then you´ll need vmod my friend :)
Yes i do ;) And i am looking for an easy guide :) So please help me :D
EDIT: I found a good guide :) http://www.xtremesystems.org/forums/...threadid=27805
by newbeetle
M/BFABIT NF7 V2.0 ‰ü ( C3C003401 ) / BIOSFNF7D_23
CPUFMobile Athlon XP-M 2500+ 0351MPMW / L12‰ü
CPU CoolingFuƒNƒ:banana:‚Ê‚¢‚ă}ƒXIPro‚Qv•u^E ¹‹‚_‚ñIfor AMD64v+LN2
Chipset CoolingFSwiftech MCX159-R +Dry Ice
MemoryFTwinMOS PC2700 BH-6 256MB x2 / 5-2-2-2.0
VGAFNVIDIA GeForce 2 MX400 AGP 64MB
HDDFMaxtor 5T040H4 /U-DMA 5 (ATA100)
PowerSupllyFZippy-460WSi3.3V‰üj
VcoreF2.10ViÝ’èj/ VddrF3.33ViŽÀ‘ªj/ VddF1.90ViŽÀ‘ªj/ VioF3.78ViŽÀ‘ªj
OSFWindows Server 2003
”õlFCPU”{—¦16.5”{ / LN2—â‹p / 8rdavcore-0.8.5bŽg—p
http://homepage2.nifty.com/NewBeetle/img155.gif
:p:
cpulloverclock and zyx
Nice overclocks! :P
amezing:slobber: :slobber: a 1 sec faster on you´re on par with the nr.1 barton :) go 4 it :p: :DQuote:
Originally posted by zyx
:p:
zyx's score is uppon unmoded Lanparty mobo and Prommie 404 :D
What's super pi?
AnyBody else Crazy enough Other than me to run the 32M Test :stick:
Test is Great for checking stability
P4C800-E Dlx
P4 3.2C
Ocz PC3200 Plat LE, 1:1 @ 2-2-2-7
Cpu Water Chilled
Hehe. Already done it ;) It has to be somewhere in this thread. But for you, here ya go :D
my best, at this timeQuote:
P4C800-E Dlx
P4 3.2C
Cpu Water Chilled
http://learn.chez.tiscali.fr/3.0C/SPI-32M-4350MHz.png
http://learn.chez.tiscali.fr/32M.php
does dualchannel affect the 1mem test? asking because i got 34 sec by now with singlechannel on an prescott4,15ghz with memory@ 238mhz cl2-2-2-5
It ought to.
My dualchannel 2.4A gets the 34sec limit at 3801MHz (211FSB) so yes it does make a difference.Quote:
Improved from 38 sec to 36 sec, on my new ghetto waterchiller (so far :))
Picture:
http://www.try-this.dk/36sek.jpg
EDIT: for pictures of chiller, go here:
http://www.xtremesystems.org/forums/...threadid=34458
Here is my best so far on my 3.0C/P4C800-E rig:
http://users.adelphia.net/~youmansj/...PI%2036sec.jpg
Just done
22.29 in SuperPiM32.
The Cascade can handle everything in 64 bit OS under 2 volt.
my highest OC under 2 volt is 3300.
Then the multi must be 14 (13 is to high to fastest timings)
Easy.
If I try higher than 2 volt It hold for about 20 minuts, then the Cascade gets hot.
I'm close to that point, where I can finish BEFORE its gets hot
That like "Lucky Luke ":D
nice score :D
Congrats Tom Holck
i test my 2.4A with C02, and i think this enough this time...
next time i take some LN2 and i have to mod this mobo first and get 3.0E ;)
http://http://verdict.puuhis.net/2.4.../sp8m_5_22.jpg
http://verdict.puuhis.net/2.4A%20Pre...sp1m_29sek.JPG
1,8V with prescott? How is it possible? Everyone has no-boot overo 1,65V
CO2 cooling could be the reason ;)
Yea agree, bias_hjorth,Quote:
I remember when everybody said that 1.8/1.85 was the max on the old P4. With cascade cooling sub -100c the best OC was close to 2 volt.
I have not tried Prescott yeat (FX-53 is better at this point, like a 6+Ghz Prescott!!*) but with sufficient cooling the Prescott can take volt, for sure.
*2400@3300x14 is like a FX-62:slobber:
yup and that not even long ago :)Quote:
6Ghz pressi should be a "tad" bit faster than a fx53 even at impressive 3300 :)Quote:
someone in germany feeds his 2.4er prescott with 1,75 with only mach2 and he gets an astonishing 4,4ghz super pi 1m time of 29 sec ;)
sry for tipo. meant 29 sec and not 20 sec ;)
