Page 1 of 4 1234 LastLast
Results 1 to 25 of 94
Thread: Think BH-5 can do 280 2-2-2-5?
    Banned
    Jun 2003
    Broomfield, CO
    I will be installing my VTT mod this weekend for my IC7-MAX3. My OCZ DDR Booster has been sitting by patiently for more than a month now (I was able to get one the first day they came out...lucky me). Once VTT is tracking I plan to go as high as 3.5 or maybe even 3.6V for 24/7 use with the 2*512MB Corsair XMS3500C2 v1.1 (BH-5) that I have had since the i875 chipset hit the market years ago.
    Right now I can go as high as 250FSB 2-2-2-5 stable. No problems at all. Upping the Vdimm with the booster does no good as VTT continues to hover around 1.4V.
    Any chance I will get to 280FSB 2-2-2-5 with this BH-5? Had anyone done this? Can it be done? Can I run 24/7 like that. I have some excellent active cooling for my RAM. They are not even warm to the touch right now.
    If I can get to 280 FSB I can use a 14x for 3920Mhz...which would be a very sweet spot. Thanks for reading.
    -Kris
    May 2004
    East Bay, California
    Re: Think BH-5 can do 280 2-2-2-5?
    How many volts does it take to do 250?
    Banned
    Jun 2003
    Broomfield, CO
    3.2V, no less
    Xtreme X.I.P.
    Nov 2002
    Shipai
    a good friend has a stick of bh6 thats does 270+ 2-2-2
    but thats VERY rare! dont think your bh5 can do 280...
    Banned
    Jun 2003
    Broomfield, CO
    thanks for the encouraging words saaya :thumbsup:
    Dec 2003
    It's not so much whether the RAM would do it, not saying it's a small feat by any means. The problem you are going to have before you get there is getting your nb/mobo to cooperate with 2-2-2-5 over 260 - 270. Not many people get much further on an 875 chipset, even with known killer sticks like saaya mentioned. Not in DC on 875. You might want to at least do some vddq/vagp modding while you have the soldering iron hot to help your cause out though. Hipro's all in one IC7 mods might help out.
    .........current project, make the 135i faster
    Banned
    Jun 2003
    Broomfield, CO
    NB voltage has already been bumped from 1.48 to 1.70V in preparation. That allowed me to run at 340x12 for fun if I wanted....hehe. Before I could not get over 303FSB.
    Dec 2003
    I'm not knocking the effort, but I think the best I've ever seen 1:1 with 2-2-2-x on 875 is by macci and catch22atplay in the 270 range. Doesn't mean it hasn't/can't be done. Sounds like your board is a good candidate at least. Hope it works out for you.
    Xtreme X.I.P. Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    Stinger ran 280 with his A64...I don't think the same sticks would do that on an Intel board.
    System
    ASUS Z170-Pro
    Skylake i7-6700K @ 4600 Mhz
    MSI GTX 1070 Armor OC
    32 GB G.Skill Ripjaws V
    Samsung 850 EVO (2)
    EVGA SuperNOVA 650 G2
    Corsair Hydro H90
    NZXT S340
    Banned
    Jun 2003
    Broomfield, CO
    So what's a more reasonable goal? In any case, I'm still shooting for my target speed of 280Mhz.
    XS - Extra Strong
    Aug 2003
    Toronto, Canada
    I'd say it depends on the ram, on your cooling, on your board, and luck. Whats holding you back from answering your own question?
    -Phenom2 x6 1055 @stock
    -8gb ddr3
    -Gigabyte UD3
    -Geforce 7900Gt 755/1863 1.562v vgpu
    -OCZ Powersupply 600w
    Sep 2002
    "Stinger ran 280 with his A64...I don't think the same sticks would do that on an Intel board." And they worked even higher I'm at 283mhz 1:1 2-5-2-2 but as you said that is Amd
    Shuttle SN95G5
    XS Intel News & D²OL enhanced
    Nov 2003
    Netherlands
    have vagp at around 1.98volts, have everythihng properly heatsinked, n you might make it. good luck to you
    Mar 2004
    East Bay Area, CA
    I think to get around 280 youd need more than 3.6v
    P4C 3.2Ghz @ 4.2Ghz 1.8v (Vapo LS + 4 Tornados & 2xNexus)
    AIW X800XT Running Stock
    IC7-G w/ 2x 512MB KHX3000 (BH-5) + 2x 512MB Muskin Redline XP4000 BIOS 2.8
    2x 36GB WD Raptors RAID 0 (ICH5R)
    2x 80 gig Seagate SATA RAID 0 (SiI3112a)
    Promedia 5.1 Ultra on Audigy 2 Plat
    Pioneer DVR-108D / Lite-on combo SOHC-5232K
    Lian-Li PC-65 w/ all 80mm tornado case fans & PC P&C 510w Deluxe
    WinXP Pro
    3d03: 14185
    Oct 2003
    Lincoln, NE
    My guess is 3.6v with an extremely good pair...probably in the 3.6-3.8 range though.
    System
    ASUS Z170-Pro
    Samsung 850 EVO (2)
    Corsair Hydro H90
    NZXT S340
    Jul 2004
    The Netherlands
    i know kakaroto has bh-5 that does 280mhz
    but he has an A64 aswell...
