Sorry... ill just photochop a pic for you that explains it...
I believe he's refering the the spring clips on the xp90, they are held on by a screw in the center of the clips. If you where to shim the spring clips up from the hs base with a washer or two you would increase the spring tension from the clips since they are not a little further away from the socket and hs base.
It does basically the same thing as lower the retention base but instead of lowering the base of the retention base you move the spring clips on the heatsink further away to increase tension.
Work Rig: Asus x58 P6T Deluxe, i7 950 24x166 1.275v, BIX2/GTZ/D5
3x2048 GSkill pi Black DDR3 1600, Quadro 600
PCPower & Cooling Silencer 750, CM Stacker 810
Game Rig: Asus x58 P6T, i7 970 24x160 1.2v HT on, TRUE120
3x4096 GSkill DDR3 1600, PNY 660ti
PCPower & Cooling Silencer 750, CM Stacker 830
AMD Rig: Biostar TA790GX A2+, x4 940 16x200, stock hsf
2x2gb Patriot DDR2 800, PowerColor 4850
Corsair VX450
This should make more sense.
EDIT - The red bit is the washer.
This will increase tension on the clips... make sure your not fouling the heatsink cage with the CPU and you will be ok.
