XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods
Reply
Old 11-06-2006, 11:43 AM   #1
GAM
Xtreme Cruncher
GAM's Avatar
Arrow Guide: PSU SATA Power Cable Mod/Sleeving
Pictorial guide on modifying your PC power supply SATA power cable (follow web link for full details: http://www.gam.net.au/pcmods/satapower/index.html.)
Note, the page still requires further updates and enhancements. I figured it was best to get something up rather than nothing
I didn’t like the locations of the SATA power connectors on my ThermalTake ToughPower 750W PSU cables so I modified them to be more appropriately located and spaced. This is nothing new, but as I experimented with various SATA power connectors and took pictures along the way to assist another forum member, I ended up with sufficient material (and experience?) to put together a simple guide.
The objective was to relocate the existing SATA power connectors to the end of the cable, spaced apart accordingly with the power connectors of my mounted hard disks. The distance between connectors is never appropriate for me. For instance, with three drives in a row, I want three connectors about an inch apart, not 3-6 inches! I also want the cable to be long because I am routing all cables and wires in and around the motherboard etc.
Before:
After:
(Please excuse the dodgy picture, but the camera was away so I had to use my mobile phone.)
The overall length of the cable is the same. Note the black heatshrink where the original connectors used to be.
The full guide can be found here: http://www.gam.net.au/pcmods/satapower/index.html
Happy modding!
__________________
Project: "IOU"
GAM is offline   Reply With Quote
Old 11-06-2006, 01:01 PM   #2
Nosfer@tu
OCTeamDenmark Staff
Nosfer@tu's Avatar
Send a message via MSN to Nosfer@tu
Great job Gam
Like your other work to
__________________
OCTeamDenmark.com
Nosfer@tu is offline   Reply With Quote
Old 11-06-2006, 01:09 PM   #3
GAM
Xtreme Cruncher
GAM's Avatar
Thanks mate.
And thanks for the previous encouragement too. Sometimes that's all it takes to get motivated. I've got more guides/info to come, I just need the time and energy as quite a bit of effort goes into these things (surprisingly or not.)
__________________
Project: "IOU"
Old 11-06-2006, 01:48 PM   #4
Shift
Send a message via AIM to Shift
Great tips and loads of pics. Bookmarked!
I can't wait for the Cable management mod, do that one next!
__________________
Watch 24!
Q6600 G0 w/ Scythe Zipang
A Data 2x2gb DDR2-800
Corsair 750w PSU
8800GTX
320gb Maxtor HDD
Audigy 2 ZS
RocketFish case
Shift is offline   Reply With Quote
Old 11-06-2006, 03:10 PM   #5
GAM
Xtreme Cruncher
GAM's Avatar
@Shift, cheers. I'd like to write up the Cable Management mod (part of the whole 'mods to "Main"/Chieftec mods' I've been doing), but it could be a little while yet . There are some basic pics of the work done in the 'sneak peek' page (scroll the pics to the right a few (5?) and you will see the MB tray cutouts and a shot of the cable routing behind. It needs enhancement though and a little more work to get it perfect . There is also some stuff in a thread here, but mostly side panel window related.
__________________
Project: "IOU"
Old 11-06-2006, 06:25 PM   #6
qdemn7
qdemn7's Avatar
Kudos GAM, thanks for the guide. Will definitely help down the road.
__________________
DFI LP LT X38 TR2
Yorkfield Q9450
2 x 2048MB G. Skill PC2-8000
BFG 8800 GT OC
Asus 1814 BLT SATA DVD-RAM x 2
Seagate 1TB SATA II x1
Samsung 300GB SATA II x 1
Silver Stone SST-ST60F
Dell 2405FPW
Thermalright Ultra 120 Extreme
Thermalright HR-05 SLI
HSPC Large Top Deck Station
XP Pro SP3
qdemn7 is offline   Reply With Quote
Old 12-10-2006, 01:06 PM   #7
GAM
Xtreme Cruncher
GAM's Avatar
Sticky? Post seems to have gone off the radar, can't find it in forum listings.
__________________
Project: "IOU"
Old 12-11-2006, 04:52 AM   #8
ByrgerRI
great mod....seems fun enough to DIY
ByrgerRI is offline   Reply With Quote
Old 12-24-2006, 03:20 PM   #9
TheJollyFellow
FINALLY-I've needed/wanted to do this for a while, great job on a great mod how-to
__________________
465 Watts of Computing Power....Running Off the Sun.
**w00t for solar panels**
TheJollyFellow is offline   Reply With Quote
Old 12-25-2006, 09:46 PM   #10
GAM
Xtreme Cruncher
GAM's Avatar
@TheJollyFellow, I'm glad it's helped. This is what Xtreme Systems and this guide is all about, and what makes me keen to contribute... being able to help others. Don't hesitate to ask any questions as I'd be more than happy to help (not that this is very hard, but if you've got an unusual connector or such, I might have one that I'm willing to sacrifice etc.). Same goes for suggestions to the site/content I've provided. I can be lazy, so suggestions are often all that's required.
@Moderators, thanks guys/gals, I just realised this has been 'stickied'. This is my first and it makes me feel proud.
__________________
Project: "IOU"
Old 02-02-2007, 07:45 AM   #11
IAmATeaf
Great guide, does anybody know where in the UK you buy that nylon type braid/sleeving
IAmATeaf is offline   Reply With Quote
Old 02-25-2007, 04:09 PM   #12
Cracker
Xtreme Cruncher
Cracker's Avatar
I'd like to know where to find this stuff in the USA.
Cracker is offline   Reply With Quote
Old 02-25-2007, 04:19 PM   #13
GAM
Xtreme Cruncher
GAM's Avatar
A 'google' and I came up with this: http://www.performance-pcs.com/catal...ndex&cPath=135
and... NewEgg: http://www.newegg.com/Product/Produc...NE&N=0&Ntk=all
[edit: Vantec Sleeving Kit is one of the main ones, but there are others, so perform a search for 'Sleeving Kit']
Check your local performance pc style businesses.
__________________
Project: "IOU"
Old 04-12-2007, 06:30 PM   #14
redmondmok
redmondmok's Avatar
GAM's idea was great!
I did my mod too, but without sleeving due to the short distance...
Here's the pic:
Before
close-up
After
Close-up
Tho no sleeving, but the twist looks cool too.
GAM, any more mods to further enhance the cabling or cooling?
Looking forward man...
Cheers!
__________________
CPU: Intel Core™2 Quad Q6600 with Artic Cooling Freezer 7 Pro PWM
MB: Foxconn P9657AA-8EKRS2H SOL-Series (BIOS P50)
MEM: CORSAIR TWIN2X4096-6400C4DHX CL3-4-4-12@2.0v
VGA: PowerColor X1950Pro Extreme 256mb with Artic Cooling Accelero X2
SND: Built-in 7.1 channel HD Audio with Realtek ALC883 codec
HDD: 2x Hitachi 160GB(8MB) RAID 0 + 1x Hitachi 320GB(16MB) SATA-II
CASE: InWin O3 Mid-Tower with Tagan Easycon 480W and Arctic Fan 12L
OS: Vista Ultimate/Ubuntu
redmondmok is offline   Reply With Quote
Old 04-12-2007, 07:34 PM   #15
GAM
Xtreme Cruncher
GAM's Avatar
Good on ya' mate. Yeah twists look fine. On my HTPC machine I didn't bother sleeving it either, just left the wires flat and exposed.
There's some good cable management stuff, requires some cutting, in the following worklogs (warning, heaps of pics!!!)
WORKLOG: GAM's HTPC - Simple Modding Make-Over
WORKLOG: GAM'S 'Main' PC - Chieftec BX-01 (56K WARNING!)
Good luck!
__________________
Project: "IOU"
Old 04-12-2007, 08:09 PM   #16
kim55
http://people.overclockers.ru/kim55/record4
Good!
