsinks on both ram sticks with no trouble at all.
    so basically... dont rush this, do it right, and take your time and make sure the thermal pads didnt slide around as you were mounting the HR-07 and you will be fine.
ID:	54704   Click image for larger version.
ID:	54707   Click image for larger version.
ID:	54712   Click image for larger version.
    Nov 2002
    Juneau Alaska
    Installed.
    once the HR-07's are on the ram themself, it's actually quite tricky gettin the ram in place, and getting the fan mounted to the ram...
    see, theres something thats not really explained in the instructions...
    80mm fans are actually "small" for these heatsinks.
    a 93mm fan has a near perfect fit, as thats what the mounting brackets adjust to fit the best.
    getting a 80mm fan on there, took about 10 minutes of trial and error, and few times almost losing the screws too, while trying to line up holes, that are mounted on something that has a tendency to want to move around on its own...
    in my case, I chose my 80mm Tornado fan.
    I figured... my first time having a real cooling system for my ram... why bother with some boring quiet fan, I want results damn it.
    so 80mm tornado fan it is.
    its actually a pretty slick little system once its all mounted and solid in place.
    wish I had more room to show some other views, but I am tight on space as you can see.
ID:	54708   Click image for larger version.
    Nov 2002
    Juneau Alaska
    And Results.
    this D9 here, has always been a great set of ram.
    I can easily get it to cas 3-3-3 at 1 Ghz... when pushing 3 volts into it.
    but I find, this HR-07 probably isnt a good choice for something so extreme like that, and I will explain why in a moment.
    I've always tried to keep my ram at 2.3 volts or less for day to day speed.
    lately I been trying to get 1.1 ghz stable... however, with my P5B Deluxe here, the 4:5 ratio is the least stable ratio there is, and 1.1 ghz at 4:5 hasnt been easy to get stable yet.
    however, where the ram use to Error pretty fast at 1.1 ghz, with HR-07, I can now get 1.125 ghz stable, and up to 1.15 ghz unstable, but benchmarkable.
    remember, this is only 2.3 volts.
    I wanted something I could use for day to day speeds, not just suicide speeds.
    at 1.1+ ghz, I always used cas 5-4-4-10 or close.
    cas 5, seems to be the sweet spot for high mhz, and low voltage for my D9 and thats why most of my benchmarks tend to be cas 5 and not cas 4, for me, cas 4 takes about 2.5 volts when pushing above 1.1 ghz, and I only do that when I get into a serious benchmark session, which for this, this wasnt a "xtreme" session, just some testing.
    First Test.
    Hardware used.
    8 x 452 with the 4:5 ratio, Quad Core Xeon 3210.
    Mushkin PC6400.
    8800 GTX.
    2 x 150 gig raptors.
    400 gig slave.
    750 watt PC Power and Cooling Silencer 750 main PSU.
    250 watt Thermaltake VGA PSU on the GTX.
    Creative X-fi.
    P5B Deluxe, all mods, Bios 0910.
    108 Mhz PCIE speed.
    1.4 volt CPU.
    1.4 volt VFSB.
    1.45 chipset voltage.
    1.2 volt MCH.
    2.3 volt Ram.
    this is a personal favorite for quick stability testing.
    Test 5 of Memtest 86 tends to be rather unforgiving, and will always error at 98% if there is any errors.
    45 minutes of Test 5. No Errors at 1130 Mhz.
    Previously with no HR-07, 1100 mhz was the best.
    And a program that I been using for awhile now, Rightmark Memory Analyzer.
    it doesnt take too much time to run this default test, but this program has one thing I really like, being able to visually see exactly when and where errors happen.
    previously whenever I would try 1.1 ghz, I would get instant errors... or "little red boxs" when in windows, unless I boosted the voltage to 2.45 volts... which I really didnt want to have to do for a daily speed.
    with the HR-07, I am able to not only pass 1.1 ghz stable, I am able to be able to use 2.3 volts to do it, which definatly falls in my "comfort zone" for voltage on a daily basis.
    1.130 ghz stable, no errors, and passes the whole default test.
    so all in all, this seems to have been a very solid little product.
    but the real test, for me, came in my gaming last night.
    in the past, whenever I tried to get 1.125 ghz stable for gaming, I would get violent crashes happening in oblivion, where my speakers would just go nuts making a crazy high pitch sound then the game would freeze.
    and in Titan Quest, I would constantly get game crashes after a few minutes of game play.
    basically, unless I boosted the voltage past 2.4 volts, I wasnt gonna get 1.125 or 1.13 ghz stable for my gaming, and for me, I just dont want to run 2.4 volts on a daily basis.
    well, I am glad to say, last night I played Titan Quest for the First time, at 1.125 Ghz, at 2.3 volts... for about 4-5 hours... and not a single crash/error or freeze happend.
    so I am definatly Happy with the HR-07 so far.
ID:	54710   Click image for larger version.
    Nov 2002
    Juneau Alaska
    Conclusion.
