Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: LukeXE`s autocascade for Xtreme Competition
    -130C Club Member
    May 2005
    Poland
    Hey
    I wanna show you my autocascade, that I have done for Xtreme 2006 Autocascade Competition. I`m in CO2 division, so I have hard job to do with that gass.
    Now spec of unit:
    Compressor -- Rotary 1HP
    Condenser -- steel, about 2kW
    Evap -- a`la chilly1 one, made in poland
    Cap tube lenght -- high stage 2,35m, low stage 3m
    Interstage HX -- my innovative project, insulated well with foam.
    Phase Separator -- modded empty mapp gas bottle.
    Gasses -- R22/R290/CO2
    Cut off switch from Hatemi
    and here some picks:
    That`s all for now, tomorrow I will try to tune it well with 150W dummy load
    Cheers !
    -150c Club Member
    May 2005
    Northeast, USA
    Whats your lowside pressure?
    If you have a cooling question or concern feel free to contact me.
    -130C Club Member
    May 2005
    Poland
    ~ 1 bar, so really I must tune it to make pressures smaller.
    -150c Club Member
    May 2005
    Northeast, USA
    Still for 1bar doesnt that seem like the evaporator is too warm... I think your getting some r22 in the evaporator, the propane is lighter after all.
    -130C Club Member
    May 2005
    Poland
    I wanna install fans that will blow on phase sep to make it colder a little bit , maybe it will help with good separation
    -150c Club Member
    May 2005
    Northeast, USA
    I doubt it, does the top of your phase seperator have a way to block liquid?
    EDIT: Maybe provide more cooling (preferably sub ambient - SLHX sorta? ) to the mixture before it enters the phase seperator.
    -130C Club Member
    May 2005
    Poland
    No, It doesn`t.
    I will try do something to make it working good, but sth like slhx on pipe that enters to the phase sep isn`t good (I could be wrong), because if there will be too low temp, co2 will condense too. Maybe very, very small HX will be good
    -150c Club Member
    May 2005
    Northeast, USA
    Then look for a spot down your suction where its cold, but not cold enough. I don't think CO2 condensing would be a problem because I don't think you'll manage that that early.
    -130C Club Member
    May 2005
    Poland
    I`ll add it today or tomorrow, small HX before phase sep, but now I must use R290 because I don`t have now any R22
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    r290 and CO2 seems like a good mix, especially with r290's tendancy to carry oil Looks good though, I love the huge blog of insulation.
    -130C Club Member
    May 2005
    Poland
    I have added a SLHX before phase sep, vacuuming now Maybe now high stage refrigerant won`t go to the evap...I hope
    I have small problem because I don`t have R22 and R290 now ;( and I`m still waiting for preso from Hatemi, it`s should be in my house in next 2-3 days
    Jan 2006
    Sheffield, UK
    Looking good Luke. So if you use Co2 as a refrigerant how do you prevent it from forming dry-ice?
    -130C Club Member
    May 2005
    Poland
    The CO2 tripple point is -56,6*C at (from what I read) 5 bar pressure (I`m not sure about that).
    But now I don`t have any problems with dry ice, I hope I won`t have any
    The one solution is to feed evap with high stage gas, that will flush the dry ice from evap.
    Jan 2006
    Sheffield, UK
    So the high stage gas would be the R290 that has run through the HX?
    -130C Club Member
    May 2005
    Poland
    That`s right
    you can just add second cap tube to the evap, one with co2 and one with R290.
    Apr 2005
    Setubal, Portugal
    where come from the cap with r290 that feeds the evap?
    This won´t steal performace from the HX low stage ?
    CASE Sharkoon Rebel 12 / CPU Core i7 920 SLBEJ @ 4Ghz + EK Supreme Acetal + Laing 10w + Feser 240 / MOBO Asus Rampage II Gene / MEMORY 3*2Gb Transcend DDR3 1333Mhz @ 1600Mhz 8-8-8-24 / GPU ATI HD5850 1Gb DDR5 + EK-VGA Supreme Acetal / PSU Corsair TX-750 / HDD 150GB WD Velociraptor(Boot) + 500GB Seagate 7200.11 + WD 400GB(storage) / MONITOR Samsung SyncMaster 2223NW
    -130C Club Member
    May 2005
    Poland
    That cap goes from that same place, that goes cap tube to the HX (High stage liquid side).
    And you think good, this will steal performance from HX, so I won`t use this method.
    Today at 14 I will have package with cut-off switch and ethylene I will install it and make some photos
  18. #18
    Apr 2005
    Setubal, Portugal
    Quote Originally Posted by LukeXE
    so it has to be tunned like a dual head?
  19. #19
    Jan 2006
    Sheffield, UK
    I dont know if it would need to be tuned as all it would be doing was preventing dry-ice from forming...so it wouldnt matter how much was flowing through. Someone correct me if im wrong!
  20. #20
    -100C Club Member
    Feb 2004
    australia
    so ya getting some ethylene hey.
    cant wait to see the results hey
  21. #21
    -130C Club Member
    May 2005
    Poland
    I`m wondering, maybe I will use that ethylene in that auto-c, but really I don`t know how it will work Kayl, Have you used ethylene in your previous auto-c ?
  22. #22
    Jul 2003
    Finland
    It worked pretty good. 1.7hp and 34cc tough IIRC 180w in the -70c range with half of the compressor under ice because too cold suctiongas
    cool cool cool!
  23. #23
    -130C Club Member
    May 2005
    Poland
    Hm, so maybe I will charge with that gas...I hope there is enough gas for that auto-c and cascade
    BTW, What discharge pressure did you have ?
  24. #24
    Jul 2003
    Finland
    It did have high startup preasure but when running properly it was quite reasonable. You might want to try with butane and propane to get the startup preasures lower. I was going to, but got bored before that
    cool cool cool!
  25. #25
    -100c Club Member
    Apr 2003
    Riverside, California
    Don't think you can lower starting pressure too much on mixed gas really without sacrificing temp too much. After all, the the high pressure gas is non condensable till quite a bit later :P
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
