great pics!
great pics!
I will post pics of my system as soon as my camera returns from LA.
I am running an AMD 3200 754 on a K8V delux v2
My block is a Swiftech MCW5002-64T with a 266W Tec powered by my Antech truepower 550W with 36A on the 12V line. Water is then cooled by a BIX2 with two panflow 109CFM fans.
My idle temps are -3C (lowest my temp prob will read) and rises to 11-13C under full load.
all my crap is mounted in a CMstacker
wow very niceQuote:
Originally Posted by labrat23
Here you go this is my tec setup, not really pritty but it works.
http://img213.imageshack.us/img213/5...3948er4.th.jpg
What's the routing on your system like? The pump looks like it goes to your video card, but there's some weird Y or T connector there--what's that all about?
Originally Posted by THE JEW (RaVeN)
I was waiting for someone to give me heck for that!! :cool: I have the Y turned wrong. :slap: It flows from the pump to the y (drain plug) and then up to the rad. out of the rad into the cpu out of the cpu to the videocard. then up to pay res and back down to the pump. I really need a new case, and I really, really need to change the y on to its sideinstead of the way it is. I didn't notice what I did till I had it all full.
Ah, ok, I see it now. I just couldn' figure out where your pump flow was going :lol:
I plan on changing the y on my next refill!! :) When I seen that I made a dumb @$$ attack it was too late I had the loop over half full! :( I said the heck with it and took a pic anyways to post in here because this is my 3rd setup and the I decided I need to get a system pic posted in here!!! :DQuote:
this is what happens when I'm not paying attention good catch.
Wrong thread?
Im confused mate.
I want to try making a TEC memory module. How much more of an OC can you get with them?
there was one made and posted a few pages down it got him 25 mhz more
unless you are pumping huge volts through the ram it is pointless tho a fan is more than enough
P.s A mod needs to run through this thread and remove all the posts with The RED X
My wife's PC, I put the Vigor Gaming Monsoon in her PC, because I found it inadequate to cool my naked Opty 170, but it's good enough for her 3200 Venice.
http://i67.photobucket.com/albums/h2...osfirstrig.jpg
http://www.nvnews.net/vbulletin/atta...7&d=1175243190
http://www.nvnews.net/vbulletin/atta...8&d=1175243190
http://www.nvnews.net/vbulletin/atta...9&d=1175243207
http://www.nvnews.net/vbulletin/atta...0&d=1175243207
http://www.nvnews.net/vbulletin/atta...1&d=1175243221
http://www.nvnews.net/vbulletin/atta...2&d=1175243342
http://www.nvnews.net/vbulletin/atta...3&d=1175243342
jAkUp: Glad to see your here to! We've been reading each others posts from nvnews.net for a while now. Can't seem to get enough staring time at your PC, what a piece of art work you have there my friend:shocked: . If I can just say one thing, I would water cool your 8800's, that would be the icing on the cake bro....
Take Care
http://farm2.static.flickr.com/1058/...49455b.jpg?v=0
http://farm2.static.flickr.com/1338/...c809aa.jpg?v=0
jAkUp that set up is a thing of beauty.
I'm going to try running my FlexXLC on a Peltier chilled loop. They are good for 1150+ and don't get too hot on water, to hot to touch over 1066 after a few minutes of memtest on air.
The XLC heat spreaders are removable so they might be a good place to start. What wattage would you need to accomodate though? And would you strap TECs to both sides or use a heat spreader?
Swiftech Apogee GT custom 226W Qc Peltier block:
http://farm3.static.flickr.com/2323/...b29765.jpg?v=0
Installed on my E4300:
http://farm3.static.flickr.com/2139/...b09ff5.jpg?v=0
It's pumped by this 3000L/H monster:
http://farm3.static.flickr.com/2383/...c287e9.jpg?v=0
In a dual loop with a VAG Motors radiator:
http://farm3.static.flickr.com/2159/...24edd8.jpg?v=0
The third loop is for pressure relief and temperature monitoring but will include this HDD block:
http://farm3.static.flickr.com/2028/...ebb069.jpg?v=0
It will be sandwiched to the RM1 radiator (radiator on the hot side) to chill the Northbridge, Southbridge and RAM.
I also plan to put my 350/540 on the CPU and TEC the HD2900XT which has already been prepared with Red Gasket Sealer and Modded with copper shims in place of the thermal pads and paint stripped from the contacts to the heatspreader:
http://farm3.static.flickr.com/2313/...e00eea.jpg?v=0http://farm3.static.flickr.com/2005/...e389b1.jpg?v=0
Wow that is pretty epic TEC setup, Tyne. How is the progress coming along? I hope you didn't run out of money/time.
Out of time at the moment, juggling two women is eating into my modding time lol. Also planning to leave the TECs until I am totally happy with the water loop.
I'm currently planning a 5-way split
GPU
CPU
RAM1
RAM2
Fusion (NB)
I've been given some [insert company name here and I will die] technical documents on automotive cooling system design which I need to read.
oh my... g)-(ost where did you get that block? post some temps with that thing :O
homemade blok, work progress HERE
Finally able to post here... Hope you all enjoy.
http://i279.photobucket.com/albums/k...loodTEC009.jpg
http://i279.photobucket.com/albums/k...loodTEC010.jpg
http://i279.photobucket.com/albums/k...loodTEC011.jpg
http://i279.photobucket.com/albums/k...loodTEC008.jpg
http://i279.photobucket.com/albums/k...loodTEC013.jpg
http://i279.photobucket.com/albums/k...loodTEC016.jpg
http://i279.photobucket.com/albums/k...loodTEC020.jpg
http://i279.photobucket.com/albums/k...loodTEC021.jpg
http://i279.photobucket.com/albums/k...loodTEC026.jpg
http://i279.photobucket.com/albums/k...loodTEC027.jpg
http://i279.photobucket.com/albums/k...loodTEC029.jpg
