#0, afaik.. In unlinked mode, ram speed isnt set by using dividers on the main PLL. The board has dual PPL, one for cpu, one for ram.
You kinda hint otherwise under 9. Dividers
I noticed a speed decrease when unlinked
Im a bit confused, in your statement you said that the higher CPU freq is you are guaranteed to get better mem bandwidth, correct ?Quote:
Originally Posted by Lestat
with that said, dropping the multi from 7 down to 6 reduces the CPU freq so it should also drop in memory bandwidth, thats from what i understand in your statement.
So whats the problem of losing mem bandwidth from 7 down to 6 when its expected to do so ?
But do C2D's maintain bandwidth regardless of the CPU speed say i get X bandwidth with 400fsb with 8x multi, even dropping it to 6x multi while having 400fsb still nets the exact same bandwidth ?
p.s. im not saying anyone is wrong here but i just seem to miss the point.
I differ when it comes to NB temperature. My NB doesnt get to over 55 Celscius when stressed with 1.45 NBcore. I have the striker to be exact.
Mine stays quite cool, and the heatpipes are actually working quite well. I stay right around 31 on the Asus probe, with an actual thermometer it gets to 45 where you were putting the temp sensor.
I would also say my best performance for memory/pi/3d/everything is in the 1T column. 4-4-4-8-1T @ 970 mhz beats everything else I could throw at it. 980 errors ou on pi32. 960 is prime stable. Its a funny board.
I have not popped mine off yet, but is it possible we are seeing yet another case of bad mounting, concave chipsets, and improper application of thermal interface material on these boards?
Ive found a glitch on my Striker. Sometimes when booting my Razer diamondback isnt recognized..so i unplug it and replug it.. soon as i replug it..the system reboots itself :stick:
Just RMAed my striker today hopefully ill have a replacement quick...this board rocks though absolutely a wonderful mobo IMO.
Anybody recommending another board over the striker? I will have a full refund in my pocket and was just going to buy another Striker but now im wondering if EVGA is just as good...
I have trouble with my Saitek keyboard. I have to plug / unplug it and it's recognized again. No reboots tho.Quote:
Originally Posted by Ibinco
I need help :)
i ve got 2 settings in my bios(striker) that i need cleared up:
- 1.2 VHT voltage
-CPU VTT voltage
Which one of these two is the equivalent of HTT voltage?!
From what i read here, i would say stick with Striker.Quote:
Originally Posted by sdumper
In response to Ibinco,
My Razer Diamondback loses itself on both my DFI Lanparty and my EVGA 680i. And has caused reboots on both. So Im pretty sure it isnt just the board. I never noticed this phenomenon on my AMD stuff before I got the Razer.
I noticed something weird on my evga board today.
All I did was add a dvd-rom drive and reverse the cable, and my windows boot time is now literally like 4 times faster than before.:eek:
I don't know what happened, but faster is always welcome:toast:
You didn't buy one of those directional cables, did ya now? :p
yes, imho, prolly better, and a lot less in price!Quote:
Agreed and i have been running orthos 4.4ghz now for lets see....2hours and 20 minutes ... not too shabby...1.63/1.65 vCore after vdroop...Quote:
Striker Extreme FTW
CPUz: http://valid.x86-secret.com/show_oc?id=149338
Icon57: Had to give Striker another chance the layout and probes were so cool ... lol
Obviously I can bench higher but right now I am more interested in everyday use and so Orthos is playing a big role. Also since I have only had this board back for a short period I'm sure it has a lot of hidden secrets to discover...this bios is amazing 0402 ... 0502 is not stable for me :(
Very nice job.
Im waiting for the first 680i to fall under $200 then Im gonna start making my conroe rig :D
BTW @ Sdumper. this is plug from BPC :D
and thanks for the info kunaak
Hey Plug these chips respond very nicely to phase so when you get your Mach II gt back expect big things! I think you know where to find a nice chip already lol...Quote:
Originally Posted by umop ap!sdn
Seems to OC fairly high too...
http://valid.x86-secret.com/show_oc?id=149488
I have had ZERO problems with mine. 6600@400x9 ruuning at default volts, 8800 GTX, XT-X, 2x WD 500GB RE2's. Rock solid stability compares easily with the P5W64 Pro which is my fav Intel board.Quote:
have an e6600 runs on 680i evga nice on water @ 3,850 and vcore 1,65!!My problem is the DDR2!! Have an G.E.I.L
DDR2-800 in 4-4-4-12-2t on 2,1volt..What is possible to these chips?get some tryin like 5-5-5-15-1t 1000?anyone had these chips?
thanks and happy xmas
janbatos
I ran Orthos for over 6 hours at 4.4ghz and then shut it down to play some with my highest OC ... :) Anyway I brought it back up and let it fold both cores for 48hours and not a single error in my WUs. This is plenty stable for me. Final verdict this is hands down the best socket 775 mobo I have played with.
Food for thought: 4717 ghz (http://valid.x86-secret.com/show_oc?id=149488) on this board and prior to that my highest was 4.6 on my P5W64 Pro (http://valid.x86-secret.com/show_oc?id=131381). I havent tried all the mobos but this is what is beats out from the ones I have tried:
P5W DH Deluxe (vmodded)
P5B Deluxe
P5W64 Deluxe
P5B Deluxe wifi (vdroop modded)
Im sure it will have some contenders soon but for me it was worth the money I spent on it.
Has anyone else noticed that the P5N32-E SLI has been removed from the ASUS USA Website? looks like the Striker Extreme is now the only 680i board they are going to sell. Guess ASUS got greedy and doesn't want to sell a board for under $400.
I was also wondering if anyone knows of a tutorial that explains what tests to run to test individual components of a PC so I can pinpoint where my bottlenecks are happening? I'm still at 3.2G and somewhat unstable since I cant Orthos blend for more than 2 hours and dual SP2004 errors after around the same amount of time. I'm starting to wonder if I should have started with a different board for my first system in over a decade. Maybe a nice intel board or something that will really 3D like a champ.
Cy
The P5N32-E SLI is still on the Global site. It's probably just a web site screw up although I'm beginning to wonder why AnandTech hasn't put up a review of this motherboard. I'm sure I saw where their review should be posted around Thanksgiving but now I'm wondering if the P5N32-E SLI didn't turn out to be the turkey!:DQuote:
Originally Posted by Cyaneed
I'm also having problems with dual SP2004 at 3.2GHz and above. In my case it's unstable almost immediately.
