Page 1 of 3 123 LastLast
Results 1 to 25 of 63
Thread: eVGA Nforce 680i SLI Mainboard on Vapochill LS
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Machine specs
    Asetek Vapochill LS R507 Modded -50 in bios
    Intel 6300 Retail
    Intel X6800 ES
    Intel QX6700 ES
    Nvidia Nforce 680i SLI mainboard
    Nvidia 8800GTX Stock heat sink
    Corsair Dominator 9136 C5D
    4x Western Digital 150GB Raptors 10K RPM
    I-ram OCZ 4GB
    Installing
    There is plenty of clearance for aftermarket coolers that mount from topside, I installed a Asetek Vapochill LS that is capable of more than -50c with current modifications. The gasket fits nicely on the top side, the Vapochill head clears all parts no problem at all. No changes were made for clearance on the front side.
    On the back side there are a few surface mounted parts, they are low profile so you will need extra foam insulation so there is no contact with the metal back plate of the Vapochill. I can see other aftermarket coolers that require the back plate also having problems with those surface parts. Normal clearing of metal pins is needed to prevent shorting out.
    All three PCIE slots have full board clearance for video cards, all connectors are up next to the ram slots with the exception to the USB pin header next to the battery. There is also a serial pin header at the edge of the board. I did not install this option.
    I installed the Iram in the lower PCI slot, no clearance problem with bottom of case. I connected the I-ram to SATA port one and the raid drives to SATA ports three four five and six. I also connected a Seagate 7200.9 for single drive tests.
    The board does get hot around the chipset and PCIE slot so dont skip the optional chipset fan, it is needed.
    BIOS
    Lots of bios shots can be found around the net so I will skip those and give some settings that I use instead.
    The bios is geared for the overclocker and has plenty of options to overclock every aspect of the board. The droop is pretty bad from our standards. At 1.70v set in bios it will ride between 1.61v and 1.64v I was able to get all benches done with a max of 1.70 set in bios even though the max setting in bios was 1.8v. I wanted to keep benches consistant to compare against the Abit AW9D-Max I ran at 4.2Ghz.
    The bios reads beyond -50c but in windows it reads error.
    Linkboost is enabled when it detects an Nvidia video card and it will bring the clock speed of the PCIE to 125Mhz.
    QX6700 I left the FSB at stock 1066Mhz and all the voltages stock with the exception of the vcore and vmem, the 6300 and the X6800 I cranked up the voltages a bit to reach a healthy 530FSB, I did quite a few 3D benches on the X6800 at 520FSB.
    Vcore set to 1.70v
    Vmem set to 2.50v
    FSBV set for 6300 set to 1.4v
    FSBV set for X6800 set to 1.5v
    MCPV set to 1.50v
    SPPV set to 1.50v
    There are quite a few FSB holes between 1066 and 2090, it seems the HT bus is locked in ratios. To best explain it at 1690Mhz bus speed I will lose PCIE and it will boot in VGA mode, at 1700 it will start to caugh up HD errors in windows. Once you get to 1710 all is fine again till the next hole.
    When a failed overclock happens the bios will reset itself to the default FSB speed to let you fix the problem. No need to use the cmos reset jumper. Worst possible case is where you push too far without enough vcore and it will display -- on the post LED diagnostic built into the mainboard. If this happens a cycle of power is needed to get proper reset.
    All bios options are nicely labeled with clearer detail to what functions they do.
    RAID
    It does not matter what SATA connector you plug the raid drives into but you will need to enable that port in bios for raid. You can set each port individualy and run non-rain drives on the same controller. It is possible to scramble the raid with bad memory timing.
    Here is a screen shot of the storage control panel
    Drivers
    Drivers seem solid for the motherboard, everything is working as expected with the exception of an audio glitch where playback is fed back into mic. So if you were in a chat program the other parties would hear anything playing on your PC speakers. In games it will hold the audio channel open and annoy. The mic record quality and volume is superb.
    Overclocking tools
    Ntune is the main program used to overclock the motherboard and it can also be used to overclock the Nvidia GPU as well. Nvidia has gone the extra mile to label the options in bios as well as in Ntune.
    You have PLL access as well as voltages on this screen.
    Here is what the GPU screen looks like.
    Dynamic Bios access screen.
    Tune system screen.
    View system information. Notice the Corsair Dominator 9136 Memory
    available
    Stability control panel.
    Memory timing
    In bios there is quite a few timing settings and I was very surprised that this memory will do very tight timing of 2-2-2-2 timing at stock 266FSB speed in sync mode DDR speed of 533Mhz. I had no problems running 3-2-2-x, 3-3-2-x, 3-2-3-x as well. This memory was very flexable compared to other DDR2 I have tested. The motherboard booted!!
    I will post more tight timing stuff with 3D results.
    Ok, onto the good stuff.
    This is the oddball screen shot with the Retail E6300 processor. I was dialing it in on air to get this bandwidth. this was sync 3-2-2-4 1T. I dont trust Ultimate too much but it is an impressive score. I setup the hard drive and stuff with this processor and then switched the motherboard over to Vapochill and X6800 processor.
