Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: VIA K8T800 socket 939 : what is maximum FSB you ever got?
    Fused
    Dec 2003
    Malaysia
    My friend(ianho@lowyat.net) manage to do 310MHz FSB on his k8t800 board... anybody did this far before?
    Is it a new WR for K8T800 chipset FSB ? never seen anybody go this far before....
    Spec:
    AMD64 3000+(Venice) @2.8Ghz,
    TT Silent Tower HSF with UFO Twin Blade fan,
    Abit AV8 3rd Eye mobo,
    2X512 Kingston KVR RAM,
    Leadtek 6600GT,
    Vantec Fancard,
    80Gb WD HDD,
    480W Enermax Coolergiant Red,
    Custom Case with 4 Cooler Master fans.
    CPU-Z Verified:
    310MHz
    http://valid.x86-secret.com/show_oc?id=20334
    Xtreme X.I.P.
    May 2004
    Hammel/Denmark
    i dont have any screenies from my ABIT AV8 times, but i did 320 without probs. i think quit a lot of people have gotten there with AV8.
    The whole world's hip and thats not cool !
    Rip Van Hippy
    Doesn't expecting the unexpected make the unexpected the expected ?
    Light travels faster than sound. This is why some people appear bright until you hear them speak
    Aug 2002
    London,Uk
    is that board k8t800 or the pro version? the locks were iffy on the chipset to say the least but afaik works 100% of the time with any divider locked in, just 1:1 the lock wouldn't always work. so yes, high fsb is piss easy on that chipset in anything but 1:1. from what i recall it was mainly the a8v asus boards that had some major issues hitting such high fsb, they most often wouldn't break 270mhz.
    its more likely to be the unofficial record as no one really uses the chipset for high overclocking and haven't for ages. tis a really nice chipset but just not as easy to hit as good speeds 1:1 and they also have a lack of well made boards with the needed voltage options.
    Mail Me | 3500+ , dfi sli-dr, g-skill la, 2x6800gt, 600w pcz, stacker case, air cooled
    Champion
    Jun 2002
    lab501.ro
    Varzmaster posted this a while back on a romanian forum:
    Abit AV8 / Winchester 3000+ @ 5X340 / 256MB Corsair 3200XL @ 340Mhz 3-4-4-10
    And with 4X multi (memory running at only 275Mhz, even if CPU-Z is showing 344):
ID:	31498   Click image for larger version.
    Fused
    Dec 2003
    Malaysia
    my bad...
    anyway nice FSB there Micutzu
    congrats
    and thanks for the info guys....
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by drunkenmaster
    sorry ... it is VIA k8t800 pro
    AV8 rev1.1
    and it is on Bios 20...
    Bios setting:
    External clock- 310/66/33
    AGP ratio- Fixed(66mhz)
    CPU V- 1.6
    AGP V- 1.65
    DDR V- 2.8
    NB V- 1.6
    SB V- 2.55
    HT V- 1.25
    DRAM Clock- DDR 266
    LDT bus fequency-FSB X 3
    RAM settings- 3,4,4,8
    Mar 2005
    Australia
    320 on the Abit Av8 1.1 that i had. no Screenys though and 3d was hella unstable on that thing :s
    Opteron 170 @ 3.0Ghz on air, Opteron 144 @ 3.1Ghz on air
    Feb 2005
    dang those av8 kicka**
    can they run dual channel?
    Mar 2005
    Australia
    Yep. though mine couldn't run 3dmark, or rather anything 3d at over 255htt~ with 66mhz AGP lock
    iirc it was a memory / lock problem
    running mem @ 266, or AGP lock @ 74mhz fixed the problem... totally messed up board imho.
    Aug 2002
    London,Uk
    yeah, 3d stable was very difficult iirc, that seems to often be the case with via chipsets, or maybe just on ath 64 stuff from them, not sure, i can hit hella fsb's with a divider, but tbh it doesn't help performance in the slighest, running 275 1:1 or at a guess 340/275 with a divider, given same mem speed same bandwidth will be achieved and almost identical performance. but above 270 or so 3d stable on my a8v, av8, and i think one of the gigabyte boards was not really possible.
    Mar 2005
    255~ with my Asus A8V deluxe, that's what i get for going 939 really early (july/04)
    Microsoft's homepage can be found at: thesource-dot-ofallevil-dot-com - interesting, no?
    Think of something witty and imagine it here.