    The HR-07 isn't without its faults.
    it's time consuming to install, and can be alittle tiresome trying to get a fan hooked to it once installed on the board.
    I definatly dont like that the entire thing is held in place, by tension alone.
    it definatly would have been better to have some sort of way to make a more solid "fit" onto the ram, by some sort of screw or something.
    the fact that it uses tension to be mounted into place, might make it easy to forget that the heatsink isnt solidly mounted onto the ram, so if you should be one day removing the ram, you might just pull off the heatsink instead.... I can see that happening to someone sometime.
    and theres one observation I think I need to mention.
    while I had great luck with my overclock at 2.5 volts, and less.
    I had a sharp fall in OC's when I went above 2.7 volts....
    basically, I dont think this thing is suited for extreme overclocking, if your running alot of voltage through your ram, cause this thing seemed to actually make things worse, then better.
    it would seem theres a limit on where it begins to lose effectiveness, and it seems to be once you begin passing 2.65 volts, the HR-07 just can't cool things fast enough to really help and actually began holding me back.
    however, this is a small thing, as I doubt anyones gonna be looking to run 2.7+ volts into thier ram on a daily basis.
    so for average to high end daily overclockers, this is definatly a tool worth looking into.
    if you were hoping to use this for some 3.0+ volt overclocking, this is not the tool for you, as it seems to lose effectiveness quickly at that kinda voltage.
    so think about that, and what kinda uses you have for your ram.
    in my case, I will gladly settle for 2.3 volts and 1.125 Ghz thats game stable.
    and like I said earlier, this thing would be rather easy to remove... so if I ever get the urge to do some high voltage overclocking again, I can always remove this heatsink rather easily.
    Overall, I'd give this item a 8 outta 10.
    great little item for daily use, and definatly does a good job cooling and ram, and the price isn't bad at all.
    -Kunaak-
    The Blue Dolphin
    Nov 2004
    The Netherlands
    Nicely reviewed
    Can you measure temperatures or don't you have a thermometer at hand?
    The conclusion is pretty much as I expected to be honest. The heatpipes don't stretch far enough to the right in the 2nd picture, which is really nasty for that last 2 ICs. Also the bond between the heatpipes and base doesn't seem very good. And the base is pretty thin while the chips are relatively large compared to the heatpipes. And then you also have those pads (with crappy performance compared to TIM) and difficult installation.
    Again I say heatpipes are overrated. They are only good when you need to transfer large amount of heat from a very tiny surface, like a CPU core. When a heatpipe isn't necessary it only adds to the deltaT between the air and chip.
    Geek factor: 5/5
    Performance: 2.5/5
    Blue Dolphin Reviews & Guides
    Blue Reviews:
    Gigabyte G-Power PRO CPU cooler
    Vantec Nexstar 3.5" external HDD enclosure
    Gigabyte Poseidon 310 case
    Blue Guides:
    Fixing a GFX BIOS checksum yourself
    98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
    Dec 2006
    Quote Originally Posted by alexio
    Nicely reviewed
    Geek factor: 5/5
    QFT
    Banned
    Jun 2006
    Durham, NC
    I'll stick with a fan.
    Sep 2006
    Nicely reviewed
    Ditto.
    I would really like to see how this compares to Hipro5's work: http://www.xtremesystems.org/forums/...8&postcount=55
    Aug 2006
    London UK
    So in order to enjoy a big leap like you do, people would need to stick some crazy spinning 80mm fan like a Tornado on it?
    That's where reviews are misleading sometimes, you could have used a normal 2000rpm 25-30dBa first and see how your Ram's stability improves. Then move onto the xtreme part, which is obviously this forum's signature.
    But at consumer level, who would want to game with a storm roaring inside their case? I myself as hell would love to run it a few Mhz less but acceptably audible, not deafening.
    Just a heads up, but I'm glad you as a reviewer liked it, any chance of updating with some Passive and Low-spinning fan tests?
    E6300 / P5B-E+ / 2x1GB Crucial Anny / X1950XT / Xfi XM / 2x320GB 7200.10/ PCP&C 510SLi / Dell 2007WFP
    Achieved:
    4Ghz E6300 on air - 115% OC
    666Mhz 5-5-5 2.45v
    Nov 2002
    Juneau Alaska
    haha...
    I dont use the tornado at max speed for daily use.
    I dont like tornado fans anymore then others do.
    they are a short term solution for when I want the best chance at a high OC.
    Admin
    Feb 2005
    Ann Arbor, MI
    Kunaak, any possibility of testing this in a low airflow environment? See how much it gains there....
    Jan 2006
    Gotham City, Sweden
    Quote Originally Posted by Vapor
    The High riser series have lots of space between the fins and are thus made for low air flow. The Hr-01 is even better than the Ninja at ultra low air flow. And the fins are short so it won't take much pressure to move air through them.
