Results 1 to 11 of 11
Thread: Coolermaster Fujin
    Jun 2006
    stuck in Bloomington, IN right now
    Coolermaster Fujin
    http://translate.google.com/translat...D%26safe%3Doff
    Coolermaster will leave from here a few weeks (envisaged for December) a new radiator; it is about Fujin. With share a photograph which traine in a corner of their site, no information is available; one can only note that it imposes some… To thus follow meadows.
    DistroWatch - find your flavor of Linux
    Petra's Tech Shop - for all your watercooling needs
    Feb 2004
    Finland
    Isn't that the same heatsink Coolermaster had at Computex with dual 120mm fans?
    [i5 2500K, ASrock extreme3 gen3, Corsair Vengeance LP 8GB 1600MHz, Palit GTX570 Sonic Platinum, CM HAF932, Antec Truepower New 650w]
    Jun 2006
    Quote Originally Posted by Nazu
    Very similar if not the same.
    Nov 2002
    Crazy looking heatsink! That would look cool on a hspc tech station.
    In addition, best translation ever!
    I can't wait for the meadows to follow
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    Not the same. The one at the computex did not have a hole. Good idea, it probably drops the weight a good amount without losing a lot of performance if any. Freaking huge is what that is.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Feb 2004
    Finland
    Has that hole any other meaning that just for weight reduction?
    May 2006
    The Netherlands
    The hole makes no sense 2 me...
    [SIZE="1"]//My Photoblog
    Click : Ducked.nl
    //Nikki
    AMD Opteron 170 (@2600MHz)
    Abit KN8 SLI
    2x 1GB OCZ EL DDR Platinum (OCZ4002048ELDCPE-K)
    2x 1GB Twinmos PC3200
    Asus EN8800GTS 640MB
    Creative Audigy 2 ZS
    1x WD Raptor WD360ADFD 36GB SATA
    1x WD Raptor WD1500ADFD 150GB SATA
    1x Samsung Spinpoint T133 400GB HD400LJ SATA
    1x Samsung Spinpoint T166 500GB HD501LJ SATA
    1x Hitachi 7K250 250GB PATA
    Tagan TG480-U22 (480 Watts)
    Coolermaster CM Stacker RC810 Silver
    Full Specs : Click here!
    //Cooled by
    -TT Big Typhoon VX (Papst 4412 FGL)
    -2x Nexus D12SL-12, Outtake
    -2x Coolermaster Ultra Silent SAF-S12-E1, Intake
    Banned
    Jun 2006
    in a Red Rage D....
    hmm airflow? lolz
    May 2006
    The Netherlands
    It looks like its only purpose is to show the Coolermaster logo (cutout).
    Check it: www.coolermaster.com
    Click : Ducked.nl
    //Nikki
    Abit KN8 SLI
    //Cooled by
    Sep 2006
    Wow if that is dual 120mm side by side that thing is going to be beyond massive. Going to be a little tricky for some cases and motherboards.
    God's in his heaven, all's right with the world.
    AMD Athlon 64 4000+, ASUS A8R32-MVP Deluxe, eVGA GeForce 8800 GTX, 1Gb OCZ RAM, WD 10k RPM Raptor and 7.2k RPM Caviar, Thermalright SI-128 ,Lian-Li PC-V1000 Plus II
    Xtreme Mentor
    Aug 2006
    HD0
    dayamn...
    wouldn't fit in 90% of cases though...
    or atleast no case in my price range...
