I dont see max FSB for Q6600. Can you test litre more Q6600, and shere Max FSB with as.Thanks:)Quote:
Yes, because I maxed out at around 460 FSB... with the Q6600 :p (hope my pb comes from the CPU)
I stuck at 455Mhz with the QX6700. Seems to be the typicall FSB Wall in this Mobo with QuadCores.
wQuote:
Originally Posted by krampak
What MB?
can you share settings
vcore
vdim
multy
ext
thanks baz
With what MB?Quote:
Originally Posted by Thomas Olivaux
The Commando of course :)
I tried with the lower multi (x6) and with voltage increase for FSB Term, NB and SB.
I dont have eny more P5B DLX after I do 470FSB , bun no screnshot. My mb is must go to my friend and this is max at box and multi 8, vcore 1.52V. Full load 92-93C deam it is hot.Quote:
http://www.fotorola.com/uploads/2731f70d47.jpg
and today I see that Supertim0r can do 470 MHz with P5B DLX same as I, and when he get commando max what is he do is 400 MHz, I order commando and this is frickig me out
http://www.xtremesystems.org/forums/...125865&page=16
God damn it, i've had mine a week and i'm still waiting to get it up and running. I need a new CPU which i'm purchasing on tuesday next week.
Hopefully i'll get a good OC with an E6300.
finally someone actually posted some real results from the board...
getting damn tired of these "reviews" that have have no results and 200 pictures of the board...
Good stuff!
impossible to run over 395fsb :(
I have some numbers if you want.... :) DFI RD600, Asus Commando and Intel XBX2KR:Quote:
http://img225.imageshack.us/img225/6816/final2so9.png
I don't really know why are Spi numbers better on the Asus Commando than on the Intel badaxe2, i've used exactly the same configuration in all boards, except the 1T CPC on the DFI which couldn't be configured on the Asus and the Intel boards. Also the low result in 3dmark 2001 on the Intel board isn't normal, it should be the highest.
What is impossible to run at 395fsb?Quote:
Originally Posted by Supertim0r
I found the same when comparing the Commando to my P5WDG2 WS Pro at identical settings. :stick:Quote:
Maybe this Commando has some "tweaked" P965 ? :D Better superpi and 3dmark 2001 results than a 975X ? that's not usuall for sure.
ok, found the problem...max fsb in a few mins
Do share! :toast:Quote:
guys, does the commando swtich the strap at also 401mhz like the p5bdlx or at some higher speed
yup 401
vfsb 1.5v
nb volt 1.7
posted already results overhere kunaak
http://www.xtremesystems.org/forums/...1&postcount=19
same fsb @ watercooling , don't think its better then p5b dlx except memory speed and voltage's
Notice: Only DDR2-800 memory supporting JEDEC approved 1.8V operation with timings of 5-5-5 or 6-6-6 is supported on Intel Desktop Boards based on Intel 965 Express Chipsets.
So Cellshock PC 8000 1000MHz 4-4-4-12 will not work on 965 boards:confused:
nice start misteroadster
congrats
That is still not 470 MHz, try more setings or I will kill myself because I sell my DLX mb.:brick:Quote:
