The first thing I wanted to bring to everyone's attention is this excerpt from a chemistry professor on the cleaning (de-oxidizing) copper. Vinegar by itself is surprisingly not that effective of a cleaner. However, vinegar and salt (acetic acid and sodium chloride) is highly effective for the following reason.
"In water, under any conditions, salt breaks down into sodium ions and chloride ions. (Even in the solid, it is in that form, so it would be better to say that the water just allows the ions to separate.)
It's a little more complicated than that. The copper in the tarnish would be in the 2+ form. Chloride ions do not bond strongly to this form. However, they do bond fairly strongly to the 1+ form. A reaction that would be unfavorable in the absence of chloride ions, Cu + Cu2+ *--> 2Cu1+, becomes favorable when the chloride is present to tie up the Cu1+ form (as [CuCl2]-).
The first process can be viewed as transfer of an electron from Cu (metallic copper) to Cu2+. This is followed by reaction of the Cu1+ with the chloride. The resulting copper-chloride complex is soluble in water. It's the electron-transfer aspect of the chemistry (the conversion of metallic copper and the Cu2+, to Cu1+) that makes the role of the salt a little surprising."
You can test this for yourself using 1 cent US pennies or 5 cent Euro coins like I did. The salt makes the cleaning process highly effective. A copper coin placed in this solution is cleaned almost instantly.
Edit: I took out what I said about the galvanic corrosion, because the metal plating is nickel, not zinc. But really, assuming you keep contaminates out of the loop, even the worst metals should be okay in just distilled water because of its almost nonexistent conductivity. Not sure how anti-algea stuff plays into it though.
