G.Skill DDR400 2-3-2-5 2GB ZX Test Report: OC sessions
Hello guys,
Today I am showing you some OC sessions of the value RAM 2GB ZX that should be OC'ing pretty good.
The chips that are used is unknown to me, so don't ask :p:
***F1-3200PHU2-2GB ZX***
Flavor: 2x1GB and 1x1GB
Rated speed 1: DDR400 2-3-2-5 2.6~2.75v
Rated speed 2: n/a
Chip: OEM IC
PCB: B6U808 v1.1
http://www.xs4all.nl/~famchow/Memory...ZX/1%20021.jpg
The modules...
http://www.xs4all.nl/~famchow/Memory...ZX/1%20020.jpg
A closer look...
As you can see the default timings are 2-3-2-5 at a clockspeed of 400MHz DDR. The voltage range is 2.6 ~ 2.75v.
In this testreport I will use 2.8v as maximum voltage.
Test system:
3000+ Venice week 17
DFI Lanparty nF4 SLI-D (bios 623 official)
Tagan 480W-U22
First some stock tests:
http://www.xs4all.nl/~famchow/Memory...325_32MSPI.JPG
http://www.xs4all.nl/~famchow/Memory...25_Everest.JPG
DDR440:
DDR500:
DDR520:
The average OC lies between 250-260MHz with timings 3-3-2-5.
Higher speeds can be achieved but it really depends on the modules and your luck. I do not recommend higher voltages then 2.8v for 24/7 use.
In CPU-Z you see HX, that is a mistake in the SPD. It must be ZX offcourse :)
