sorry, noob here but i did say feels like....just that its my first time removing the onboard hs's and its my 2nd board after getting the first replaced due to the buzzing sound..so trying to avoid the hassle of a 3rd.
today i flashed the new 0803 bios, it is a little bit better for oc as 0801.
now my e6400 run with 1.30v @ 3.6Ghz
Chri$ch Where can we download the 0803 BIOS ? I can't seem to find it anywhere,it's not on Asus's site or FTP's .
Asus P6T Deluxe, Core i7 920 @ 4.1ghz, Corsair Dominator Tri channel 1600Mhz
Evga GTX285, Raptor 150GB, Corsair HX620
Apogee GTZ, PA 120.3, CM Stacker STC-01, DDC 3.1 MCP355/XSPC top.
Win Vista Premium X64
Could somwone who knows both boards give me an opinion. Which is better?
-P5N32-E SLI
-Commando
Unless u're not running async mem dividers, 965 @ high fsb doesn't need much vmch.Originally Posted by MrDeeds
That's the case with my P5B-Deluxe also.
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
you must flash it in Dos with AFUDOS or Asus EZ Flash (not with Asus-Update)!!!Originally Posted by Nanobot
Commando 0803 download
flashing on your own risk!
Thanks man.
Hey guys, I bought some silicone in a tube (I presume this is what is referred to liquid silicone) and I am about to apply it to that coil thing that is making the buzzing/squealing sound.
I have a question, though, how should I wait before using the machine again? On the tube it says that it stops being sticky after 1 hour and it "hardens" all the way through in 2-5 days. So, do I have to wait 1 hour, 2-5 days or 10 minutes?
Same shiznit happened with me as well but...I got my friend the same board for helping me around my shop and his Drivers CD DOES WORK.If anyone needs a copy let me know.I would prefer to make an image and then just send it to someones FTP and get it distibuted out to all who need it that way.Anyone with an FTP willing to help me share this drivers disk?Let me knowOriginally Posted by BLHealthy4life
I would wait a few hours anyway but not necessary to wait days.Originally Posted by Bludd
Main Rig;
Asus Rampage II Ex, i7 920DO @ 3.64, 12 Gb Corsair Dominator DDRIII, Corsair H-70, Corsair 1 KW PSU, 2 ea EVGA 580's in SLI driving 3 Samsung 245t's at 5760 X 1200 surround, Boot drive Corsair Vertex II SSD, Programs 2 V- Raptors in RAID 0 and a WD 1 Tb RE3 for files and client data. Sound, ASUS Xonar D2X, Normal optical drives Etc. Win 7 Ult.
Does anyone know if 4:5 works at high fsb (500+) on this board? thinking about getting one for some 3060 xeon on DIce action.
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
Originally Posted by afireinside
I never tried quite that high, but 450 4:5 was easy to achieve straight boot to windows and didn't need much work if that helps at all. The voltages could more than likely be set much lower than in this screeny too.
Q6600 G0 L720B058 @ 3.8GHz | Asus Maximus Formula (Rampage 0403 Modded) | 4x2Gb GSkill PC8000 PQ @ 1015MHz | XFX 9800GX2 XXX @ 680/2080 | 2 x WD Raptors RAID0 | 1 x WD5000KS | Samsung S203B DVDR/W | Samsung SM245B + Panasonic TX37LZD80
D-Tek Fuzion | PA120.3 + Shroud + Nexus Fans | MCW30 | Laing DDC w/ Petra's DDCT-01s Top Combo | Tygon 1/2" Tubing | T-Line
thanks for the download Chri$ch is there a change log with it ??, is it a beta
cheers mate
need help,
Core 2 Duo x6800
Asus Commando
Corsair Dominator 8500
Vcore = auto
Fsb = 1.5
NB = 1.5
Mem = 2.2
SB vcore = 1.6
SB chipset = 1.12
i can't reach 3.3Ghz above, my pc won't boot, any suggestions?
my goal is 4.0Ghz
thank you very much !!
This is not a soldering issue, the Vmch and Vdimm coils are not tightened/glued correctly, that's all. I agree the RoHS solder is inferior from many aspects, but this has nothing to do with soldering but with the low quality of those two coils.Originally Posted by Baer
Originally Posted by Anhydrous
You have a PM about getting a CD made and shipped to me...
BL
guys, how much % of the CPU is used for processing the sound on commando?
it would be useful to buy an x-fi?
Originally Posted by -Sweeper_
yup curios to find out too, n why doesnt this board support dolby digital, anyway neweggs having an offer on the x-meridian.
Is easyflash only for old OS? like Win98 Says does not support NTFS.
intel i5 2500k
Asus P8Z68-V
EVGA GTX470
Corsair 8GB Vengence
Corsair HX1000W psu ,
High Speed Tech Station Top Deck,
Dell U2410
You do not need to apologize some of these guys are just sOriginally Posted by cablesguy
intel i5 2500k
Asus P8Z68-V
EVGA GTX470
Dell U2410
I think I can mange to send that to you this weekOriginally Posted by BLHealthy4life
Let me get my taxes done tomorrow and then I can ship it to you man
I didn't read whole thread but is there any vdroop mod for that mobo?
regards
My Work: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LNē Pots, LD GFX-R1 Dice/LNē Pots,
LittleDevil LD PC-V10, LittleDevil's K-Type Temp Display, |EMAIL: ldphasechange@gmail.com
LD PC-V8 Watercooling Cases: LINK
LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots: LINK NEW!
www.ldcooling.com
Find US on Facebook
Originally Posted by LittleDevil
- Team Skootterit
- SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
I don't know how much further it would go, that run was just part of a battery of tests I was running at 3.6GHz and like I say it didn't need any special treatment to get there. I've been meaning to get round to checking just how far it can go, but something always comes up and I get sidetrackedOriginally Posted by Revv23
