Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: X6800 review out early, with overclocking results!
    Apr 2006
    I couldn't find a thread on this site yet, so here it is, wow!
    Just look at the FEAR benchmarks!
    Here is the entire link, it's in French, but I Googled it for English. It's a good read.
    http://translate.google.com/translat...language_tools
    Some pricing too.
    Xeon 5160 3.00 GHz, FSB1333, 4 Mo L2, socket LGA771 - 851 US dollars
    Xeon 5150 2.66 GHz, FSB1333, 4 Mo L2, socket LGA771 - 690 US dollars
    Xeon 5140 2.33 GHz, FSB1333, 4 Mo L2, socket LGA771 - 455 US dollars
    Xeon 5130 2.00 GHz, FSB1333, 4 Mo L2, socket LGA771 - 316 US dollars
    Xeon 5120 1.86 GHz, FSB1066, 4 Mo L2, socket LGA771 - 256 US dollars
    Xeon 5110 1.60 GHz, FSB1066, 4 Mo L2, socket LGA771 - 209 US dollars
    Core 2 Duet X6800 2.93 GHz, FSB1066, 4 Mo L2, socket LGA775 - 999 US dollars
    Core 2 Duet E6700 2.66 GHz, FSB1066, 4 Mo L2, socket LGA775 - 530 US dollars
    Core 2 Duet E6600 2.40 GHz, FSB1066, 4 Mo L2, socket LGA775 - 316 US dollars
    Core 2 Duet E6400 2.13 GHz, FSB1066, 2 Mo L2, socket LGA775 - 241 US dollars
    Core 2 Duet E6300 1.86 GHz, FSB1066, 2 Mo L2, socket LGA775 - 209 US dollars
    Core 2 Duet E4200 1.60 GHz, FSB800, 2 Mo L2, socket LGA775 - Price nonavailable
    Core 2 Duet T7600 2.33 GHz, FSB667, 4 Mo L2, socket mPGA479 - 637 US dollars
    Core 2 Duet T7400 2.16 GHz, FSB667, 4 Mo L2, socket mPGA479 - 423 US dollars
    Core 2 Duet T7200 2.00 GHz, FSB667, 4 Mo L2, socket mPGA479 - 294 US dollars
    Core 2 Duet T5600 1.83 GHz, FSB667, 2 Mo L2, socket mPGA479 - 241 US dollars
    Core 2 Duet T5500 1.66 GHz, FSB667, 2 Mo L2, socket mPGA479 - 209 US dollars
    Nov 2003
    Core Duo - simply too powerful.
    Jun 2006
    Amazing stuff =D .
    Jun 2006
    Dude... the X6800 at stock is unbelievable. Imagine 5ghz like people have already achieved. I'd like to see the game benchies with 5ghz...
    Nov 2004
    Holland
    Core 2 Duet
    My Rig:
    Intel Core 2 Duo E6400
    2x512mb Micron PC3200 OEM D9DQW "Fatbody"
    Biostar TForce P965 Deluxe
    MSI/Medion GeForce 6700XL (Cheap )
    Chieftec 360W (in search for someting better)
    WD 160GB S-ATA
    Xtreme Cruncher
    Jun 2006
    You couldn't fine a topic about this review?Man there were at least 2 of them...
    Search harder next time.And the test is not showing us anything we didn't know earlier...
    Jan 2006
    Poland
    I'd like to see at least 10x7 benches with AA/AF, 640x480 seems worthless.
    ...currently under construction...
    May 2004
    Quote Originally Posted by [ypher
    not really, at that res we see big differences as the cpu's do alot of the work. its a decent way to show off the power of a cpu.
    Jan 2005
    Bay Area, CA
    Quote Originally Posted by vengance_01
    Running test at super low resolutions is just like running a synthetic bench. It shows off, but doesn't mean anything for real world performance.
    For games CPUs just don't matter that much these days...
    Banned
    Oct 2005
    Quote Originally Posted by J-Mag
    Strange you feel that way I have a differant take on what I am seeing inthat review.
    If you would look at the O/C section for gaming. You will notice that Conroes keep scaling up. Even at 3.6 ghz. While the AMD @ 3.1 loses groung and infact runs slower than a 2.7 amd.
    I believe that when the R600 are released and If you run XF the Conroe will show off a lot more power in gaming than AMD . AT high res and min frames the differances should be rather LARGE.
