Try other bios for RE best is 0121.....
But i have a Rampage Extreme X48, so no Rampage II Extreme.
If you mean bios 0121 for my board, that bios is only good for 1M and besides, i could not change multuplier in that bios. :shrug:
Thanks for the suggestion though. ;)
Yes this is the best bios for 1m ....for 32m I always go for last available ...
p.s.
RE not RIIE (RIIE is on the bench table at the moment so I made this typing mistake) ..I made a change on post above.. :)
PL8 at 630+ FSB ain't gonna happen for me, at least not with this (water)cooling i'm using. ;)
Do you know what services i can disable to gain some seconds and what to chop off?
I disabled some services with zero gain. Als tried to disable the clock in the taskbar and disable the quicklaunchbar without any gains. :(
hey guys
just fired up this Asus board as i need to use it tomorrow on a show
and as all Asus boards it gets you suckered into SuperPi lol.....i dont have a lot of time on it but here is a start for 7.xx category :)
unfortunately this bios is missing a couple of values i need and i havent tested many combinations to see what works best but this sob has some potential anyways heh
why is CPUTweaker locked on this board WTF....:confused:
4354.9......dinos22............7.59.985....25x174 ....1045mhz.....7-7-6-20....2/12....X58
http://img22.imageshack.us/img22/420...5s32msuper.png[/QUOTE]
Read that it is (or was by now, not sure) not possible to change timings with cpu tweaker on any Asus board.
My OS must be really cr@p for 32M, i just cannot touch the efficiency of the likes of Kintaro, cheapseats, ToyTen or 3oh6, not even close! :mad:
Did a desperate attempt at sub 11 minutes with 4x1GB CSX Diablo.
I was actually able to run the timings as tight as a virgin despite 4 sticks of ram!
http://img.photobucket.com/albums/v6...Msub113969.jpg
Efficiency still sux though. :(
This time i disabled a hell of a lot services, killed a lot of processes, killed explorer, quicklaunch bar, clock.
Olive theme, maxmem 600, copy waza, pi_rec from cheap, pagefile 512-512, realtime prio, core affinity, etc.
I even uninstalled my ati vga driver!
:shrug:
Managed to shave of 1 notch of FSB, from 7x567 to 7x566:
http://img.photobucket.com/albums/v6...32M1059906.jpg
For 16x
4027......geobot24............16.59.344....20x201. ...805.4mhz.....7-7-7-21....1/4....AM3
http://www.hwbox.gr/attachments/hwbo...ge-955_lcc.jpg
For 17x
3737......geobot24............17.59.281....18.5x20 2 ....808mhz.....7-7-7-21....1/4....AM3
http://img263.imageshack.us/img263/3...lcc1759281.jpg
Way to go my friend George :up:
Moar, moar :D
Thanks mate!!
One more run from today with lower cpu frequency but with more memory:D:D
3977.5......geobot24............16.59.453....20x21 5.....860mhz.....7-7-7-21....1/4....AM3
http://img109.imageshack.us/img109/9531/955lcc16x.jpg
After tweaking and trying for almost 2 days i finally am in the same ballpark as the 32M big guns for efficiency. (well, almost)
Still not on top but better than i've ever had it. :)
I lost count of the number of 12.00.xxx runs i had but i can assure you it was more than 10. :D
http://img.photobucket.com/albums/v6...12min35576.jpg
The trick was to set AI clock twister from light to moderate, stopping about 15 services, checking the CDT box of SPi tweaker and some more tricks.
I think i can take a rest now. :D
3798,2......Oldscarface......16:59:953......262x14 ,5......873,4mhz......6-5-6-18-1T......3/10......AM3
4075,7......Oldscarface......15:59:688......263x15 ,5......876,7mhz......6-5-6-18-1T......3/10......AM3
4418,9......Oldscarface......14:58:563......260x17 ......866,7mhz......6-5-6-18-1T......3/10......AM3
hey Old
what cooling do you have on the CPU :)
great
dont waste time with air....it's always better subzero :D
i gotta do some efficiency testing soon when i find a suitable C3 chip and do some comparisons with a couple of different boards
looks like you set some kick ass benchmarks to go by....i like it :D
giga & asus top end stuff mate
4398.7......kintaro.............7.58.203....21x209 .5 ....1047.4mhz.....6-8-7-20....2/10..X58
3442.2......kintaro..........09.58.234....17x202.5 ....1012.5mhz.....7-7-5-20....2/10..X58
3112.2......kintaro..........10.57.219....15x207.5 ....1037.4mhz.....7-7-7-20....2/10..X58
2834.7......kintaro..........11.58.157....14x202.5 ....1012.5mhz.....7-7-5-20....2/10..X58
