the memory range is anywhere from 170-186 meaning the first dimm. Please don't tell me the chip has reached its limit... it does the same errors at 210!!!!
Oh I would so cry....
Thx.... Yeh i want 7k :)Quote:
Originally Posted by DevilsRejection
do you have 1t enabled?
Just a quick question bout the DFI 250gb... CPC Enabled=1T & CPC Disabled=2T right?
Originally Posted by Rabbi_NZ
indeed
yepQuote:
bios settings as seen in sig
i must be blind where does it say it :confused: :(
This ram has enabled a higher STABLE cpu clock and has decreased my cpu temp :eek:
It really does get better with time btw
prime95 is the only thing now thats bothering me... Even with more voltage it still fails
DevilsRejection, attached pic for you
Seems strange my modules are doing so much better... I will share my entire timings tomoro.
One thing I did is set my timings according to these suggestions here @ DFI-Street... I set most timings more towards the loose side of the spectrum... but am still running 2-2-2-10-1T
sorry man iv forgotten what you have reached, was it 255 with 3.2v?Quote:
I need 3.5v as it started to error with 3.4v if left for more than an hour on memtest
Don't worry, Prime95 has a compatibiltiy issue with 90nm CPU's, you're fine :toast:Quote:
Originally Posted by Orker
havent tested past 250 properly yet, but Memtest seems 100% stable at 256-258 3.2v and I havent burned them in much
10x250 2-2-2-10 3.2v is 8hours+ Prime95, MemTest, SuperPI 32MB stable :)
With the 90nm CPU Prime is not going to run. Try P95v at 200fsb like I did and watch it fail. I also had it fail at 250fsb on the MSI Neo2 also with the 90nm 3500+ running TCCD at 2.5-3-3-8 and 3.0v. This RAM can run Prime95 with the same timings and voltage for 24 hours before I stop it on the DFI UT 754 board running both sticks!Quote:
There is a serious issue with 90nm and P95.
andyOCZ, congrats on the moderator job :toast:... didnt realise you were a mod
but if 90nm sucks @ prime then y r some people prime stable?
sooo!!! show me an a64 tweaker :toast:Quote:
what kinda bandwith are you getting?
I dont have AMD Tweaker or internet access at home... for now.Quote:
Originally Posted by aCidbAbY
But if someone can offer picture hosting for me I can email some screenies tomoro morning (NZ time)
I can only access internet from work for the time being and all free-hosting sites are blocked.
If someone could email A64 Tweaker and the latest CPU-Z to me it would be great too hehehehe
i aggree with orker b4 i could only get 2.5ghz stable now i got 2.55ghz and i can boot into windows with 2.59ghz:D
Cool thanks.. I just wont bother with it.. I hope they patch it soonQuote:
Originally Posted by andyOCZ
Something else strange but GOOD is happening to my VX ... I can now do 2-2-2-10 245mhz at 3.3v!! The voltage requirement has shrunk
http://img50.exs.cx/img50/9605/memtest86245.jpg
It seems that P95 may run on a 90nm for hours today and then 90 minutes tomorrow, the maybe 12 min, 3 hours, etc. The results apperar to be completely random. So someone may post as stable in P95, but are they? I can't run it more than an hour at 200fsb with relaxed timings. All my gear is good stuff too. That's proof enough for me.Quote:
mee too but i left mine higher.Quote:
have you noticed that we have so far had almost exactly the same expeirience with this ram? wth :toast:
lol i have noticed that
hopefully i will soon be able to pass 250 like you :toast:
I think i will get pass 250 easily if i had a DFI board
Can we start placing all our testing in the Official OCZ VX Thread as this one is getting so long....
yeh ive been wanting to do that but figured id wait until i think im at my highest possible oc :)Quote:
Originally Posted by cinders
Orker make that 3 sets that are close to the same. I have tested 167 passes this morning at 243 3.3v. I haven't tested higher but will do 244 and 245 at 3.3v later today. I hope I can pass like you did. Yesterday anything over 240 errored at 3.3v so I'm quite happy.
