Thanks for the quick reply, much apprecaited!
Asus Maximus III Formula (2001)
Intel i7 860 (L924B516)
Noctua D14
Corsairs CMG4GX3M2A2000C2 (2 x 2GB) RAM
eVGA GTX480
DD-H20
BIX GTX360
MCP35X PWM
Creative X-Fi Titanium PCI-e
LG GGC-H20L Blu-Ray
Toughpower 850w Modular
GSkill Phoenix Pro SSD 120GB
HEAT
What's the melting point of the solder anyway, 90c?
If so I could put some boiling water onto it, that's like 100c
lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
*phone rings*
Friend: Do you have a spare PSU lying around?
Me: No why?
Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
Me: what PSU was that again?
Friend: Antec 480w
Me:........
True... but with 100c the cpu definitely will not die... with your method overheating it is still possible... man I want that IHS off real bad
*phone rings*
Me: No why?
Friend: Antec 480w
Me:........
Garrett,
Although I wasn't able to find it I remember reading about a member here trying to remove his IHS using boiling water, he just submerged the chip right into the water! I also don't remember what kind of luck he had with it, probably not much! People have tried many different ways to remove the IHS but very few if any were successful like Rubiconx3 was! I think the trick was having even and constant pressure on the IHS during the whole heating process, that way once the solder melted it would pull apart. Most people end up heating the IHS up enough to melt the solder but by the time they get something under the IHS to pull, the solder had already gone back to a solid/semi-solid state? I think this is why so many people end up pulling the die right off with the IHS, lol! Tricky business although I'm now very tempted to try!
Noctua D14
eVGA GTX480
DD-H20
BIX GTX360
MCP35X PWM
LG GGC-H20L Blu-Ray
HEAT
@ Garrett : I know you can melt solder with a lighter . if the boiling water method works make sure you post it =)
E6420 @ 8x499 (Clock Gen After That)
P5K Deluxe (Looking for mods to get me over 530 FSB)
2x1gig Ballistix 600Mhz @ 5-5-5-10 2T
Corsair 620hx
Evga 8800gts 320mb @ 676/1050 Vgpu@ 1.45v Vmem @ 1.9v
I've been thinking the last 15 minutes.... yeah I can actually think lol...
I could cut the black silicone, put 4 thin razors under the edges for the needed pressure... cut some foam and put it in a metal kitchen pan, put the cpu on top of the foam (to protect the resistors under the cpu) and then pour, and thus soak, the cpu in boiling water... it may just work
If the boiling water is indeed hot enough, then the solder will melt and the razors will do the popping for me
I won't be able to try it this week though, kind of busy, but at least I'm sure the cpu won't die of heat since it is not supposed to die until it reaches 140c
see here: http://www.xtremesystems.org/forums/...7&postcount=31
*phone rings*
Me: No why?
Friend: Antec 480w
Me:........
There was another "IHS Removal" thread where a member used a digital non-contact thermometer to measure the actual temperature that the solder softened up, well he came up with about 85C before the solder softened enough to remove the IHS. Unfortuelty he used a screwdriver to pry the IHS off and ended up killing 2x C2D processors because he pulled both the IHS and die off (poor guy)!
Noctua D14
eVGA GTX480
DD-H20
BIX GTX360
MCP35X PWM
LG GGC-H20L Blu-Ray
HEAT
I may have another solution.... my hair dryer gets up to 101c!!!
I have this digital thermometer that's priceless in this kind of job right?
*phone rings*
Me: No why?
Friend: Antec 480w
Me:........
Garrett,
What are you running for hardware these days? I havn't talked to you since back at the VR-Zone when discussing hard-modding our 7900GT's! (at least that is what I think we were discussing, it's been a while), lol!
Noctua D14
eVGA GTX480
DD-H20
BIX GTX360
MCP35X PWM
LG GGC-H20L Blu-Ray
HEAT
Alright I take it back FCG, lol! By the way how was it done, what removal method did you use (if you can share that info with us)?
Noctua D14
eVGA GTX480
DD-H20
BIX GTX360
MCP35X PWM
LG GGC-H20L Blu-Ray
HEAT
dang thats beautiful lol
3570K ● Asus V Gene ● 8GB Mushkin DDR3-2133 ● EVGA 660 Ti SC ● Seasonic X750 ● 128GB Samsung 830 SSD & External 1TB RAID1
SupremeFX SPDIF -> MHDT Constantine DAC -> Darkvoice 336i Tube Amplifier -> AKG K701
Garrett, the hair dryer might not be such a good idea lol, as it heats up the IHS slowly, it also heat up the processor itself evenly, make the die warm as well.
If you use something quick it'll be painless, the heat would melt the top before it even reaches the bottom.
I'm assuming the solder that keeps the die on the pcb doesn't melt as quick as the solder that keeps the IHS on the die right?
*phone rings*
Me: No why?
Friend: Antec 480w
Me:........
Rubycon !
I bet its easy for you to visit local Ace Hardware store to get a stick of PC Fahrenheit don't you ? Again, don't choose others, just stick to PC Fahrenheit !
When you got it, HERE on how to protect that die from crushing at it's corners when mounting HSF or WC block ! Trust me, you will never know how tilt those base when you start tightening those 4 bolts, learned it back from old Duron days !
Since C2D doesn't have those capacitors around the core, then it is even easier to make and goop art around it !
Now, never worry about "over" tighten those bolts anymore !
Come on FCG..... enlighten us with your knowledge.... share it here
It could make us all great IHS-removers
*phone rings*
Me: No why?
Friend: Antec 480w
Me:........
CPU:Intel Core i7 @4,51GHz Watercooled
Mobo:Asus Rampage 2 Extreme Watercooled
RAM:Corsair Dominator 3x2gb 1600C8D @1714MHz 8-8-8-20
VGA:Asus GTX285 @730/1584/1430MHz Watercooled
HDD:Velociraptor 300gb+Caviar 500GB+Caviar Black 1TB
Sound Card:SoundBlaster X-Fi Titanium Fatal1ty Pro
Dvd-RW:Samsung S223
PSU:Corsair HX1000W
Case:SilverStone TJ07B-W
W/C Parts:Swiftech Apogee GTZ,MCWNbMax,MCW60R,MCRES Micro Rev.2,MCP655,Thermochill PA120.3,Tygon R3400
Monitor:LG L245WP
Speakers:Logitech Z-5500
Mouse/Keyboard:Logitech G9/G15
Great job with the IHS, it looks yummy
Sound: Asus Essense ST | Wharfedale Diamond 9.1 | Norge 2060 Stereo amp | Wharfedale SW150 sub (coming soon)
Camera Gear: Canon 6D | Canon 500D | Canon 17-40L | Canon 24-105L | Canon 50mm f1.4 | Canon 85mm f1.8 | Rokinon 14mm f2.8 | Sigma 10-20EX HSM | Benro A3580F + Vanguard SBH250 | Bag full of filters and stuff
So Garrett did you get the bawls yet to pull the IHS off your processor? I have been seriously considering it but I still think the dangers outweigh the benefit (especially since I don't know if I would see any benefit since I have no idea how well my IHS contacts the die on my 3060)!
Noctua D14
eVGA GTX480
DD-H20
BIX GTX360
MCP35X PWM
LG GGC-H20L Blu-Ray
HEAT
