looks niiiiiice. so many slots!!! keep us updated!
So ... DFI finally releasing it's new O.C King ...
Waiting to read more !
someone resize this image and host it on XS..........it takes ages to load even on damn cable
Active cooling on SB ? I don't get it, should it not be on NB ?
Signature? are you kidding? with new stuff coming out every day, why bother ?
DFI layouts always rule.
pls. test max. Fsb...
if you can
...thanks regards -dyn
i don't think that's intel chipset >>> nvidia chipset that gets hot is located under the fanOriginally Posted by IluvIntel
Damn - I wish this had been released a few weeks ago. Looks like it will be a good board.
Bloodrage || 920 @ 3.2Ghz || TRUE Black
3x 2GB HyperX 2000 || @ 2000Mhz 7.7.7
2x 300GB WD VR Raid 0 || 2x 2TB Samsung F3 Raid 0
LG 10x BD-R || LG 22x DVD/RW
MSI GE 470 || LG 246WP
Sonar X-Fi || Klipsch 5.1
Lycosa || Mamba || Exact Mat
CM ATCS 840 || Seasonic M12D
Server 2008 R2 x64
@ Dynasty
well it seems they'll only do around 350MHz FSB (unless retail board will do more.....who know more mature bios and all )
http://www.tweaktown.com/articles/926/
tweaktown motherboard had active cooling on that passive heatsink as well (reference board >>> gues final version can do with it)
I can't wait to see the potential of this monstrous one!
My current rig info,
CPU: Intel Core 2 Duo 6600 Retail (Maleysia Packing L632F047)
Mainboard: ASUS P5W 64 WS Pro (BIOS Version: 0402)
Memory: SuperTalent DDR2 5300 1G*4 or A-DATA 6400 Extreme Edition 512M*2
VGA: Nvidia 7600GT or Matrox G200
HDD: Seagate sata2 320G*2 in raid0 and Samsung sata2 250G
Power: Enermax EG701AX-VE
Case: Nude in action when overclocking!
Cooler: Nowpug.com DI/LN2 2.5' Copper Container or Tuniq Tower 120
Monitor: UP-M23U or 10'4 dedicate display for overclocking
OS: Windows XP or 2003 Server
350 fsb is not to good.....350 x 11 & your already maxed out on air
you'd need more to max out on air as well LOL!Originally Posted by Dynasty
kan anyone see where the 12v stick goese in? i like the clearance around the cpu socket looking forward to the results?
Gigabyte X38T-DQ6/2x1gb xtreme/2x2900xt
E6850@ 4500
1000w psu/vapo Ls/2x74gb raptor raid.
Hoho~~We will use 2x7950GX2 from Winfast and do a Quad SLI test.
And the Extreme FSB will be......Haha, please wait for our results!!
busy with the MB now~~
not support my usb-dvdrw ......
not supported ? at all even in windows ? or you can not boot from it ?
i have not been able to boot with my 2x NEC 3550a drives when using them in a USB enclosure.
ive tred with a few different motherboards and none of them will boot to a usb cdrom.
but im jumping to conclusions.
so not compatible means ?
"These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
Welcome to the Roughnecks"
"Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
Heat Ebay Feedback
I always use usb-cdrom install my systemOriginally Posted by Lestat
now I have to use IDE-CDROM ....
because when i use usb-cdrom,the debug LED shows 50....cant continue....
lol don't waste time with that stuff dude heheheh
get cracking pronto
hehe dinos gets right to the point I am hoping for good results my fingers are crossed. X X
Been waiting for someone to have a play with one of these boards....
P5W64 WS PRO 69M0AG
E6600 B2 - BTT HSF
2x 1GBHZ G.Skill DDR2 serials 0606
2x 1GBHZ G.Skill DDR2 serials 0629
XFX 8800GTX 760mb PCIE
TT Shark Case 2x120mm fans
Enermax Liberty 620watt
Creative X-Fi
2x ASUS DVDWR SATA
WD 320GB SATAII
Seagate 120gb SATAII
WD 200GB SATAII
Seagate 200GB SATAII
How would the Default Vapochill Lightspeed Clamshell fit on the Board?
Would it need the 775 Kit Instead or is the Previous Clamshell sitting for a Snug Fit ?
Wow, releasedate ?
[SIGPIC]http://techsweden.org[/SIGPIC]
Gigabyte Z87X-OC, Haswell 4770K, 8GB Team Group 2666mhz, Asus HD7970
