http://rosenson.mine.nu/upload/upload/38sek.jpg
My 3400+ 64bit and ocz 3500eb on vnf3 250, does it in 39sec. Stock speeds, etc... Is that any good?
no thats 1x512MB OCZ PC4400 EL Gold Ldt!Quote:
Originally posted by aoc007
Is that running EB? Very nice mem speed, try and up the core! :toast:
Bad timings, huh? ;)Quote:
2,5-4-4-8 .... (SPD)Quote:
no thats the crappy 3400+ ....:mad:
my 3500+ s939 and my asus av8 deluxe arrived today, but it's too late to test, it's 11.22pm.
XP-M 2400+
NF7-S v2.0
http://www.hpautoelectrics.com/OverC...super%20pi.jpg
I got 35s on mine A64 @ 245 x 10 Mhz OCZ EB @ 3-3-2-8 1:1
better than nothing:
was hast du am epox gemacht um so einen hohen fsb zu bekommen?Quote:
ich hatte noch nie ein epox :D
my mobile run on a dfi lanparty nf2 ultra b. but i can't go higher with my watercooling
um bei englisch zu bleiben ;)
:lol:Quote:
LP B rulez :D
Seems that my tweaks gained something ;)
http://mbnet.fi/elixir/3.2E/SPI-1M-28.PNG
And thats R404 Mach2 cooled.
That looks good The Stilt :D
P.S. Any updates on the Datapage of the Super-Pi yet??.......The page seems to be missing or something....... :)
very nice stilt, what mobo?
IC7-Max3 @ IC7-G Downgrade, VTT, VDDR mods, IC7-G 24 bios.Quote:
did you just flash it to the abit ic7-g bios?
Why do that anyway?
Yep, hexedited IC7-G bios. It must be edited because it wont go in if it hasnt been edited. IC7-G bios is littlebit faster and, its more gentle when it comes to GAT settings ;)Quote:
Why do that anyway?
It's slower than 22 or 21 ones.........check it out over Pi-fast or whatever..... ;)Quote:
Whats the best IC7-G bios? The newest?
Shaved off another second with 5 more mhz on the fsb.
Thats on air with the top and rear fans in my PC-65 swapped out for 80mm tornados and a 92mm tornado on my SP-94. 1.85v set in bios.
As for me, it's the 21 and the 22 ones(the same)....Quote:
