Originally Posted by palese
Yes and no, you'll need to boot with a stick of el cheapo ram and then change volts to get it working.
Q6600 G0 L720B058 @ 3.8GHz | Asus Maximus Formula (Rampage 0403 Modded) | 4x2Gb GSkill PC8000 PQ @ 1015MHz | XFX 9800GX2 XXX @ 680/2080 | 2 x WD Raptors RAID0 | 1 x WD5000KS | Samsung S203B DVDR/W | Samsung SM245B + Panasonic TX37LZD80
D-Tek Fuzion | PA120.3 + Shroud + Nexus Fans | MCW30 | Laing DDC w/ Petra's DDCT-01s Top Combo | Tygon 1/2" Tubing | T-Line
Anyone know my I can't do 433FSB x 9 with my E6600? I increased vcore to 1.5725, NB to 1.6 and FSB termination to 1.45 and its still not stable. I can boot into windows but orthos failed and restarted in 1 sec
i had this kit on my commando and it work without problems, i dont need a other stickOriginally Posted by palese
to change the vdimm.
do you have the newer SPD chri$ch? the one with EPP tooOriginally Posted by Chri$ch
Deam that is 3.9GHz you must have to expensive cooling and to much good CPU, and litle more to increase voltage.Originally Posted by DarkSephiroth
no, my kit was without EPPOriginally Posted by HermS
edit: SPD was 500Mhz 4-4-4-x
Where did you get ahold of the 0702 bios? I thought there wasn't one released yet..Originally Posted by Supertim0r
Hmmm thats curious, sounds the same as mine (week 42's) I also find that if I have a failed overclock the commando just will not recover while the Cellshocks are in. Doesn't happen with my HZ's or at least less so. I wonder what I'm doing differently.Originally Posted by Chri$ch
is def. voltage to low on your commando? or your cellshocks need 2v or higher to
boot.
ps: my kit was week 41 and i dont had any problems on Commando and P5B Deluxe
Shows as 1.84v at bios defaults, thing is I had the same problem with my P5WDG2 WS Pro. The sticks clock great (467MHz 3-3-3 @ 2.45v) but just struggle at low volts, very odd behaviour. I think it's better that I take the issue up with MSC and see if they know anything about this or have any ideas.
Sorry i've not the processor to have 590X9 .Originally Posted by Rol-Co
This 6600 is really fun for aircooling , you can give it 1.77V with 1.80 bios as you said, even with aircooling .
For the 557FSB Pi shot, i was at this vcore
This chip is so special.
Yes, there's some bug to be fixed, this board is not perfect yet.
Yes i have Fuzion WC set up. I just upped vcore and orthos if fine for nowOriginally Posted by Spacemaster
is it more stable then asus striker extreme?
