Page 4 of 10 FirstFirst 1234567 ... LastLast
Results 76 to 100 of 241
Thread: Vdimm/Vcore mod for MSI K8N Neo2 PLatinum-54G Edition S939
  1. #76
    Xtreme 3DTeam Member
    Aug 2003
    Germany
    Quote Originally Posted by |-jokker-|
    I am now using a k8ns and with the vio mod the board can t pass the 220 htt dual , with 3.26v to the memory thats , my problem and the reason that e see to goo to the msi but if the msi dont like bh5 also i cant see where i am going :S
    Can anyone test bh5 in this mobo with the vio ?
    Thanks people
    BH5 need very high voltage on this Board! With 3,3V + most ppl can reach
    260 and higher. Some new BH5 records are on the K8N Neo2!
    280 2-2-2-11 and more!
    PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
    Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
    Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
  2. #77
    Mar 2004
    Portugal
    Thank“s man
  3. #78
    Mar 2004
    Do I need to make both of those to get higher vdimm?
    http://xtremesystems.org/forums/atta...chmentid=17105
    I did just think that I needed to do the one there got 2 cables.
    Intel FTW!
    Beanna
  4. #79
    Aug 2003
    Germany
    U need to do this one, to have Vdimm up to 3,2V!
    http://xtremesystems.org/forums/atta...chmentid=16902
  5. #80
    Mar 2004
    Damn I wont be cutting in my board so I guess Boosters is the only option for me. What dose the 2 cable mod do?
    Intel FTW!
    Beanna
  6. #81
    Jun 2004
    @ |-Jokker-| I tried the Mushkin BH-5 I have and it wouldn't even post at 10X220FSB.. Tried all types on timings. No good. I had Vdimm at 2.85V.... I have had that memory at 240 on other K7 boards...
    @ Gravedigga Here is a pic of the "Standard 3.3V bus to Vdimm":
  7. #82
    Aug 2003
    Germany
    Quote Originally Posted by RebelsHaven
    Yeah, thx exactly what i want to do
    2. BH5 cant go over 220 without any mod, that sucks a bit, but not for them who modded this board
  8. #83
    Jun 2004
    I didn't solder the mod in place because I don't have any memory that will work with it yet..... Maybe tomorrow.....
  9. #84
    Mar 2004
    Ah so if I do that mod the I can raise the vdimm to 3.3v?
    Intel FTW!
    Beanna
  10. #85
    Aug 2003
    Germany
    No rise, but the Vdimm is on 3,3V ever, no chance to change it.(when u mod ur PSU u can or u have an OCZ)
  11. #86
    Jun 2003
    Portugal, Lisbon
    Quote Originally Posted by NiCKE^
    If u can increase your 3,3v psu rail the mem's will follow that value with that mod!
    Weird that oc with mushkin bh-5 cuzz i see lot of cases that work like a charm, more then 270, bad luck maybe????
    Ever tried those bh5 on a different board ?
    "God...i know she's dead :'( but keep her soul alive because in my heart she will never die :'(" VoRtAn_MaDgE
    Nc te eskecerei avó! :'(
  12. #87
    Sep 2003
    Denmark
    Yeah think its up to around 3.4V.
    Brian Hermansen...benching with Jacob Hansen
    3DMark01 42400 | Aquamark3 104762 | PiFast 34.58
    Running chilly1 cascade
  13. #88
    Aug 2004
    Brasil, S.P.
    Can't belive that noone found an easiest vdimm mod yet!
    990FXA-UD3 | FX8350@4.7Ghz | Asus HD7870 | 2x 4GB Crucial Ballistix Tracer 2050Mhz 8-8-8-22 | AX850W |SSD Vertex3 Max IOPS 120GB | Auzentech Forte + TAPCO-S5
    EK Supreme Full-Gold | XSPC RX240 + EX120 | MCP35x | 3x Koolance Blue Led @PWM | Tygon Black 1/2 | Bitspower Compression | @ FM CM690 I
  14. #89
    X.I.P.
    Oct 2002
    Australia
    Quote Originally Posted by Barr3l Rid3r
    Thats probably coz people are using the Vdimm/3.3V bypass mod for really high Vdimm values and BH5.
