XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel > Intel Info And Support
Reply
Old 09-10-2006, 06:00 PM   #1
Eastcoasthandle
Xtreme Guru
Eastcoasthandle's Avatar
Intel Thermal Analysis Tool
For those of you that don't have it here it is called TAT
This program is hard to find as it's not available from Intel as of yet...I checked...
__________________
Eastcoasthandle is offline   Reply With Quote
Old 09-10-2006, 06:05 PM   #2
AndrewZorn
Xτræmε ÇruñcheΓ
AndrewZorn's Avatar
does not work on my 805D. i take it this is C2D only.
i dont understand, you can change the workload level? like make it run at 50% max or something?
__________________
ABANDON THE MODERN WARFARE 2 BOYCOTT.
Infinity Ward has promised revolutionary Mouse Control™ and Graphical Settings™ in the PC version of COD:MW2. Nothing more to complain about.
AndrewZorn is offline   Reply With Quote
Old 09-10-2006, 06:06 PM   #3
vengance_01
It will simulate a work load so you can gauge temps. From what I can tell its the same as core temp, so I use core temp, smaller footprint etc....
It see my CD2 as a Pentium M core, so mabey just newer chips and not the P4 chips??
vengance_01 is offline   Reply With Quote
Old 09-10-2006, 06:07 PM   #4
Ksu
I've tried it and TAT shows 2C less temp than Core Temp so I like TAT more
Ksu is offline   Reply With Quote
Old 09-10-2006, 06:14 PM   #5
Kashath
I'm getting 2-3 degrees C less than CoreTemp.
__________________
E6400 @ 8x375 (1.39 vcore) w/ Thermalright Ultra-120
ASUS P5B-Deluxe 0614
2 Gigs Corsair XMS 6400C4 @ 936 4-4-4-12 (2.25v)
7950 GX2 @ 550/1400
Soundblaster X-Fi
Seagate 320GB 7200.10
Kingwin Mach 1 600 Watt Power Supply
Dell 2407WFP
Kashath is offline   Reply With Quote
Old 09-10-2006, 06:56 PM   #6
ted3
Set max workload to test your max temp, and for sure the temps will go way higher than Orthos with small FFT's, theres no other way i know of to stress a CPU this much.
And you can also set a throttling level to reduce the processors performance to a preset percentage, up to 87.5% throttling. Apps will run quite slow if you set both cores to 87.5% throttle =)
What makes TAT more useful than CoreTemp is the throttlewatch, i posted a screenie in another thread not long ago, this is what happened 2 minutes after CPU fan was disconnected (3.6GHz E6600 at 1.6volt):
__________________
BadAxe2, WC'ed L631B115 Xeon3060 3.4GHz 1.27v summer OC, 2GB BallistiX 4:5,
2x250GB-16 Raid-0 + 400GB-16, 7900GTO 512MB, Acer 22" Wide, Nexus 500W.
ted3 is offline   Reply With Quote
Old 09-10-2006, 07:03 PM   #7
Ace-a-Rue
I am Xtreme
Ace-a-Rue's Avatar
as much as we would like to use this, it was designed for the mobil core...might be close but not exact...
__________________
BIOSTAR TPOWER I45 UNOFFICIAL THREAD
BIOSTAR TPOWER BOLT MOD FOR HEATPIPE AND HEATSINK
BIOSTAR TPOWER I45 BIOS FLASHING PROCEDURE
ABIT IP35 PRO HEATPIPE MOD
ABIT IP35 PRO BIOS FLASHING PROCEDURE
IP35 Pro: 9650@4000Mhz, par overclocker; Freezone Elite; 4Gb GSkill DDR-800@DDR-1068 (2 x 2gb); XFX 8800 GTS; Areca 8X PCIe in Raid 0 working at 4x speed; 4-250 Gb (single platter) 7200.10 drives; Giga 3DAurora case with side window.
Ace-a-Rue is offline   Reply With Quote
Old 09-10-2006, 07:12 PM   #8
ted3
Ace-a-rue, Merom and Conroe have the same cores, i cant see what makes a big difference. Merom has lower FSB, and what else is different?
Edit: In task manager, when running TAT stresstest, it shows up as MeromMaxPowerVer0p3, in the folder its installed there is another file for Core Duo, YonahMaxPowerVer1p0.exe.
__________________
Old 09-10-2006, 07:16 PM   #9
Artmic
Artmic's Avatar
I think you can use this thing for anything, it will report the temps, besides it is close to Everest. so how bad could it be if it is from Intel, and somehow i doubt anyone would be stupid enough not to design this software to handle more than one type of CPU.
__________________
Core 2 Duo X6800 @ 3.47Ghz
ASUS P5W DH Deluxe
Corsair TWIN2X2048-6400C3 4GB
eVGA GeForce 8800 Ultra
3 X Raptor 150GB
PC P & C Turbo Cool 1KW
TR SI-128
MountainMods U2 UFO Horizon
DELL 2407FPW
---- Water cooling components
PA 120.3 Radiator
MCRES-MICRO Clear HI-FLOW Reservoir
MCP655 Pump
D-TEK Fuzion CPU Water Block
Tygon 3603 1/2" ID Clear Tubing
Artmic is offline   Reply With Quote
Old 09-10-2006, 07:46 PM   #10
taemun
It won't run at all with my E6600, P5W-DH etc... the dialog comes up asking me to agree, I hit agree, and the program exits...
t
taemun is offline   Reply With Quote
Old 09-10-2006, 07:53 PM   #11
Eastcoasthandle
Xtreme Guru
t
bad OC?
__________________
Old 09-10-2006, 08:10 PM   #12
taemun
Originally Posted by Eastcoasthandle
bad OC?
nar its the same at stock or oc'd
t
Old 09-10-2006, 08:36 PM   #13
eallan
t
Weird, works fine on mine, same system.
(Hello everyone by the way.)
eallan is offline   Reply With Quote
Old 09-10-2006, 09:05 PM   #14
Eastcoasthandle
Xtreme Guru
__________________
Old 09-10-2006, 09:08 PM   #15
eallan
You guys have quite the selection of smileys haha.
__________________
P5W DH Deluxe w/ C2D E6600 @ 3.0ghz 333x9
Corsair Twinxms Pro 4-4-4-12 @ 667mhz
2x 320GB Seagate 7200.10
BFG 7900GTX
Old 09-10-2006, 09:10 PM   #16
taemun
Hmm .... you guys are all running XP? I'm running Windows 2003... (there is some killer pricing on it for educational purposes )
Anyone out there with 2003 x86 (32-bit) and working / not working?
t
Old 09-10-2006, 09:45 PM   #17
AndrewZorn
Xτræmε ÇruñcheΓ
AndrewZorn's Avatar
hotter than orthos!? wow... this combined with the fact that the 'core' probe is deeper than a normal die sensor... no wonder AMD fans think even the 65nm conroe runs hotter than an AX2 (not that it DOESNT, im not sure, but it doesnt run as hot as they think)
anyway the throttling sounds interesting.
so i could say, cut it to 50% clockspeed if it gets to 70*C? do you have to let this program run in the background? is there a way to reduce voltage (reducing clockspeed only wont help much)?
__________________
Old 09-10-2006, 09:53 PM   #18
Anemone
Perpetually learning
Welcome Eallan
Anemone is offline   Reply With Quote
Old 09-11-2006, 03:03 AM   #19
MrBean
MrBean's Avatar
Yeah, it's fine on my E6600, P5W DH, and GSkill HZ Ram.
Chipped clocked to only 3.33gig (370fsb 1:1), watercooled, and when using TAT thermal testing tool, temps stabilize around 47 deg C core 1, and 45 for core 2.
TAT reads 1 deg C lower on both cores vs Coretemp.
Very nifty little app, thanx Intel
Orthos will only take temps up to around 38-40 on water, this is quite a bit more intensive. Good stability checker I would say.
__________________
Never argue with Idiots...they will drag you down to their level and beat you with experience!
MrBean is offline   Reply With Quote
Old 09-11-2006, 03:07 AM   #20
fhpchris
fhpchris's Avatar
Does not work @ server 2003
fhpchris is offline   Reply With Quote
Old 09-11-2006, 09:15 AM   #21
ted3
The on-demand throttling isnt something most people want to use i think I guess its just there for testing purposes, like the name of the app indicates its an "analysing tool". Temps will drop quite a bit when setting throttle, but as my little test without cpu fan showed, the cpu will throttle itself down when going above 85c as a safety meassure. As long as you can run TAT for 5-10 minutes at dual 100% worklevel without throttling you are safe, if it aint broken dont fix it! High temps are nothing to worry about, throttling is what we dont want. The reduction of voltage will still be the job of C1E, dont know if theres a way to do that on demand, probably not.
__________________
Old 09-11-2006, 09:27 AM   #22
Shintai
Xtreme Cruncher
Shintai's Avatar
Just on a sidenote, please ask before you paste a link to my home server again
But on the good side, you didn´t link my picture directly.
But else, its the best tool. And it will never be a public download, since its for OEMs internal testing only.
__________________
Crunching for Comrades and the Common good of the People.
Shintai is offline   Reply With Quote
Old 09-11-2006, 09:45 AM   #23
Fred_Pohl
AMD fans think Conroe runs hot because they have no clue how hot their 100W+ Athlons really run. It doesn't help that so many Conroe users mistakenly think that TAT and Core Temp readings are somehow comparable to other cpu temps, because they aren't.
__________________
Gigabyte GA965P-DS3
E6400 @390FSB/3120MHz (1.40V)
Scythe Ninja Plus 1500rpm fan
2x1GB OCZ EL Platinum XTC Rev. 1 @DDR780/4-4-4-12/2.1V
EVGA 7800GT-CO @500/1150
Seagate 7200.10 320GB/16MB SATAII
Etc.
Fred_Pohl is offline   Reply With Quote
Old 09-11-2006, 10:21 AM   #24
vengance_01
thats very true. my Scythe Mine's heatpipes do not even get warm under full load with my 6300@2.8GHZ@1.32 volts(bios) I think this is reading at the very heart of the core thus giving very accurate temps at that spot. Its cooler running than my old Opteron 165@2.7GHZ as I can feel the back dumping off much less heat.
Old 09-11-2006, 11:02 PM   #25
Fred_Pohl
Finally! Thank you. I'm so tired of reading opinions about how the bios, speedfan, easytune, etc. are reading some nonexistent mobo socket thermistor and that Core Temp, iTAT and Everest are reporting "true" on-die temps. While the second part may be true, it's important to understand that Core Temp, etc. are reading sensors that don't exist on any other cpu and are therefore not comparable. As for the socket thermistor theory, that's just plain BS. Every Intel CPU since the P2 has had an on-die thermal diode which has been read by the mobo to get the cpu temp.
Nice to meet someone else who "gets it".
__________________
Gigabyte GA965P-DS3
Etc.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
