E6500 ? Now that`s something new.
Is that upcoming 800FSB chip ?
this could be what the 3000+ was for amd
No, 3000+ is 6300 For them
6500 is more like 3500+
Actually this one will be named as E4300. It seems cpu-z ain`t recognising it quite well atm. Very good chip never the less. 9x multy and 200FSB at stock.
Now go and get some decent cooling for that little chip and squeeze >3.5 out of it
No its deffiantly a 6500...
They are due out later i think..
Im on a coolermaster hyper 48+ which should do the job?
Still these high temp reports are worrying, does anyone elses gigabyte report high temps?
try to flash F3 BIOS - perhaps temp monitoring ain`t that correct with F1.
Oh and what`s the default clocks ? with 200FSB it should be 1.8GHz - just like E4300
if you look @ cpu-z = 2.4Ghz (266x9)Originally Posted by Cooper
So it`s E6400 with only 2MB L2 - alrighty then.
And YGPM horrorwood
e6400 is not 2.4ghz at stock.Originally Posted by Cooper
oops I ment E6600Originally Posted by horrorwood
oh and i dont have any floppy disks, what can i use to flash the bios in windows?
no, its a E6600 with 2MB L2Originally Posted by Cooper
edit: to late
i ment E6500 = E6600 with 2MB L2Originally Posted by horrorwood
And it seems you must have Floppy to flash BIOS.
PS you have PM upper right corner of main forum index webpage
Still need a floppy disk for that...Originally Posted by COOPER
Whats stock cpu volts?
1.3volts?
Using cheap kingmax ram too, seemed to do ddr667 at 1.9volts ok though. Only ram i've got that will post in this mobo :/
Whats safe volts to go to on ddr2 ram?
That looks like a great chip, good balance between Perf. and price i would imagine.
When's it due out?
Conroe E6300 ES
2x1gb Ballistix PC8000
Asus P5W DH Deluxe (1705)
Manli Geforce 7950GT 512mb
Hiper Type-R 480w
Samsung SP250
"What did the quantam duck say?" "Quark Quark"
aquamark pleaseOriginally Posted by horrorwood
how bout some 05 and 06
btw this would mean 250$? if you want to obtain this chip?
Wait, isn't the E6500 the 2.4 ghz 1066fsb 2mb chip Intel is also releasing in Q4?Originally Posted by Cooper
Yay, well done mate, see you finally got it working then!!
Seen what kind of clocks youve been able to get out of it yet?
e6300 X850XT '03 16296, e6300 X850XT '05 7193, e6300 X850XT '06 2528