__________________
kim55 is offline   Reply With Quote
Old 04-12-2007, 11:20 PM   #17
redmondmok
redmondmok's Avatar
Good luck!
Yo GAM,
From the Mod of ur cheftec I have a few question here mate.
1. I saw the sponge-like black stuff in the casing. Is it sponge by the way?
2. And is it suppose to reduce noise from the casing?
3. Will this sponge trap heat within the casing itself?
I can see you put in loads of work in the cool casing... How I wish have a workshop like yours...
__________________
Old 04-12-2007, 11:59 PM   #18
Nosfer@tu
OCTeamDenmark Staff
Nosfer@tu's Avatar
COOL that it is a Sticky now
proves your efforts are NOT futile
__________________
OCTeamDenmark.com
Old 04-13-2007, 12:25 AM   #19
GAM
Xtreme Cruncher
GAM's Avatar
@redmondmok, that's 'Noise Isolation' foam material with adhesive backing. It's readily available from performance pc shops. Here's a link to an Australian supplier for reference. There are other brands too. You could also go to you local electronics shop to source sound dampening materials etc. It may trap a little more heat but I doubt it makes much difference in a well cooled/ventilated case. The important thing here is reducing noise.
You'll have your chance to build up a tool collection over time. It has taken me 35yrs , maybe 25yrs from my first hammer and screwdriver
@Nosfer@tu, yeah, thanks. It was your original suggestion that encouraged me to put the guide together . It is a popular guide internationally, getting hits from all over the place (places I don't frequent or even know ) No real surprise I guess, as it is a nice easy mod with satisfying returns.
__________________
Project: "IOU"
Old 04-14-2007, 07:33 AM   #20
Nosfer@tu
OCTeamDenmark Staff
Nosfer@tu's Avatar
Your efforts dude, Your honor
And it take A LONG time to do guides like that
__________________
OCTeamDenmark.com
Old 05-26-2007, 07:26 AM   #21
Tobit
Very cool guide, thanks for doing this mate! I'm taking a slightly different approach on my new build. I am making my own cables for my modular supply from scratch. I have all the parts arriving in the mail today actually. This way, if I ever want to sell the PUS or send it off for warranty, the original cables are all intact as if they've never been used.
Tobit is offline   Reply With Quote
Old 06-03-2007, 01:33 PM   #22
GAM
Xtreme Cruncher
GAM's Avatar
@MicroFly, good one mate. I had in mind doing the same thing, but could not be bothered in the end. I also found it hard to find the plastic PSU connectors. These vary a little from one PSU to another i.e., square vs. round connections in different locations on the plastic 6-pin connector.
Good luck with it though, and make sure you post your achievements.
__________________
Project: "IOU"
Old 06-03-2007, 01:43 PM   #23
serialk11r
Xtreme Cruncher
serialk11r's Avatar
Hmmm... good idea I don't have multiple hdds so eh, I just use molexes but this is something I could consider for future stuff.
__________________
e6400
gigabyte ds2r
7600gs 256mb
crappy ram you don't want to know about
crappy hard drive you don't want to know about
crappy case you don't want to blah blah blah
Homemade watercooling mounted with zipties for the most part
serialk11r is offline   Reply With Quote
Old 06-20-2007, 11:16 PM   #24
fps4life
ok alittle question @ those that seem to know what there doing i have the antec nine hundred and the asus P5N-E mobo currently in build stage now my predicament is that the 4 pin p4 conector is in the very top corner of the case when orientated corectly and my p4 power conector does'nt reach that far is it safe for me to extend this wire to reach and allow for cable routing.
i wana save 100+ bucks on a new psu if posible
fps4life is offline   Reply With Quote
Old 06-21-2007, 10:19 PM   #25
GAM
Xtreme Cruncher
GAM's Avatar
I'd do it.
__________________
Project: "IOU"
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
{vb:raw chatroll.html}
