no matter what
if gigabyte not going to fix it, we can also exchange to 2GBPK for 2GBZX and 2GBNR for 2GBNS. however, it is just weird to me that seting CL4 will auto change to CL3 that is weird
no matter what
Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
Check out our items on NewEgg
So if i hand in my unopened 2GBZX you give me a 2GBPK kit?
Sweet...
Is there anyway to test the DQ6 board using either F2 or the F3a beta?
richard y do u make 2 posts when u can just do one
so would this be a problem for any ram on this board that wont boot at cl3 because it sets that automatically, or does it only do that for some gskill ram
Um, another question popped into my head after the first one, sorry.
Does this Gskill work fine in the DS3? Im thinking of getting it. http://www.newegg.com/Product/Produc...82E16820231051
I want to get the best working ram for under 200$ and these seem to be good, but I'm not sure whether they work in the DS3 flawlessly at boot.
hehehehehOriginally Posted by Haltech
Originally Posted by dinos22
Asus P8P67-M Pro - Bios 413
i7-2600K LO41C106
Cooler Master V8 - Antec 180 Mini
G.SKILL Ripjaws X Series 8GB (2 x 4GB)
Sissy OC - 4.6 @ 1.3175 24/7 | 18' Idle - 55' Load
Windows 7 MS Is Getting Better...
Personal Site!
No, it's more proof that everyone is dealing with a new chipset... A little research before you purchased might have been a reasonable approach...Originally Posted by bobdelt
i7-2600K LO41C106
Personal Site!
Edit: I see this is a more isolated issue with 965 / DS3. Sorry.
Just as an FYI to counter some of this..
My ZX kit is fine at 1.8, 1.9, 2.0, 2.1, 2.2, 2.3.
SPD sets it correctly, manually at 4,4,4,12 it's also fine.
Though, this is on 975 chipset, so, maybe it's a 965 issue. (P5W DH)
I have had some strangeness with it and Orthos/SP/Prime, but I seem to have sorted it last night and have had no problems since.
Of course, if the G.Skill guy is having problems, there is obviously something wacky.
stuff goes here.. etc etc.. i win.. lalala.. pwn etc
sup guys.... that is right, i am working about 12hr a day and no weekend life
ok i try F2-6400PHU2-2GBNS, F2-6400PHU2-2GBZX
those are show haveing problem with 965 chipset only.
there is no problem with 975 and 945 (i only have those mobos)
however, 965 due to the design of mobo, those two kits are not working properly.
i recommend buying F2-6400CL4D-2GBPK amd F2-6400PHU2-2GBNR.
those kit using 1.9v are good on 965 chipset, i am testing it right now and i will post my result tomorrow.
really sorry about the tourble.
Thanks I would definitely buy Gskill if I didn't have to worry about which RAM would work in the DS3 etc.
I hope I can get a 2GB kit soon, perhaps from Gskill if there is a good working one for the DS3. hmm
right now i am testing F2-6400CL4D-2GBPK on Asus P5B-D tonightOriginally Posted by Chris583
and tomorrow i will test it on Gigiabyte DS3 mobo
However there is a problem, with 2:3 divider at DDR2 800
no matter i manually set at CL4 in bios, it just boot with CL3....
that is bad, bad and bad!!
G.Skill Guy: You rock.
We all appreciate the testing and honesty of the responses from you guys.
Seriously top notch, you don't see this kind of thing from most manufacturers / vendors.
[flame bait] intel, when are they gunna stop screwin' up [/ flame bait]
but seriously, g.skill is a very good company, it's just timing-voltage issue. every generation of cpu's have a draw-back. even new generation of mobo/chipset have limitation. tha's what happens, tha's why overclocking/tweaking is a skill, not a given.
mobo: strix b350f
gpu: rx580 1366/2000
cpu: ryzen 1700 @ 3.8ghz
ram: 32 gb gskill 2400 @ 3000
psu: coarsair 1kw
hdd's: samsung 500gb ssd 1tb & 3tb hdd
I got the ds3 and the cheap gskill 2gbns ddr2 800. Do you think I'll be ok?
EDIT: I see gskill is testing this out. I will wait for there results and hope I'm not screwed.
Gigabyte 965P - DS3
Intel C2D E6400 @ 2.8Ghz
eVGA 8800GTS @ 675/1025
G.Skill 2GB DDR2-800
Ultra XVS 700W
Creative Audigy 2 ZS
no it is not ok.....Originally Posted by delas52
Yea I just saw there is an issue there. Is there anyway I will be able to get these two to work together?
Gigabyte 965P - DS3
Ultra XVS 700W
This wont work either Patriot PC7200 2x1GB DDS2 900
oh too bad, it's stupid isn't it?Originally Posted by Lestat
btw, you should blame G.Skill rather than Gigabyte.
who would expect 1.9v unbootable?
Yo GS TEch. This guy was having the same problem with the ds3 and some ocz ram. Look what he did to boot into the bios an raise the Ram voltage:
You think this can be done for us as well, because what he did really was independant of the ram he had, since it wasn't in the mobo when he gt into the BIOS?Originally Posted by rzrsk8
Gigabyte 965P - DS3
Ultra XVS 700W
G.SKILL tech...so would it be possible to exchange a 2GB ZX kit for a 2GB NR kit?
I know the NR is cheaper, but i don't care about that...i just want a working PC!
the ram he uses is ocz 800mhz gold, so rated at 2.0V and starting with cl5.Originally Posted by delas52
the gskill on the other hand is starting with cl3 instead of cl4 AND with too low voltage.
so thats a pretty big difference.
also, he had luck, as he wrote he had try for HOURS to get even in bios. I don't think many people would like to gamble with they ram and mobo combination, do they ?
I guess I'll trade my ns for nr then through gskill. How quick are they over there at gskill?
But still man, it isn't much of a gamble if you just do what he did and change the voltage then boot up again with everything attached to the mobo and the highered voltage.
Gigabyte 965P - DS3
Ultra XVS 700W
This still looks like a MB issue to me... Corsair 6400 C4 also starts @ C3 with the F3 and F4a bios..
i7-2600K LO41C106
Personal Site!