    AMD Phenom II 940BE | DFI LP DK790B-M2RS | Echo audio Layla 3G | 8GB Corsair C5 PC6400 | Sapphire HD3870 with HR-03+ | Genelec 8030A | Samsung 244T | Antec P182 gun metal | Thermal right Ultra120 | UPS: APC BACK-UPS RS 1500VA | Windows Vista Ultimate 64 | DAW: Ableton/Sonar | WAN: 100/10Mbit/s | OS on: WD Velocioraptor Storage: Rocket Raid 2300 PCI-E + 4*400GB Samsung T133 @Raid5. Firewall: Tyan Tomcat 945GM | Core Duo T2600 | 2*512MB ram | Nexus PM PSM-5000 | Picu PSU.
    "People who enjoy waving flags
    don't deserve to have one".
    Oct 2004
    Germany
    Nice review Kunaak
    And Thermaltake copycat too
    Memory Addict
    Aug 2002
    Brisbane, Australia
    nice.. next revision ....what about replacing TIM pad with dabs of ceramique and screw through or clips to hold heatsink contact to modules ?? heh
    Sep 2005
    Cool !~~~.. and I know there is an link show this Cooling
    http://www.anandtech.com/tradeshows/...spx?i=2908&p=3
    ha ha .
    I am Xtreme
    Dec 2002
    Quote Originally Posted by eva2000
    this is a good point... i bet they would handle voltage ALOT better if contact was better. as the volts increase i bet you are reaching the thermal pads heat transfer limit.
  18. #18
    Jul 2006
    Washington State
    Is there any spot where you could actually screw threw for a more firm fitting?
    You could possibly use the same clips that come with aftermarket heat spreaders along with AS5 or Ceramique. I couldnt imagine using any kind of thermal adhesive on these.
    Could you try them with more pressure and better TIM?
    Phenom 9950BE @ 3.24Ghz| ASUS M3A78-T | ASUS 4870 | 4gb G.SKILL DDR2-1000 |Silverstone Strider 600w ST60F| XFI Xtremegamer | Seagate 7200.10 320gb | Maxtor 200gb 7200rpm 16mb | Samsung 206BW | MCP655 | MCR320 | Apogee | MCW60 | MM U2-UFO |
    A64 3800+ X2 AM2 @3.2Ghz| Biostar TF560 A2+ | 2gb Crucial Ballistix DDR2-800 | Sapphire 3870 512mb | Aircooled inside a White MM-UFO Horizon |
    Current Phenom overclock
    Max Phenom overclock
  19. #19
    Xtreme X.I.P.
    Aug 2004
    Chile
    i dont like them because:
    there is a big chance that when someone is removing factory heatspreaders they damage their ram. That isnt covered on your review and might be usefull to mention.
  20. #20
    Xtreme Cruncher
    Dec 2006
    Texas
    Quote Originally Posted by Blknoel View Post
    This is why I have loud speakers. Seriously though, I had an 80mm delta that will make you go crazy. High pitched whining all the time.....
    I'd like to see them with a 50cfm 92mm fan on there. That and with the pressure mods others suggested. Seems like pressure would make these babies shine
  21. #21
    Nov 2002
    Juneau Alaska
    Quote Originally Posted by metro.cl View Post
    dont you think thats kinda obvious to people around here?
    plus, theres tons of other ram products that require removal of heatspreaders... do you put all them products down too?
  22. #22
    May 2006
    Canada
    Yea i agree that it seems like the thermal pads are limiting the cooling.
    From my experience thermal pads have horrible heat transfer.
    Would be neat if you could cut the heat spreaders into two parts then just put a clamp over it or something so you could have the best contact.
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
  23. #23
    Xtreme 3DTeam Member
    Jul 2003
    Mason, MI... USA
    Kunaak great review! I really like your (well)formed opinion pushing this device. You really went above and beyond for a user such as myself which never likely would touch something like this with a 10 foot pole. You've defined a threshold it works well to which is beyond (i hope) most folks are willing to push their gear to. I liked it alot :P
    GA-P35-DS3L no more than 450fsb w/1333 chip
    E6550 stuck at 3150
    V-DATA 2x1gb
    MSI 7900GS 512 3Dmark score in near future
    Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
  24. #24
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    They look good and I would buy them IF the "body" of them was made by cooper and not aluminum so to absorve the temp faster.....
    INTEL PWA FOR EVER
    Dr. Who my arss...
  25. #25
    Oct 2006
    I have them and am happy so far at 2.6v.
    Rig #1
    DFI UTNF4 SLI Dr Expert (Bios 04/06)
    AMD64 3500+ @2.8
    G.Skill F1-4000B1U2 2GB (3-3-3-7 1T @2.7v)
    2 Enermax Liberty 620w PSU's
    Leadtek PX7800GT (2 SLI )
    Rig #2
    DFI LPUT NF590 SLI M2R/G
    Amd64 X2-6000+
    G.Skill F@-6400PHU2-2GBHZ (4-4-4-12)
    Asus EN8800 GTX
    Zippy 850w
