Hi Guys,
Yesterday i have buy my new System.
MSI K8N (nforce3) and a 3200+ Winchester! RAM i have OCZ 3200 EL Rev.2 2x512 ...
For the first i have the same Problems like you. Vapo cools down at 0 the MB Diode shows 255 and the System freeze!
I have tried many BIOS and tricks and i have found a trick to boot the System without Problems!
Also:
Dont start the Mobo and Vapo at the same time!
Start the Vapo first and let cool down the Temp how much you will.
Then make an CMOS Clear to the BIOS and start the Mobo!
Now dont go into the BIOS let start Windows!
When you go into the BIOS or you make a restart the Mobo dont will start again. You must al make now the CMOS Clear trick!
But for the first its not bad! Now we must find a way you can change your Settings without Problems!
I noticed then when you make this trick the Temp Diode allways rest at 40!
I think all the Problems was with the Diode! Can somebody make a BIOS with a option to disabled this Temp Diode?
Greetz Mrki
Sorry for my bad english!
Like a64 tweaker fix timnings and stuff :P
