Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: Thermaltake Extreme Spirit II chipset cooler on Abit AW8D 975x motherboard
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Cool Thermaltake Extreme Spirit II chipset cooler on Abit AW8D 975x motherboard
    Funny with all this conroe/DDR2 talk, had an itch to see if i can figure out the issues with AW8D and fsb limits.
    Folks say NB chipset cooling for LGA775 is the key to high fsb, so decided to try a Thermaltake Extreme Spirit II chipset cooler on the NB chipset. Bought 2 of these coolers from i4memory.com sponsor Mittoni.com.au http://www.mittoni.com.au/extreme-sp...er-p-2318.html
    Fits just right for video card, and Swiftech G4 Storm waterblock and even has allowance for Maze4 GPU waterblocks' mounting bolts which extend out by ~25mm from the back of the video card. The orientation pictured below will allow the Maze4 GPU waterblocks' bolts to extend out without touching the chipset cooler
    Full pics posted at http://i4memory.com/reviewimages/mot...SpiritII/html/
    Preview pics:
    The Thermaltake Extreme Spirit II cooler on top of existing Abit AW8D heatpipe passive heatsink to show how it would look in it's place. Also seems the stock heatpipe heatsink's TIM doesn't even properly contact the chipset core or is it meant to be that way ?
    Please note, this Abit AW8D is an early engineering sample so might not reflect the final retail product.
    The larger heatsink connected to the heatpipe located near IO connectors is covering some mosfets. So removing the passive heatpipe, you would need to find another heatsink to cover these. Luckily, I found just the right heatsink off my old Asus P4G8X chipset heatsink measuring 42mm x 42mm. Even luckier is the fact I have double sided TIM adhesive tape which measures nearly the same size too!
    Thermaltake Extreme Spirit II chipset cooler even comes with a circular foam piece for smaller chipset cores to prevent crushing the core! Here's it fully installed on Abit AW8D.
    Haven't booted the system up yet so will find out if it helps higher FSB as well as lower temps
    Dec 2005
    Antarctica
    OMFG, guess what, this cooler should be able to handle a stock speed Conroe! lol
    CPU: Very Fast!
    Memory: Very Big!
    Motherboard: Very Luxurious!
    Hard Disk: Very Hard!
    VGA: Very Long!
    Case: Very Flash!
    Coolers: Very Cool!
    Speakers: Very Loud!
    Jun 2003
    1. I thought the AW8D did not support conroe but the AW9D will?
    2. The AW8D has been for sale retail for a week or two why use a es version?
    Feb 2006
    eva,what this function?thankyou
    Intel Core 2 Duo E6300 6B2
    Gigabyte 965P-DS3 f6b
    Corsair 5400UL v1.5
    Leadtek 7900GT 640/880 daily use
    WD Raptor 7400ADFD
    Memory Addict
    Aug 2002
    Brisbane, Australia
    yeah AW8D doesn't support conroe only AW9D does... mines ES sample board and it came with that wire on it.. not sure what it is to be honest
    only using AW8D has it's provided for me and well AW9D ain't out yet heh
    hard to justify buying a AW8D retail right now when conroe supported boards are coming soon.. using this as a test to see if NB cooling helps
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    does this cooler fit on DFI ULTRA-D ?
    ASUS P5K-E // E8400 Q746A519
    G.Skill F2-8000CL5D-4GBPQ
    LC 550W GP// XPERTVISION 9600GT
    Feb 2006
    i have retail AW8D but seem's like different,so that mod @your ES AW8D mobo for support Conroe?thanks.
    Corsair 5400UL v1.5
    WD Raptor 7400ADFD
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by TEDY
    probably but haven't tried it...
    as to the mod/wire not sure if that is for conroe.. as i got this ES month or so back so probably not
    Feb 2006
    thankyou eva2000.i'm wait till conroe launch and arrive @ Indonesia
    Corsair 5400UL v1.5
    WD Raptor 7400ADFD
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Well booted her up and so far some improvement not sure if it's to do with NB cooling but my OCZ PC5400 Platinum XTC 3-3-3-12 DDR2 ram couldn't do cas 3 before wouldn't boot pc... now with chipset cooler installed running memtest with 3-3-3-12 as rated!
    Bios temps look cool at 14x200HTT stock for 920D but have to wait to get into windows before i can compare as i really can't remember what the bios temps were before heh.
    Bios temps & fan speed
    Running system pictures below
    These below dual stressprime and dual 32M were temps in windows WITH stock heatpipe heatsink with the pictured 60x25mm 4.9W fan on top of the passive heatpipe heatsink heh
    @4506mhz
    Will redo windows results with the Thermaltake Extreme Spirit II chipset cooler soon
    Apr 2006
    Belgium
    Cooler looks good.
