http://valid.x86-secret.com/show_oc?id=19957
2800 :D
311*9 at 1.475v in bios....
http://img163.echo.cx/img163/3463/su...b3111cc.th.jpg
2800 :D
0517BPDW 3200+ Vapo LS 10x330@1.632v BH-5 2-2-2-5 275@3.7v
cpuz verification: http://valid.x86-secret.com/show_oc?id=19999
http://www.jpop.com/gocchin/venicecpuz.jpg
SuperPi reasonably fast @ 3216mhz... with tight timings:
http://www.jpop.com/gocchin/venicesuperpi1.jpg
3500 LBBLE 0515FPAW [IMG]http://img146.echo.cx/img146/6521/32m2531fpaw3us.jpg[/IMG] Got a new stepping SD : CABGE 0516WPAW to try later. The 3500 LBBLE 0517APOW was ok but not as good as this one.
First post, w00t
LBBLE0515APAW
Mine seems to be the runt of the litter, cannot go over 2.8 prime
http://img.photobucket.com/albums/v7...-venice-OC.gif
2.8 is fine in windows, stock Vcore set in bios
http://img.photobucket.com/albums/v7...Computer/2.gif
2.8 will prime for a little bit but will always fail. Using 1.475 Vcore there, it ran for a while but now it seems to fail; it is inconsistent. Over 2.8 will always fail, even if I go over 1.6 Vcore it fails just as fast. Tried memory dividers and they did nothing.
This is annoying me. 2.75 Ghz is prime stable for hours with 1.475 Vcore, but 2.8 Ghz will NOT stabilize in prime for more than a little while, despite using over 1.6 volts. That is such a sudden wall :(
The ram is definitely good for more, i have ultra loose timings and i've tried all the dividers, tried increasing Vdimm and lowering it as well, but 2.8 Ghz will not become prime stable. I think i have one of the worst 3200+ APAWs but 2.75 Ghz with less than 1.5 volts, i shouldn't be complaining.
28 sec. at 2880 with 1.425 X 113%. [IMG]http://img91.echo.cx/img91/1617/28secpifpaw2hr.jpg[/IMG]
By Cal930
M/B:EPOX EP-9NDA3J VddrMod
BIOS:5215
CPU:Athlon 64 3000+ 0517EPMW
CPU Cooling:ZM-WB+Bath Pump+Ice(Water Temp2℃ Room Temo18℃)
Coolant:Deep Seawater MarineGold
Chipset Cooling:None
Memory:Aarare Original Rev1(SP)512MB×2
VGA:ATI XPERT 98 PCI 8MB
HDD:MAXTOR 6Y80P0
PowerSuplly:OCZ PowerStream 520W
Vcore:1.73V / Vddr:3.76V / Vio:3.74V
OS:Windows Server 2003
http://cal930.sakura.ne.jp/cgi-bin/c...3355_24_29.png
Dont know steeping or anything but I guess its the one with the L since its a 3800+
Vcore was at 1.625
Cooling is air but I cheated since it was cold out so I put a house fan blowign in my case. room temp was at 20C.
CPU temp maxed at 55C usually around 49C.
Pi pic is my best time and so is 3d mark. iT is stable enough to run those programs. Running 2750 right now, just got done playing counter-stike. I had trouble getting 2.7 stable untill I went to 1.600 volts. I can get more system info if needed.
Hi all,here is my first post :D
Venice 3200+ LBBLE 0515 GPBW
(air cooling Cooler Master Hyper6)
DFI lanparty NF4-D
Gecube X700 PCI-E 128mb
Corsair 3200XL REV 1.2 (256mbx2)
Enermax EG475P-VE
My first post :D
Here is my 3000+ LBBLE 0517 DPMW
http://img163.echo.cx/img163/3527/ve...300145v3ft.jpg
i have a LBBLE 0517 APNW also and will post results later coz im still testing :)
Originally Posted by TekXoID
Thx :D
here u go
http://img241.echo.cx/img241/5996/a64tweaker5pp.jpg
a64 3000+ venice DBPW CBBLE 0512
Here is my scores, I want mone any ideas ?