    280 1:1 on a P4 is gonna be tough though, i can tell you that... you can ask hipro
    he modded the hell out of his board and still hit only about 267mhz 1:1
    Dec 2003
    At work
    I agree with the comment made about the motherboard being cooperative.
    Even if the memory was willing to do it, the northbridge still must be willing to play ball and it may or may not be physically possible.
    Best of luck though....you're going to need it...
    Server: HP Proliant ML370 G6, 2x Xeon X5690, 144GB ECC Registered, 8x OCZ Vertex 3 MAX IOPS 240GB on LSi 9265-8i (RAID 0), 12x Seagate Constellation ES.2 3TB SAS on LSi 9280-24i4e (RAID 6) and dual 1200W redundant power supplies.
    Gamer: Intel Core i7 6950X@4.2GHz, Rampage Edition 10, 128GB (8x16GB) Corsair Dominator Platinum 2800MHz, 2x NVidia Titan X (Pascal), Corsair H110i, Vengeance C70 w/Corsair AX1500i, Intel P3700 2TB (boot), Samsung SM961 1TB (Games), 2x Samsung PM1725 6.4TB (11.64TB usable) Windows Software RAID 0 (local storage).
    Beater: Xeon E5-1680 V3, NCase M1, ASRock X99-iTX/ac, 2x32GB Crucial 2400MHz RDIMMs, eVGA Titan X (Maxwell), Samsung 950 Pro 512GB, Corsair SF600, Asetek 92mm AIO water cooler.
    Server/workstation: 2x Xeon E5-2687W V2, Asus Z9PE-D8, 256GB 1866MHz Samsung LRDIMMs (8x32GB), eVGA Titan X (Maxwell), 2x Intel S3610 1.6TB SSD, Corsair AX1500i, Chenbro SR10769, Intel P3700 2TB.
    Thanks for the help (or lack thereof) in resolving my P3700 issue, FUGGER...
  18. #18
    Oct 2003
    Terra
    2-2-2-5 @ 280 fsb with 8KDA3+ with 2 sticks 256mb
    100% stable @ 270 fsb ( maybe its stable @ higher speeds but i dare not to give it more then 3.8v .... )
    CPU : Intel Core 2 Extreme QX9650
    MB : Asus P5E X38 Rampage bios
    RAM : Team Xtreem 4x1GB DDR2 OPB handpicked
    VGA : Sapphire 4870
    Power : Antec Quattro 850w
    Storage : 1 x 60GB OCZ Vertex + 2 x 750gb WD 32Mb
    DVD : Samsungs DVDwriter Sata + Liteon DVD
    Sound : Creative XFI Xtrememusic
    Cooling : D-Tek Fusion + D-Tek Fusion GFX
    Monitor : Samsung 226BW
    Errorcode : An error occurred at address AC 20 DE AE FF BC ...... System halted.
  19. #19
    /dev/zero
    Nov 2002
    Germany, Berlin
    Not the memory but the board will be limiting you...
    I know it from my DFI (A XP)... and there's a limit around 272MHz max timings at 3.55V, increasing voltage does not help...
    so you should definately take every important onboard component into consideration.
    Good luck... you will be able to pull some nice clocks anyway :thumbsup: Around 265 is possible IMO.
    Xtremesystems.org
    i7-4820K * ryba 2-stager + 1-stager * EVGA X79 Dark * 32G Team Xtreem 2666C11 * EVGA GTX 680 SC Sig. * Intel G2 80G * Corsair HX1000 * Lian Li PC-70B * Watercool Heatkiller, EK Fullcover/Backplate for GTX, MCP355 Dual Setup@Koolance RP-402X2, PA120.3+Alphacool 360, Tubing 16/10.
  20. #20
    /dev/zero
    Nov 2002
    Germany, Berlin
    3.8V ??!!?? Man, didn't ya fear - yeah fear - the death of your A64???
    For how long did you run at that voltage? I mean, I would give it also 3.6V if I had an A64 BUT only if I could be sure it can take it... (fluctuations?!).
    Is there anyone running a high vdimm 24/7 with a64 anyway?
    Xtremesystems.org
  21. #21
    Bandwidth Freak
    Dec 2003
    280Mhz is achievable with BH-5, but only with rare ones.
    Most BH5 craps out @3.6V around 260-270MHz.
    Around 3.4V
    I did 290MHz @3.7v need a stable board (*DFI )
  22. #22
    Feb 2004
    Nashville
    280 on an Intel dual channel is going to be very tough with bh-5. Best I've ever done was 271 at 3.7v and it was barely stable enough to run sandra. You'd need some great sticks, a lot of voltage, and some extra cooling for the ram.
    The A64's do a little better, one because they're single channel and two because they tend to less agressive on the memory
  23. #23
    Oct 2003
    Lincoln, NE
    Yeah 280 3.4v is amazing but its only a single 256mb stick.
    DC is going to be pretty much impossible.
    System
    ASUS Z170-Pro
    Samsung 850 EVO (2)
    Corsair Hydro H90
    NZXT S340
  24. #24
    Mar 2004
    East Bay Area, CA
    Hes talkin 2x512 here not 2x256, they always seem to need more voltage.
    WinXP Pro
    3d03: 14185
  25. #25
    Bandwidth Freak
    Dec 2003
    most single channel BH5 users cannot do this. In DC it might need some more Vdimmm, still possible 280Mhz