    Feb 2004
    Bs. As. - Argentina
    A friend did 320 with a winchester 3000+ and patriot xbl asynch on an abit av8 3rd eye
    AMD 1700+ DLT3C JIUHB
    Abit NF7-S VDD VDIMM and VTT modded
    Sapphire 9800 Pro Vcore and Vmem modded
    Mushkin PC3200 2-2-2 Special 2x256
    Apr 2005
    Benchland
    Congratulations, Micutzu. It seems that the air from Ploiesti can really make some miracles.
    Champion
    Jun 2002
    lab501.ro
    Thanks guys, but i've said in my post, those are Varzmaster's screenshots, not mine.
    Jun 2005
    Hungary
    Nice fsbs
    When i set the cpu to 300*8=2400mhz, then the cpu is stable( i tested with Prime95) but the 3d doesn't work . I use mem divider 266, becouse my rams don't go together upper than 430mhz.
    Why not work the 3d?
    C2D e4300@9*375; Abit AB9; 2x1gb Samsung 800@750; C3D X1800XL; FSP BS II 350W.
    Dec 2004
    Denmark
    313x9 on A8V, 308 rock stable.
    Jun 2005
    Malaysia
    Quote Originally Posted by TMM
    So what you mean is just put mem on a divider and agp lock to 74MHz and its all 3d stable for 24/7 use?
    Just curious cause mine is not 3d stable as well and if this solves the probs then I'm gona try it.
  18. #18
    Feb 2005
    anyone got max fsb for an asus a8v deluxe rev 2.xx??
    does it exceed 300?
  19. #19
    Dec 2004
    Denmark
    Quote Originally Posted by kjâ„¢
    does it exceed 300?
    BIOS = 300, Use Clock Gen to push further.
  20. #20
    Feb 2005
    i meant that wat max fsb that this board asus a8v 2.xx is averagely stable?
    im sorry..
  21. #21
    May 2005
    Here's my latest attempt at highest HTT for my AV8. 345HTT. Screenie attached. Also CPUz verified at
    http://valid.x86-secret.com/show_oc?id=20654
  22. #22
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by ianho_
    yeah... this is the man ....
    to XtremeSystems!!!!
    ianho... is it 3d stable at those super high FSB...
    most people said anything higher than 260MHz will crash 3d application away...
    is it posible to play games or 3dmark benching at 300MHz HTT ?
  23. #23
    May 2005
    Quote Originally Posted by tictac
    Well, I just got my water cooling setup n running fine now. Finally got down to Priming n 3DM05 benchies. I'm still watching my temps with the new set up so I'm still being conservative with the OC. Right now am at 290X9. 3DM05 without a problem. I've been benching it like mad all day trying to get to the top of Lowyat 8 pipelines rankings. Now at #5 haha. So yeah, I can say 3D is rock solid at 290X9. B4 this I cudn't even run 3DM05 when I had the AGP fixed at 66. Then I heard sum1 say try 74. So I tried it n it works a charm. Been Priming 290X9 for the past 5 hours. If all goes well, will Prime n bench 300X9 2moro. BTW thanks 4 the welcome
    King Kong
    Intel Q6600(G0)|| Arctic Cooling Freezer7Pro|| Arctic Cooling MX-1 TIM|| Asus Striker Extreme|| 2X Nvidia 8800GTX SLi|| ATI 2400Pro 3rd GFX card|| || 150Gb Raptor + 250Gb Caviar WD HDD|| 1000W Silverstone Olympia PSU|| Logitech G5 n G15|| Corepad Eyepad|| Modded ATP3 Speakers|| Sennheiser HD580 Precision Headphones|| Apple Cinema Display 30in & 20in|| Silverstone TJ07.
  24. #24
    Mar 2005
    lol u made it..
    show us more
    A64 FX-57 CABCE 0516 WPMW First DI Run
  25. #25
    May 2005
    Quote Originally Posted by babyelf
    lol u made it..
    show us more
    Well, this just my 1st session of Prime n 3DM05 since getting my Venice 3000+ n AV8 combo. Pretty decent results I wud say. Gonna push for more soon. But here's the screenies of 290X9.
    N here's the ORB link showing the 290X9 setting passing the 3DM05 with flying colors. Hahaha. Who dares to say the AV8 can't do 3D above 260HTT now?
    http://service.futuremark.com/compare?3dm05=904590
    King Kong