    Here is the X6800 at 524FSB CPUID screen shot w/validation
    http://valid.x86-secret.com/show_oc?id=136435
    I managed a 4.5Ghz screen shot with validation from the X6800 but I was not able to get benches off at this speed.
    http://valid.x86-secret.com/show_oc?id=136439
    Here is the Kentsfield at 4.2Ghz validation
    http://valid.x86-secret.com/show_oc?id=136436
    My results are overclocked and not to everyones stability standards. At 4.2Ghz on both processors I am 24/7 stable and benched at or around that speed for these tests. The kentsfield processor had problems at high bus speeds, near stock were used.
    Super Pi 1.5 XS
    Cinebench
    Crystalmark
    Nbench
    Everest Home with low FSB
    Sandra 2007 X6800
    Sandra 2007 QX6800
    Single Seagate 7200.9 160GB
    RAID 0 Raptor 150's
    HDTach
    RAID 0 Raptor 150's
    I-Ram
    Many thanks to Nvidia for the editors day invite and toys to go home with. It has been most enjoyable. 8800GTX 3D benches will be up later today.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Jun 2002
    Las Vegas
    I just got in a new bios that might resolve the FSB problem with my Kentsfield, the chip will not boot into windows above 300 if not I would need to switch back to the X6800 for high FSB.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Xtreme X.I.P.
    Aug 2002
    Thanks for the review Charles.
    The FSB speed is like chalk and cheese when compared to 590.
    How does the chipset compare to 975 clock for clock ..is it speedy?
    Regards
    Andy
    Xtreme Legend
    Jun 2005
    Taipei, Taiwan
    mwave 259 USD
    Sep 2006
    Denmark
    I have been looking forward for your review FUGGER. Looks great, thanks.
    Is the RAID 0 performance on the 680i chipset really so much worse than the one provided by Intel Matrix RAID. I saw fhpchris post som crazy RAID results in this thread: http://www.xtremesystems.org/forums/...i+overclocking.
    Do you know if there is a significant difference in the performance of the eVGA 680i and the Nvidia reference board (as far as I understand this should not be the case). This "official" review http://www.xbitlabs.com/articles/chi...80i-sli_2.html is not particularly in favour of the 680i chipset as compared to the 975/965 with respect to performance and overclockability (it must be noted that the guys at Xbit labs IMHO are not the most skillfull - at least compared to people like you from Xs).
    CPU: QX9650 @4.25.
    MB: Asus P5E64 WS Evolution (BIOS 0702).
    WC: Swiftech GTZ, XSPC X20 Delta, EK FC4870X2 CF, 2x Laing DDC 18W w. XSPC Top, HW-labs GTS 360 Xflow, Swiftech MCR120-RES.
    HDD: Intel X25-M 160 G2 + Mtron Mobi 32 GB SSD + 2x 1 TB Samsung Spinpoint F1.
    GFX: Club3D 4870X2 @790/915 (Asus TOP).
    RAM: 2x2 GB Corsair TW3X4G1800C8DF G (8-7-7-18-1T-PL6 @1700 MHz).
    PSU: Corsair HX1000W.
    Case: Coolermaster Cosmos S.
    Speakers: Logitech Z-5500 digital 5.1.
    Soundcard: Auzen X-Fi Prelude 7.1.
    DVD: Samsung Super Writemaster SATA DVD burner.
    LCD: Dell U2410.
    OS: Windows 7 Ultimate 64.
    Jan 2005
    Texas
    Could it be? An Nforce board for intel that doensnt COMPLETELY suck asses?
    COOL!
    "Roses are FF0000, Violets are 0000FF, All my base are belong to you."
    Asus P6X58D-E
    I7 930 @ 3.9
    Asus 660ti DirectCU OC
    Antec Twelve-Hundred
    Xtreme Cruncher
    Jul 2006
    any word if the new bios has fixed kentsfield FSB support. If it is still low seems like that is the only problem with the board.
    Oct 2006
    England
    Quote Originally Posted by Yoxxy
    I would also like to know
    Jun 2006
    Belgium - Brussel
    Nice review
    Oct 2006
    Argentina
    man you are crazy... Congrats!!
    Feb 2006
    The Netherlands - Rotterdam
    wow, thats nice! Would like to see this baby modded and hitting higher fsb.
    thanks for the info fugger
    Jul 2006
    Netherlands
    raid performance:
    my p5w dh has a sequential read of around 130Mb/s and a burst of 240Mb/s with 4x raptor 74 adfd drives.
    So the evga 680i is not much worse, especially considering i'm running mature drivers on my p5w dh and the evga has just been released.
    So i don't think raid performance is worse on the 680i and i'm going to replace my p5w d with a 680i, not sure if it'll be the evga one though (like the looks, caps and vrm of the abit!)
    (hi extera, tweakers is going XS!)
