What do you mean don't burn ?
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
dont get hot like hellOriginally Posted by TEDY
Intel Conroe E6400 - Intel P965 - 4GB DDR2 - 8800GTX - 320GB Western Digital - Dell 2007WFP - Windows Vista Ultimate
Exactly!Originally Posted by mag|c
nice one fx
i think 3ghz on a cabge is amazing, i havnt seen one over 2.8ghz yet, wost crap out @ 2.7ghz
I7 920 D0 (4.2GHZ HT on) // eVGA Classified // 6GB Corsair dominator 1600mhz // Asus HD5770 x2 // Corsair HX850 /--/
PA120.3 // EK Supreme LT // MCP655 // MM Ufo (soon to be TJ07)
Originally Posted by tatts
Many Thanks m8
I´ve seen here on XS another CABGE 144 @ 2.9ghz.
I think this stepping is good on 144 models....
I would really appreciate if you could tell me what you did to get this cpu to these clocks? I have the exact same stepping with batch 0028 and I only get 2700mhz primestable @ 1.7v and 2850mhz sp1m?Originally Posted by FxDi@mOnD
A64-tweaker ss would help, also info on your ambient, idle and load temps would help.
How does your cpu scale at low voltage? I can do prime @ 2490mhz 1.36v (according to cpu-z).
edit: Did you take of the IHS?
This is mine CABGE 0536 VPMW on modded Mach I. IHS still on.
With my ghetto watercooling does 2.8GHZ with 1.41V.
Would you please tell me what it does on air? I must do something terribly wrongOriginally Posted by Moonman
Will do. But on friday night when I come home.
I'll be waiting Just removed my IHS but didn't get any better overclock even though it lowered my temps with 10 degrees with 1.7v @ load . What settings do you use for read preamble and max async latency?Originally Posted by Moonman
Also, what bios do you use?
you have a 144 CABGE but its not a 0536 VPMW wright????Originally Posted by elmor
[Review] Core i7 920 & UD5 » Here!! « .....[Review] XFX GTX260 216SP Black Edition » Here!! «
[Review] ASUS HD4870X2 TOP » Here!! « .....[Review] EVGA 750i SLi FTW » Here!! «
[Review] BFG 9800GTX 512MB » Here!! « .....[Review] Geforce 9800GX2 1GB » Here!! «
[Review] EVGA GTX280 1GB GDDR3 » Here!! « .....[Review] Powercolor HD4870 512MB GDDR5 » Here!! «
What were the ambient temps for that CABGE at 2.9, 1.4V?
Someone else had excellent clocks "under air"....what he didnt say straight away was that the mobo was sat under an aircon unit at -2......
It sure is a GABGE 0536VPMW, my best result so far is 312x9 1.66v primestable. This is with removed IHS and with 1.7v i can get to about 2850mhz. More volts than that do nothingOriginally Posted by mascaras
Well, at least its doing good on low voltage. Atm at 2120mhz 1.15v
Why is that SPi time so bad? What timings did you use on your mem? Here's a run I did with a 3200+ Venice awhile back:Originally Posted by FxDi@mOnD
Any stability tests run? A SPI 1M is not exactly what I'd call stable...a 32m is sorta stable, but still nowhere near gauranteed to work. Good clocking though for CABBAGE POWA. 3dmark looped would be good...since imho, it's about as taxing as some Prime95 while stressing your other components.
YUP