    But you should also try the Thermalright HR-05, I love it with a 70mm fan.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by SMa
    Cooler looks good.
    yeah no stock of Thermalright HR05 in OZ till early July heh
    Xtreme Guru
    Aug 2003
    Athens, Greece
    Nice cooler eva!
    What about its noise?
    One off topic question what audio chipset does AW8D has? Have u found any reviews on the net?
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
    OC Jedi (on stand-by)
    Jan 2005
    Germany
    Nice mod, but I guess the little fan on it is quite noisy, isn't it?
    オタク
    "Perfection is a state you should always try to attain, yet one you can never reach." - me =)
    Memory Addict
    Aug 2002
    Brisbane, Australia
    actually chipset fan is pretty quiet 19dba
    tech spec http://www.abit-usa.com/products/mb/...es=1&model=313
    AW8D sound =
    Audio
    - ABIT AudioMAX™ HD 7.1 CH
    - Supports auto jack sensing and optical S/PDIF In/Out
    - Dolby Master Studio Certificated
    Jun 2006
    Sydney, Australia
    eva, does the board work with Conroe later on? Just interested...
    PS: BTW, haven't heard from you for a long time in the Atomic froums. What ahppened there?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    nah AW8D won't work with conroe, need AW9D for that
    Atomic forum's software just too hard or pathethic to use.. Atomic should change to vBulletin.com forum software
    Looks like either uGuru software temps are not accurate (idle to load only system temp changed from 31C to 32C) or there wasn't much gain in lower system temps but i did gain being able to properly boot with CAS 3 instead of CAS 4 with the OCZ DDR2 memory.
    No gain in max oc, probably either Abit board limited or differences in cpu waterblock mounting contact this time around
    with Thermaltake Extreme Spirit II chipset cooler and MCH/PCI-E voltages at 1.7v compared to stock heatpipe with 1.65v volts.
    idle:
    load:
    Will try this again with an Asus 975x LGA775 DDR2 board later to properly see how it goes.
  18. #18
    Jun 2006
    Sydney, Australia
    Ah, k. THanks for the headsup dude
  19. #19
    Xtreme Guru
    Aug 2003
    Athens, Greece
    Quote Originally Posted by eva2000
    AW8D sound =
    Audio
    Do u know exactly what chipset it is? I know these specs from abit's site.
    Project ZEUS II
    Watercooling setup:
  20. #20
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    it's 25$ here....wonder if it works on DFI NF4 ULTRA-D
  21. #21
    Memory Addict
    Aug 2002
    Brisbane, Australia
    try it and find out hehe
  22. #22
    May 2005
    eva2000, actually the Abit AW8 series doesn't report NB temps (confirmed by Abit). The system temp that you see in BIOS/uGuru is actually case/mobo temp. You'll need to stick a temp probe near the NB to get the readings. Hope it helps...
  23. #23
    Jun 2006
    Dr^_^Gon Land
    Does anybody know how it fit on asus P5W Dh ?
    E8400@3.6ghz 1.11v |Asus P5E3 deluxe bios 1001| 2 giga Cellshock DDR3 12800@1696mhz|Samsung Syncmaster 2232BW 22' | Asus 8800 GTSē 512 TOP|Western digital sata 500 SE16 | Blu Ray LG GGW-H20LRB| Creative X-fi platinum|Nexus 600W | case Coolermaster 1000 "Storm"
    Xeon E3110@3.6ghz 1.15v|Asus P5K premium "blackpearl" bios 503|2 gigas Cellshock DDR2 8500 |Twintech 9600 GT|nec 1970 GX|Gigabyte 3D aurora case
    E8400(Q804A249) valid@ 4.8 ghz 1.56v
    Xeon E3110 (Q746A534)valid@ 4.79 ghz 1.59v real bios AIR /superpi 1m@9.968 .. under vista
    My Ibanez 540S " Saber "overclocked with Di Marzio and Sperzel
    My cousin on drums Hi Brian !
  24. #24
    Memory Addict
    Aug 2002
    Brisbane, Australia
    probably fit but remember if the larger heatsink near the IO connectors covers and cools something underneath, you'd need another heatsink too... i was lucky my old Asus P4G8X nb heatsink fits there heh
    Quote Originally Posted by pcmoddingmy
    hmmm that would explain why temps never budged more than 1C LOL
  25. #25
    Jan 2003
    Holland :)
    I`m curious how the Thermaltake Extreme Spirit II chipset cooler will compare to this baby, the Coolermaster Blue Ice II
    http://www.bytesatwork.be/shop/produ...roductid=20747
    and the newest zalman :