    Lian Li PC V1000B Plus
    Sea Sonic S12-600 EPS
    Asus Commando
    Intel QX6700 @ 3.8GHz max (L647)
    2x Corsair TWIN2X2048-6400C4 (4GB)
    4x WD HDD Raptor 74 GB WD740ADFD (areca raid 0)
    1x WD Caviar RAID Edition II 400 GB WD4000YR
    Asus 8800GTX
    Tuniq Tower 120 and loads of fans
    Sep 2006
    Denmark
    Thanks for the info concerning RAID performance catscit!
    CPU: QX9650 @4.25.
    LCD: Dell U2410.
    Jul 2006
    Netherlands
    raid performance:
    my p5w dh has a sequential read of around 130Mb/s and a burst of 240Mb/s with 4x raptor 74 afdf drives.
    Asus Commando
    Asus 8800GTX
    Xtreme Cruncher
    Jun 2006
    San Jose
    Fugger is that 4x 150 raptor in raid 0? The result looks pretty low, you should be in the +200/Mb sustain read. I remember nvraid wasnt that bad, it cant possibly got worst. I have this board here but I havent try yet, but I was hoping that is not the case.
    Quote Originally Posted by catscit
    raid performance:
    something is wrong with your setup too if your only getting 130 sustain read. I get 212/Mb just from 3x Raptor ADFD.
    For all your cooling needs: ShopPTS.com
    System:
    Rampage Formula // E8400 @ 4.0 (1.28v)
    4x 1GB Ballistix Tracer @ 600 (5-5-5-15)
    4x 74GB Raptors 16MB Raid-0 // Samsung F1 1TB
    eVGA 8800GTS 512MB @ 800/1111/2000
    Corsair HX620 // LG246WP
    Cooling:
    D-TEK FuZion // PA120.3 // 3x Yate Loon SH
    MCW60GT // EK Multi-150 // DDC-2 + Petra's Top
    Jun 2002
    Las Vegas
    I added 2-2-2-2 timing screen shot above in Ntune, cpuid does not show timing on 680i.
    Here are a few from 975x chipset to show tight timing on Dominator 8888 validation.
    3-2-2-x
    http://valid.x86-secret.com/show_oc?id=132695
    3-2-3-x
    http://valid.x86-secret.com/show_oc?id=132701
    3-3-2-x
    http://valid.x86-secret.com/show_oc?id=132696
    3-4-3-x (1Ghz)
    http://valid.x86-secret.com/show_oc?id=132692
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    May 2006
    Philippines ^_^
    nice
    hope we will see DFI.. nice board.. i probably get this..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
  18. #18
    Jun 2006
    Belgium - Brussel
    Quote Originally Posted by erwinz
    nice
    Me too
  19. #19
    Banned
    Aug 2006
    me three!
  20. #20
    Xtreme X.I.P.
    Dec 2003
    Good writeup, Charles
    There are few things I'd like to see from anyone testing this mainboard, apart from what we know, that 680i is naturally SLI capable... This board is a lot different from Intel chipset-based ones in those two areas. So, those are:
    - what are the advantages of asynchronous vs linked to FSB memory overclocking and how well it works;
    - advantages of 1T vs 2T on this mainboard, measured with anything else besides synthetic benchmarks;
    - how far will board allow to go with 1T Command Rate before having to drop to 2T and what exactly is FSB and memory clock it happens at;
    Some good benchmark would be nice to show that, e.g. SuperPi 32M will do, as 1M will be to hard to see differences with. Not asking for anything like games or encoding, to save the time
    Can you try that, Charles?
  21. #21
    Nov 2003
    Lisboa-Portugal
    Nice thread FUGGER, i just got one myself.
    I need some help and i wonder if you can help me.
    I dont have the board CD and I cant find the raid drivers anywhere, and if you dont mind can you give the links to download it and if you can the link to the new bios.
    Tks
    ASUS Maximus 4 Extreme,Intel Core i7 2600K WC@4800 24/7, 2x Gigabyte GTX560 TI OC, 8Gb GEIL Corsa, OCZ Vertex 3, PSU Antec HCP-1200
    75969 3DMark 2001
  22. #22
    Xtreme X.I.P
    Mar 2005
    Belgium, Namur
    It s stable @ FSB 450mhz.
    I m going to try higher
  23. #23
    Jun 2005
    The MotherShip
    try orthos blend test and why does orthos read 4050 but cpuz read 3599? is this unlinked?
    "Behold, I am Funkadelic. I am not of your world. But fear me not, I will do you no harm. Loan me your funky mind and I shall play with it. For nothing is good unless you play with it. And all that is good, is nasty!"
    ("What Is Soul," Funkadelic, 1969)
  24. #24
    Apr 2005
    Germany, Bremen
    Orthos and Coretemp use the multiplier 9 and cpu-z uses the real multipiler 8.
    449*8 ~ 3592
    449*9 ~ 4050
  25. #25
    Xtreme X.I.P
    Mar 2005
    Belgium, Namur
    Quote Originally Posted by SeLecT
    449*8 ~ 3592
    449*9 ~ 4050
    yes and nvmonitor also
