I just got this card a day ago. So far its a good card. Stable in ATI tool @ 577/1600 so far.
HIS is really getting (even more) flamboyant with those card designs lately. What do the letters stand for again?
Either way, very thorough with the tests -- good job man
Hightech I think. That's the stock ATI heatsink btw , the new one.
Good clocks Try 625 core. Kick it up in 25Mhz knotches, thats what I usually do.
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
I cant adj the voltages and its about maxed almost. Im gonna get a fatal1ty VF-900 and slap it on see it if helps maybe. I wanna know when theyll figure out how to adj the digital VRM's
any new scoors with new cooling, i have the same card, it clocks grate :P 625/820 with no problems soon i will try hardmod on it :P let see what i can doOriginally Posted by Rubiconx3
3x FX8150, 1250w Enermax, Fractal Desing , HD6870, Asus Crossahair V and some ln2 stuff
http://hwbot.org/submission/935260_s...be_10sec_300ms <- Lets try agen.
jes i have sapphire rev2 , stock cooler allso, with 100 % fan speed plus e6300 @3500 mhz i cracked easily 12k @ 3dmark05 . imo very good for so cheap cardOriginally Posted by Rubiconx3
577/1600 are sick clocks for x1900GTrev2, share the bios RubiconX3
My stable speeds are 563/1470, so you're lucky with your card.
Can you check under the hood what mem you have?
>i5-3570K
>Asrock Z77E-ITX Wifi
>Asus GTX 670 Mini
>Cooltek Coolcube Black
>CM Silent Pro M700
>Crucial M4 128Gb Msata
>Cooler Master Seidon 120M
Hell yes its a mini-ITX gaming rig!
i had 1.4ns , but memory OCd to 820 mhz :O and core 620 stable...Originally Posted by ownage
looks like the new x1900gt whit 512MHz Core 1320MHz mem HDCP support on the new 1950pro pcb whiteout he cf connecters... is it?
the old had 575MHz Core 1200MHz mem
What's your CPU running at for that '01?
i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60Originally Posted by CompGeek
Yeah, don´t we all.Originally Posted by Revv23
Though the bad thing is that there´s no software voltage options on the rev.2 x1900gt-s. Looks like we have to start vmodding those suckers.
AMD Ryzen 7 1700X
ASRock X370 Professional Gaming
2X8GB Corsair Vengeance LPX 3000MHz
Gigabyte GeForce GTX1060 6GB G1 Gaming
2 X Kingston HyperX Savage 120GB Raid 0
Western Digital Blue 1TB
NZXT H440
Seasonic X850
Watercooled
Tell us how u could reach that, did u do hardmods, phase-cooling?, maybe cool the Vitec chip a bit more? (mine gets really hot).Originally Posted by sponge bob
Which voltage?, most of us cant get even 600 core.
>i5-3570K
>Asus GTX 670 Mini
>CM Silent Pro M700
My Sapphire X1900GT Rev2 only goes to about 550/1600 stable on stock cooler and stock voltage. With a new cooler and a voltmod I'm sure it'll hit 600/1700.
That's just craptastic...
Anyone know where you can get these in the UK?
This is the perfect card to replace my ageing x800xl.
thanks, Ed
Conroe E6420 @ 3.3ghz at the moment.
DFI Dark P965
2gb Geil DDR800 4-4-4-12
8800GTS 512mb
1.7TB Storage
CM Stacker
really nice card..
Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
X6800 , E6750 es
Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
Ati FireGL V5100, Elsa FireGL V3100
water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
Silverstone OP650
raptors, baracuda
If you also want to try to kill your card, then see this:
http://www.vr-zone.com/index.php?i=4132
>i5-3570K
>Asus GTX 670 Mini
>CM Silent Pro M700
wooohoooo go Shamino!
This means that x1950pro vmods should not be far off either, since they both essentially use the same digital vrms
'Gaming' AMD FX-6300 @ 4.5GHz | Asus M5A97 | 16GB DDR3 2133MHz | GTX760 2GB + Antec Kuhler620 mod | Crucial m4 64GB + WD Blue 2x1TB Str
'HTPC' AMD A8-3820 @ 3.5GHz | Biostar TA75A+ | 4GB DDR3 | Momentus XT 500GB | Radeon 7950 3GB
'Twitch' AMD 720BE @ 3.5GHz | Gigabyte GA-78LMT-S2P | 4GB DDR3 | Avermedia Game Broadcaster
Desktop Audio: Optical Out > Matrix mini DAC > Virtue Audio ONE.2 > Tannoy Reveal Monitors + Energy Encore 8 Sub
HTPC: Optoma HD131XE Projector + Yamaha RX-V463 + 3.2 Speaker Setup
really like the new cooler
Intel E6300 L927 @ 3.4ghz w/ Infinity
Asus P5B Deluxe 0910
Corsair 6400C5 2X512
Nvidia 8800 GTS 320Mb
Seagate 250gb sata
Hec 550watts
Viewsonic VA1912WB