    X800Pro class 3DMark01 : 36670
    X800Pro class 3DMark03 : 16092
    Ti4200 class 3Dmark01 No 1 : 22213
    Super Pi 1M : S754 28 sec, FX53 25 sec
    HEXUS Pifast : S754/Prom 40.55sec, FX53 36.92sec
    Author of A64 Tweaker
    Co-author of NF2 Tweaker
  15. #90
    Oct 2004
    how can I solder in the trace?
  16. #91
    Dec 2003
    @potkit: You have to scrape away some of the laminate to expose the copper trace. Tin the copper, tack down your wires, done. Just don't leave the iron on the trace too long...as quickly as possible as a matter of fact. You can cause damage pretty quickly if you get too much heat on the board.
    I've got a question myself about kyosen's mods. I understand that the 1st step only gets you so far without doing the 2nd. I'm just wondering what happens when you do OVP the board. Does it just not post until you adjust VDimm back down? Also, how far down do you have to adjust the 1k in step 2 to get the board to let you do say 3.6-3.7V? I'd like to just drop a fixed resistor in for the OVP defeat and not have to with adjusting it, or running into OVP, but really have no clue what it'll take. Obviously less then 1k, is maybe 500 Ohms enough?
    .........current project, make the 135i faster
  17. #92
    -100c Club Member
    Apr 2003
    Riverside, California
    Now, unlike most of people looking at VDDR I am more interested in VDD mod.
    Looks like to me the var in bottom is used for VDD mod. And leg that says VDD of mosfet must be measuring point. I am guessing you want to start at highest posible resistance on this mod? Running out of FSB regardless of HTT on dual channel vs single channel and I think this might be the fix doctor ordered... time to look where my grabbers are with 20kohm attached once I get some confirmation. What is default value of vdd er... chipset voltage anyway? And what should be decently safe zone based on nForce3 design?
    Thanks in advance
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
  18. #93
    Jan 2004
    Germany
    http://www.lejabeach.com/MSIK8N/VdimmMod/k8nneo2-4.jpg
    If I solder a pot between the two spots, would'nt it be possible to change the vdimm that way?
    Sandy Bridge incoming.
  19. #94
    Aug 2004
    Brasil, S.P.
    Quote Originally Posted by digitalfrost
    Sorry man there's no way to do that, unless you could find a 1ohm 15W pot.
    the 3.3V line gives something around 5 amp to the fet, with something around 15W, pots usually supports around 1/2W so it won't be enough.
    I can use a variable reosthat (1ohm 20W) or eighther some diodes in series feeding it straight from the 5V line.
  20. #95
    Mar 2004
    Portugal
    Did anyone tested the vio eith bh5 ??
    Tomorrow i will have my msi k8n neo2 and later i will test the vio mod.
    Tomorrow night i will have results for everyone.
  21. #96
    Aug 2003
    Germany
    Yeah i've already made it! Works fine here! Can bench up to 252 MHz with
    3,3V. Sys. runs rocksolid with the settings u see in my Sig.!
  22. #97
    Mar 2004
    Portugal
    Sweet man , tomorrow i will test my msi too , i hope so.
    Great oc man
  23. #98
    Team Japan
    Nov 2003
    Tokyo, Japan
    Hi,
    To mikead_99,
    Sorry, what is "OVP" ? ...you mean "over power" ?
    English is not my own language, so abbreviation is difficult for me
    I'll check it later...now I'm busy at Dothan testing
    To jinu117,
    Yes, that's right!
    Default value of Vdd was around 1.6~1.65V, within my memory.
    I don't know safety zone, but confirmed upto 1.693V
  24. #99
    Dec 2003
    kyosen: Yes, "OVP" I'm meaning Over-Volt Protection. I am assuming this is why only 3.2V with step 1, and more after doing step 2. I was just wondering how the board will act if I try to set higher then the board will allow before making the step 2 change.
    Thanks for looking into it, I'm glad you still pop into this thread. I need to buy a tool to get the Corecell cover off, so I can't do step 2 quite yet anyway.
  25. #100
    Team Japan
    Nov 2003
    Tokyo, Japan
    Hi mikead_99,
    Now I've checked it after soldering off one of wires.
    It's about 650ohm.
    In this state, I could get Vddr=3.698V at Vio=3.823V.
    Too high Vio/Vddr may causes failing cold boot,
    but in my case, the system looks enough robust.
    I could start up the system at Vio/Vddr=3.807/3.653V.
    PSU: Zippy-460WS(5V&3.3V modded)
    memory: M.tec PC2700(BH-6) 256MB x2
    Good luck!
