Thats a good point xgman.
All the heatsinks I have used have only one clip, not two. Or screws that you can tighten up evenly.
I think that XG is right that the heatsink you have is dangerous for a chip without IHS.
Better get another heatsink before you go this route.
That said no IHS has some distinct advantages.
1-lower temps (duh... obviously)
2- no proken pins when the CPU gets stuck to the bottom of your heatsink.
I think that once the IHS is off, and you have the right heatsink its probably safer than with it on. I had my CPU ripped out of the socket several times when I was running a retail chip with heatspreader. Several people have bent or broken pins when doing this.
This was never a problem with the mobile chip as the core's smaller surface area didnt create the same suction force. So the heatsink/waterbock just lifted off like it did on socket A.
Only an advantage if your swapping chips and coolers all the time... but I tend to do that quite a bit.
