Page 1 of 7 1234 ... LastLast
Results 1 to 25 of 154
Thread: New news about ATI R600
    Aug 2006
    The Netherlands, Friesland
    New newz about ATI R600
    http://level505.com/2006/12/30/the-f...i-r600-test/1/
    My first Thread, hope i didn't post in the wrong section.
    The R600 Specs are:
    * 64 4-Way SIMD Unified Shaders, 128 Shader Operations/Cycle
    * 32 TMUs, 16 ROPs
    * 512 bit Memory Controller, full 32 bit per chip connection
    * GDDR3 at 900 MHz clock speed (January)
    * GDDR4 at 1.1 GHz clock speed (March, revised edition)
    * Total bandwidth 115 GB/s on GDDR3
    * Total bandwidth 140 GB/s on GDDR4
    * Consumer memory support 1024 MB
    * DX10 full compatibility with draft DX10.1 vendor-specific cap removal (unified programming)
    * 32FP internal processing
    * Hardware support for GPU clustering (any x^2 number, not limited to Dual or Quad-GPU)
    * Hardware DVI-HDCP support (High Definition Copy Protocol)
    * Hardware Quad-DVI output support (Limited to workstation editions)
    * 230W TDP PCI-SIG compliant
    I Hope this is reliable information, if this information is correct, then R600 will be a great videocard
    >i5-3570K
    >Asrock Z77E-ITX Wifi
    >Asus GTX 670 Mini
    >Cooltek Coolcube Black
    >CM Silent Pro M700
    >Crucial M4 128Gb Msata
    >Cooler Master Seidon 120M
    Hell yes its a mini-ITX gaming rig!
    Nov 2004
    Fairfield, Connecticut
    Looks like a decent performer indeed. Thanks for the info.
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    results don't look out of this world either.
    Nov 2005
    The Netherlands
    230W TDP on a graphics card?
    Apr 2005
    Manchester, UK
    Quote Originally Posted by lowfat
    Agreed. I was expecting better, though these probably aren't accurate.
    i7-960@4.2GHz/Rampage III Gene/3GB KHX14400/HD5670
    Nov 2006
    UK - Skirts of London
    Looks good in places, but not mind blowing. My question would be what is the core clock on the card, and what is the r600 like under overclocking. 8800GTX's are exactly shaby under normal air and normal volts!
    - Paul
    Okay looking further anno shows a big difference. wonderhow much their is left in driver optimisation as well
    May 2005
    There's something very odd with their numbers for the 8800GTX...
    1.) CF x1950xtx at 1600x1200 doesn't speed past the 8800GTX that much. ~10 fps, but damn well not 20. Mind you, the test you've shown us runs a faster processor than the link I'll post, so the framerate should've gone up if anything for the 8800GTX, not down.
    http://www.anandtech.com/video/showdoc.aspx?i=2870&p=22
    2.) Oblivion runs MUCH faster than those numbers at 1600x1200 with 4xAA than 19 fps on the 8800gtx.
    http://www.vr-zone.com/index.php?i=4216&s=22
    There's other weird ones(3dmark05 is rather suspect, as at stock with a slower proc I've scored about 1k higher with 8xAA), but I'll give them the benefit of the doubt.
    Quote Originally Posted by Leon2ky
    "dammit kyle what's with the 30 second sex lately?" "Sorry sweetie, I overclocked my nuts and they haven't been stable since"
    Quote Originally Posted by trinibwoy View Post
    I don't think his backside has internet access.
    Quote Originally Posted by n00b 0f l337 View Post
    Hey I just met you
    And this is crazy
    But I'm on bath salts
    And your face looks tasty
    Apr 2006
    Texas
    Shens?
    No pics of the card.
    Site was made 2 days ago.
    Strange results sometimes.
    Still, it might be legit. Some people have some crazy early access to things.
    Jan 2006
    this aint exactly anandtech, so these results are just indicative of that the r600 is a true competitor against g80. i would hope that the results would be better with a mature driver, as nvidia will probably have an answer to r600, and if the r600 is only marginally faster, with some results questionable as well, i dont like ati's prospects. yet to see dx10 performance though, so that should be interesting.
    Core i7 920 3849B028 4.2ghz cooled by ek hf | 6gb stt ddr3 2100 | MSI HD6950 cf cooled by ek fc | Evga x58 e760 Classified | 120gb G.Skill Phoenix Pro | Modded Rocketfish case + 1200w toughpower | mcp 655 pump + mcr 320 + black ice pro II
    May 2005
    Thought I'd point this out guys...
    Support for DX10.1 draft?
    We all know this by now, but incase you don't let me give you a refresher course. Microsoft stated you either 100% match DX10 specifications(this includes all updates) or your card is marked by dx as not compatible... This means ATi is banking on what they expect to be DX10.1 to actually be it to a T.