315*9 1x1 2T
http://img55.echo.cx/img55/1280/315x97vq.jpg
282*10 1X1 1T
http://img129.echo.cx/img129/9462/282x101x14yu.jpg
i sold my DPMW and bought LBBLE 0517APNW :stick:
9x305@1.65V(bios) is the last prime stable OC however it is benchmarkable 9x312@1.7V(bios)
- 3200+ 0517 BPEW Z....4XX
- 1'66V
- Cooler Master Hyper 6 + papst 40cfm
- 35ºC idle 49ºC full
- DFI SLI-D, Mushkin Level II 3'3V, etc
http://img211.echo.cx/img211/7399/caliente5ms.th.jpg
It does 2600Mhz at 1'37v and 2650Mhz at 1'40v (for spi 1MB).
- 3200+ Venice 0517BPEW
- 1.64V Windows
- Zalman 7700CU
- DFI nF4 Ultra-D
- SP32M stable 2921MHz @ 1.64V
- 3200+ Venice 0517BPDW
- 1.64V Windows
- Zalman 7700CU
- DFI nF4 Ultra-D
- StressPrime2004 2906MHz @ 1.64V for 1h10min. now, I try 24h :D
BTW, for BPDW it's second boot, never seen default speed :slapass:
3200+ Venice
LBBLE 0515 FPBW
http://img57.echo.cx/img57/898/cpunumber4oc.jpg
2800mhz (10x280)
http://img26.echo.cx/img26/5023/desktop9hk.jpg
1.55v bios
1.5 in windows
~Fizz
http://img82.echo.cx/img82/4240/32m8ct.th.jpg
My new Cpu Venice 3000+ LBBLE 0517APQW.This Test was with Ram @166Divider.my Ram can handle 295mhz 1:1@ 2.5-3-3-7-1t,but with 180 Divider i have Problems with stabilitiy if i use the same Timings :(
OEM 3200+ Venice from Monarch in early May
2730 MHz, 730 MHz gain
0516EPEW
SmartGuardian says 1.61v, multimeter says 1.664v. I'm using 1.45v x 113%
Coolermaster Hyper 6
MBM5 says 45C max
DFI NF4 Ultra-D with the 510-3 BIOS, 2x512MB G.Skill LA
25h Prime95, in screenshot
ultra-d
watercooled
the temps are IDLE!!!
geil ultra-x @ 305 2,5 4 3 6
http://img81.echo.cx/img81/2199/ebay9qu.jpg
http://wowgame.free.fr/3000+%20939/L...517%20EPAW.jpg
http://wowgame.free.fr/3000+%20939/L...z1.52v11H4.jpg
http://wowgame.free.fr/3000+%20939/L...-1.584vspi.jpg
Home made watercooling :banana:
not finisht :D
it's too hot outdoor :(
next test Max Screen, i think 3175-3180Mhz at ~1.7v soon :D
My Venice
CBBLE 0512 DPAW
http://www.directupload.net/images/050513/sxR9gdvf.jpg
http://5-7.pyrokar.lima-city.de/liste.jpg
http://5-7.pyrokar.lima-city.de/2800%20Prime95.jpg
CPU-Z Validation
http://valid.x86-secret.com/show_oc.php?id=21161
all aircooled
runs also 2700MHz wirh default vcore
Thanks e7e9h3n :toast:Quote:
Originally Posted by s7e9h3n
Here is some stabitity test of this lovely baby :D
Prime stable at 2700mhz 300x9 vcore 1.39v,
and super Pi 32m pass at 2900mhz 290x10 vcore 1.52v.
As all we know ,3ghz on air was a high mountain of the Venice chips,
so I will try h2o cooling on it later,post more results soon :)
Heres my max stable. Bought from Cheif Value OEM
Any Idea on how many watts a 2800mhz 3000+ LBBLE 517 at 1.712v is? :lol:
Here are some initial results of my 3000+ 0516GPEW Retail from cheifvalue...
http://img226.echo.cx/img226/6969/gpew2700prime1qv.jpg
I'll report back later with more results!
3500 Lbble 0515fpaw also a 25min 32M Super Pi and an Aquamark screen below. Don't know how much more it can go, getting ready to paint with liq. electrical tape and cut some foam. [IMG]http://img230.echo.cx/img230/4319/29387qa.jpg[/IMG]
