Page 1 of 3 123 LastLast
Results 1 to 25 of 63
Thread: Update: 535 FSB on Gigabyte DS3.
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    Thumbs up Update: 535 FSB on Gigabyte DS3.
    ES 6400, 6x multiplier. 1.4 volts. (overkill for the hell of it)
    VMCH mod, at 1.75 volts.
    Vdimm mod, at 2.7 volts.
    VFSB at .3+
    Bios F3.
    C1E disabled. TM2 disabled.
    booted into windows at 470 FSB. used Easytune5 to get up to 533.
    can boot up into windows at 480 about half the time. 470 about 95% of the time. will not boot past 490 regaurdless of voltage or ram used.
    there is a hardwall at 533.
    getting to 533 is rather easy, but right after it, the board just goes nuts.
    even 1-2 more FSB and the board just starts acting crazy... like the screen will go black, then turn back on, or it freezes... then goes again, or the mouse goes away, then comes back...
    Hardware used.
    OCZ 600 watt powerstream.
    X1900XTX.
    1 gig of Corsair 5400UL V1.2.
    Sumbeam Silent Whisper heatsink.
    Swiftech MCX159R for chipset.
    120mm enermax fan over the ram.
    not intended to be shown as stable, just the max I could do
    I just got this CPU about 4 hours ago, still playing with it
    CPUZ Validation. (Cas is reported wrong, should be 5-5-5-15)
    http://valid.x86-secret.com/show_oc?id=108983
    Edit: see post 29 for the 535 FSB shot
    Attached Images Attached Images
    Jun 2006
    Jesus...
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    beautiful...WR?
    Jul 2005
    ATX
    umm... Nice!
    more proof that allendale+965 = goodddddd
    keep up the nice work Kunaak!
    Oct 2004
    Old Vizima
    Thumbs up
    Impressive as hell, no doubt!
    Mar 2003
    Damn, killer ram...
    EDIT: Link to the mods?
    Asus P8P67-M Pro - Bios 413
    i7-2600K LO41C106
    Cooler Master V8 - Antec 180 Mini
    G.SKILL Ripjaws X Series 8GB (2 x 4GB)
    Sissy OC - 4.6 @ 1.3175 24/7 | 18' Idle - 55' Load
    Windows 7 MS Is Getting Better...
    Personal Site!
    Git-R-Done
    May 2006
    Toronto, Canada
    Holy bannana....nice one...what's default voltage on that anyways?
    May 2005
    Arizona State
    what did it do withouth vmch mod?
    Q6700
    MSI P35
    8GB OCZ
    2xHD 2900 XT
    PCP&C 1kw
    Apr 2005
    Calgary, AB
    Nice Kunaak!
    MB Reviewer for HWC
    Team OCX Bench Team
    Nov 2002
    Juneau Alaska
    all information about volt mods I used, can be found in my post here about the mods.
    http://www.xtremesystems.org/forums/...d.php?t=107692
    the real credit for these mods goes to shamino for pointing me in the right direction to find the mods, once I had a idea where to start, the mods were pretty easy to find.
    a note about MCH mod, the board has some sort of OVP at 1.75 volts.
    should your board stop booting, just lower the voltages to below 1.75 volts.
    beautiful...WR?
    I have no idea... been awhile since I had a WR, so I really dont know.
    my goal was really the 550 mark... atleast thats what I told Shamino when I asked for his help...
    but 530 is definatly nice.
    whoa, just realized... thats a 100% OC on the FSB.... haven't done that in awhile....
    Xtreme X.I.P.
    Dec 2003
    Awesome work Eric, on both kick a$$ FSB overclock and vmods in the other thread
    Quote Originally Posted by pcdoc1
    http://www.xtremesystems.org/forums/...1&postcount=13
    Xtreme Bandwith Whore
    Aug 2005
    Orange County, CA
    Wow, kickass job How stable is she at 533?
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    Now we need to find RAM that will run 1:1 The day is too far....
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Jul 2006
    awesome job
    are we gonna see 7x and 8x multi soon
    Mar 2005
    bet you 5 bucks he gets a 3.5+ @ 8x.
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Very nice grats WR bus speed.
    If you can get some sandra 2005 and everest runs we would love to see some 500+
    Nice to know those boards have a lot of potential.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Nov 2002
    Juneau Alaska
    Quote Originally Posted by NXds
    CPU tops out around 3.75 ghz, I only have a 1M shot of that, cause its really unstable and requires 1.45 volts to get there, and heats up pretty fast.
    I'll post that shot soon.
    heres alittle early work.
    I originally started by using the 7X multiplier, but the CPU tops out around 3.7 ghz, so theres no way I was gonna reach the 530 area, with the 7 multiplier, unless I get better cooling on the CPU. and for now, I am just testing air, though I have both watercooling and phase change ready to go at any time.
    how stable at 533?
    not even close to stable.
    just a screenie...
    I did a few tests at 515 with super pi, but not much else yet.
    I do however, think I can get a few bandwidth shots at 500+.
    500 is pretty stable.
  18. #18
    Mar 2005
    bet you 5 bucks he gets 4.0 @ 8x500.
  19. #19
    Oct 2004
    Wild West, USA
    Awesome man . Congrats on FSB WR. Intresting why 965 does so well with 2mb cache cpu's. I'd like to see your MB with 6600 on max FSB.
    Did you try to play games with 500 FSB? Realy intresting if it will be stable.
    Abit IC7 P4 2.8a @4.21 | P4 3.4e @4.9 | Gainward 6800GT GS @486/1386
    Asus P4P800 SE Dothan 730-PM @ 2900 | EVGA 6800 Ultra GS @521/1376
    e8400@4.3G & 8800GTS G92 800/1932/1132 as gaming rig 24/7
    Custom self build chillbox with watercooling @-28c 24/7 | chilled wc " cpu -18c idle/-3c load
    3DMark 2005 Score Dothan & 6800U
    3DMark 2005 Score p4 & 6800GT
  20. #20
    Jan 2005
    Ioannina
    Awesome !!! 3.75gigs @ 6400 with what cooling ?
  21. #21
    Jul 2004
    France
    nice i965 WR, i'll try to go over my WR MAX FSB INTEL soon...
    http://valid.x86-secret.com/show_oc.php?id=105668
    French Overclockers roxxxxxx
    OCM Team addict
  22. #22
    Nov 2002
    Juneau Alaska
    heres the shots I was talking about heres 3750 on air.
    not even remotly stable... just a quick test.
  23. #23
    Jul 2006
    3.75 is pretty nice, should ur water or pahse take care of the stability issue
    whats the highest the cpu booted at
    u said booted at fsb 470, but at what multi
  24. #24
    Nov 2002
    Juneau Alaska
    heres a quick test of just the default voltage.
    no idea if this is the max, but this appears to be 100% stable so far.
    ran 32M on it a few times at this speed, and all default voltages, besides the obvious volt mod offsets.
    C1E and TM2 disabled.
  25. #25
    Nov 2004
    What are the C1E and TM2?
    Core 2 Duo 6300
    Gigabyte DS3
    BFG 8800GTS
    2x1gb OCZ 6400 Plat 4-5-4