    Jun 2005
    The reason they chose 640X480 is because they do not pose enough stress for a bottleneck of GPU, since Far Cry less demanding than others they can reach up to 800X600 without problem.
    If you were to run it at high res, they all jam in from the bottleneck, you'd see the Core 2 Duo X6800 to be only 2fps higher than a Opteron 165, or so on
    Waiting for Crysis
    Jan 2006
    Poland
    I play games a lot, 1280x1024 is my favourite res. and these kind of tests I can name "real life". I'm waitin' for them
    Jun 2005
    But if your GPU struggles at 1280X0124, you won't notice the difference between Conroe, and a AMD Opteron.
    As I've said before, 10*7 would be pointless in terms of CPU benches, as it would not show pure processing power, but biased against the best performing CPU by hitting a fps roof from the GPU.
    Waiting for Crysis
    Jan 2006
    Poland
    I know, I know. I'm just curious how it performs
    xtreme energy
    Oct 2004
    Europe, Latvia
    How can dothan @ 2.8Ghz beat Yonah at 3Ghz in Fear? RAM taimings must be way off
    But sure Conroe looks great
    Jun 2004
    Florida, USA
    Quote Originally Posted by Celeron Gamer
    Depends on what AA/AF settings his GPU struggles at. Even at lower resolutions, the CPU is a bottleneck on all the most recent games, so all will benefit from a Conroe, some more than others.
    May 2006
    Québec, Canada
    agree.. they are testing a CPU, not a video card. Maxing all the eye candy and high resolution will saturate the video card and the CPU will only work at a fraction of his potential. If you want to see bench with 1600x1200 resolution, you will see that in a Video card review, not a CPU review.
    Rig : Core 2 Duo E6600 | Scythe Mine | 2x 1gb OCZ PC2-6400 Platinum XTC | Asus P5B Premium Vista Edition| eVGA 8800GTS 320Mb | 1x Seagate 80gb SATA2 2x 250gb WD SATA2 SE16 Raid0 | SB X-Fi | OCZ GameXstream 600W | Silverstone TJ06 case
  18. #18
    Jan 2006
    Poland
    With QuadSLI I wouldn't be so sure
  19. #19
    Oct 2004
    [ypher, take a look at this thread for some hi-res game benchmarks.
    Q6600 G0 L726A849 (3.8GHz 24/7)
    DFI LP UT P35-T2R
    4GB Mushkin
    HD5850
    Antec 750w
    X-Fi
    Dell 2407WFP
    Custom Water
  20. #20
    Jan 2006
    Poland
    Many thanks, Jumba. Looks like a week of reading
  21. #21
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    how the 165 @ 2.7 will score more than the FX-62 @ 2.8Ghz
    really i don't trust such review unless someone can give me a resonable explanation
    for sure Conroe is very nice and thiis is not what i am talkigng about , i am only worried about the ability of this review to show true results from the AMD results
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
  22. #22
    Dec 2003
    Quote Originally Posted by Your_Boss
    Some pricing too.
    looks like I found my next cpu
  23. #23
    Mar 2005
    Cairo, Egypt
    getting a FSB 800 is not an idea i like specially when u don't know its price
    i suggest saving more and buying the E6300 which is not that expensive AT ALL
    Soon to be :
    Used to be: SaFrOuT
  24. #24
    Jan 2005
    Bay Area, CA
    Quote Originally Posted by Jumba
    That's exactly what I wanted to see. However, something concerns me.
    We all know that benching at lower resolutions shows off CPU performance better, right?
    Here are the results copied directly from that thread for the FEAR test:
    1024x768, 4xAA 16xAF, all max:
    Opteron 165 @ 3GHz: Min 60 | Avg 142 | Max 370
    Conroe @ 3GHz: Min 78 | Avg 162 | Max 485
    1600x1200, 4xAA 16xAF, all max:
    Opteron 165 @ 3GHz: Min 25 | Avg 43 | Max 172
    Conroe @ 3GHz: Min 53 | Avg 86 | Max 310
    Can someone tell me why the 1024 resolution has an average difference of 12% while the 1600x1200 shows a difference of 50%? Thats a little counter intuiative don't ya think?
  25. #25
    Jun 2006
    Well really having more power is always good. I don't see why you need to have such a negative stance against progress.