    Hey I just met you
    And this is crazy
    Xtreme Mentor
    Nov 2005
    Devon
    Quote Originally Posted by SpikeP
    - Paul
    From simple calculation clock speed seems to be 820MHz .
    missing data for evaluation of clock speed:
    Processing Power:
    * 105,000,000,000 SOps (Shader Operations Per Second)
    * 2,000,000,000 TCps (Triangle Calculations Per Second)
    * 28 GTps (Gigatexels Per Second)
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    May 2004
    because it´s only a small difference in speed and the upcoming version may be more expensive...
    You can always wait two month and get a faster video card then if it´s not ATI that has it out it´s nvidia
    Coolermaster Stacker
    Silverstone 850 zeus
    Core 2 duo E6600
    Asus Commando
    2x1 gb team xtreme
    Leadtek 8800 GTX
    X-Fi ELITE PRO
    2X WD Raptors
    2x WD 500 KS
    Laing DDC 2 pump with petra tech top
    12 mm tubing
    Apogee and MCW60
    Microres reservoir
    MCR330 triple rad and radbox.
    Apr 2006
    R600 is better than these benches.
    ASUS P5B-D WiFi
    e6600 @ 3.40GHz
    Corsair DDR2-800 2x1GB
    Sapphire ATI X1900XTX
    Scythe Infinity w/ FCG's mod
    1 74GB WD Raptor HDD
    2 x 250GB Samsung SP2504C HDD
    OCZ 700W GameXtream PSU
    Thermaltake Armor w/ side fan
    Soon to be retired.
    XS News
    Aug 2004
    Sweden
    They created a new site just to show this ?
    Hmm..
    Jan 2006
    i guess its a bigger site that didnt want to get into hot water with ati...
    Ebay Hater
    Aug 2004
    Denmark / UK
    Hmm, if this is legit, then we have to keep in mind that ATI has a tendency for less than polished drivers at launch
    edit. though, if it isn't legit, which is the opinion I'm leaning towards, it's a pretty good money making idea, with the sheer amount of google ads
    In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
    XS News
    Aug 2004
    Sweden
    Anyone know when we get some DX10 benchmark programs ?
  18. #18
    May 2005
    Quote Originally Posted by PallMall
    The januari edition is a rippoff in my eyes.
    Why buy that card for nearly 550$
    When they offer a better card after only 2months omg.
    $550?... Try $630 for the card in january.
    Quote Originally Posted by perry_78
    Bare in mind the 8800GTX driver is pretty much an infant itself, anything but polished, and definitely not anywhere close to it's top performance.
    I'd say we have ourselves, for the first time in a long time, a REAL fight on our hands. IQ wise(if this review is real), performance wise, and feature wise both camps have a real beast on their hands.
    On a side note though, people who already bought a 8800GTX need not feel buyers remorse.
    Hey I just met you
    And this is crazy
  19. #19
    Aug 2006
    If i look at the WHOIS output i have the idea the owner wants his privacy, probably because voiding his NDA contract or so.
    >i5-3570K
    >Asus GTX 670 Mini
    >CM Silent Pro M700
  20. #20
    Apr 2006
    Quote Originally Posted by ownage
    The owner better, or I fear for him.
    ASUS P5B-D WiFi
    e6600 @ 3.40GHz
    Soon to be retired.
  21. #21
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    Stop complaining about the price
    Its kinda reassuring that the graphs dont show a clean-sweep for the `600...if they`re willing to admit the 8800GTX wins some and comes close in some tests, adds come credability?
    you sigged that?
    why?
    ______
  22. #22
    Apr 2004
    This article is bogus.
    DFI LANParty DK 790FX-B
    Phenom II X4 955 BE (1003GPMW) @ 3.8GHz (19x200) w/1.36v
    -cooling: Scythe Mugen 2 + AC MX-2
    XFX ATI Radeon HD 5870 1024MB
    8GB PC2-6400 G.Skill @ 800MHz (1:2) 5-5-5-15 w/1.8v
    Seagate 1TB 7200.11 Barracuda
    Corsair HX620W
    Support PC gaming. Don't pirate games.
  23. #23
    Ebay Hater
    Aug 2004
    Denmark / UK
    Quote Originally Posted by Cybercat
    strong words!
    Either way, opinions are but speculation
  24. #24
    Jul 2006
    Between Sky and Earth
    Now that's something new - DX10 whit Full support at release and DX10.1 latter, by 2008 will see even DX10.3 on this cards, I used to wonder why wasn't this possible before - guess now it's a thing of the past.
  25. #25
    Xtreme Gaming News
    Jul 2006
    Ohio
    Yeah maybe if this came from a real website I would believe it......... Some 13 year old kid ion his basement probably made this. The writing in the article is terrible.
    I'm back....
