Thanks FastGM :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
90.202.400 2x Intel Xeon E5-2673 v4 @2.30GHz 80threads BMI2 FastGM
67.915.987 2x Intel Xeon E5-2673 v4 @2.30GHz 40cores BMI2 FastGM
Merry Christmas to everyone!
Thanks Dann & ankan!Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
104.212.806 AMD Ryzen Threadripper 3 3970X @4.1Ghz 64threads pop Dann Corbit
57.237.756 AMD Ryzen R9 3950X @4.0Ghz 32threads pop ankan
My best wishes and Happy New Year 2020 !!
I got a very nice New Year gift for this list! :up:
2 days ago i received +50 chess-benches and most off them are from AMD EPYC cpu's!
Thanks to Patrick owner from Serve The Home : https://www.servethehome.com/
I have arranged them in my spreadsheet list with all needed data and will update them here also..it will take some time to add them.
So you can regular check list with these new benches..will start from top to botton.
When they are all added to list i put here a few results to tell update is done ;)
Apriciate very much for sending me all these benches Patrick ,a hugh Thank you!! :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
275.142.992 2x AMD EPYC 7742 256threads pop Patrick @ ServeTheHome.com
150.668.610 AMD EPYC 7742 128threads pop Patrick @ ServeTheHome.com
138.905.646 AMD EPYC 7702P 128threads pop Patrick @ ServeTheHome.com
134.330.190 AMD EPYC 7702 128threads pop Patrick @ ServeTheHome.com
127.342.246 2x AMD EPYC 7601 128threads pop Patrick @ ServeTheHome.com
124.207.176 2x AMD EPYC 7551 128threads pop Patrick @ ServeTheHome.com
121.133.579 2x AMD EPYC 7501 128threads pop Patrick @ ServeTheHome.com
117.380.588 AMD EPYC 7642 96threads pop Patrick @ ServeTheHome.com
Thank you very much Patrick :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
174.000.932 AMD Ryzen Threadripper 3 3990X ES 128threads pop Patrick @ ServeTheHome.com
207.181.871 AMD Ryzen Threadripper 3 3990X @3.6Ghz 128threads pop Lukas Cimiotti
Thanks Lukas :up:
CPU: Stock Ryzen 3900X
Nodes/S: 43,299,797
Threads: 12c/24t
BMI2/Pop: pop
Nodes/S: 33,0169,502
Threads: 12c/24t
BMI2/Pop: bmi2
Thanks for all these benches :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
122.127.056 AMD Ryzen Threadripper 3 3970X @4.1Ghz 64threads pop+LP Michael Byrne
117.679.863 AMD Ryzen Threadripper 3 3970X @4.1Ghz 64threads pop Michael Byrne
117.255.337 AMD Ryzen Threadripper 3 3970X @4.18Ghz 64threads pop Mike Babigian
106.452.560 AMD Ryzen Threadripper 3 3970X @4.18Ghz 64threads pop Mike Babigian
90.249.413 AMD Ryzen Threadripper 3 3970X @4.1Ghz 64threads BMI2 Michael Byrne
76.410.943 2x Intel Xeon E5-2698 v4 @2.3Ghz 80threads BMI2 Superchess
72.281.069 AMD Ryzen Threadripper 3 3970X @4.1Ghz 32cores pop Michael Byrne
43.299.797 AMD Ryzen R9 3900X 24threads pop [XC] Lead Head
33.169.502 AMD Ryzen R9 3900X 24threads BMI2 [XC] Lead Head
List updated.
Does Patrick have an account on XS?
MY Bday is also July 2
My 3175X was at 4.3Ghz not 3.1Ghz, I can run at 4.7Ghz now if you want some updates.
I upgraded your account.
Hi Charles,
This is very kind off you..Thank you :up:
Patrick is the owner from Serve The Home website and has no account here..
And you know any bench you want to share is welcome! yours is adjusted to 4.3Ghz in list.
2nd July ,one off the best days ,but also a day that i don't want to see so fast anymore ;)
214.283.702 AMD Ryzen Threadripper 3 3990X @4.0Ghz 128threads pop The Wizard
Thank you The Wizard :up:
221.523.123 AMD Ryzen Threadripper 3 3990X @4.0Ghz 128threads pop The Wizard
After Bios update and change some settings..
I will update this bench each time The Wizard get something better at same speed!
Thanks The Wizard :up:
Ofcourse ,higher clockspeed!Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
227.448.746 AMD Ryzen Threadripper 3 3990X @4.3Ghz 128threads pop The Wizard
Thank you Monstru :up: ..and for the first time ,thanks to ZEN 3 we see BMI2 compiles are faster then pop on AMD!!Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
73.223.260 AMD Ryzen 9 5950X 32threads BMI2 Monstru
71.485.485 AMD Ryzen 9 5950X 32threads pop Monstru
56.729.627 AMD Ryzen 9 5900X 24threads BMI2 Monstru
55.652.909 AMD Ryzen 9 5900X 24threads pop Monstru
Again Thanks to Monstru for these benches :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
40.526.615 AMD Ryzen 7 5800X 16threads pop Monstru
40.492.003 AMD Ryzen 7 5800X 16threads BMI2 Monstru
31.045.535 AMD Ryzen 5 5600X @4.55Ghz 12threads BMI2 Monstru
30.951.403 AMD Ryzen 5 5600X @4.55Ghz 12threads pop Monstru
Thanks Patrick & Fulcrum2000 :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
278.098.432 2x AMD EPYC 7742 256threads pop Patrick @ ServeTheHome.com
78.245.730 AMD Ryzen 9 5950X @4.32Ghz PBO 32threads BMI2 Fulcrum2000
76.072.056 AMD Ryzen 9 5950X @4.32Ghz PBO 32threads pop Fulcrum2000
73.942.633 AMD Ryzen 9 5950X @3.95Ghz 32threads BMI2 Fulcrum2000
70.639.286 AMD Ryzen 9 5950X @3.95Ghz 32threads pop Fulcrum2000
My best wishes and a healty 2021 !
Happy New Year !!
JP.
300.190.737 2x AMD EPYC 7H12 256threads pop CCC System
58.501.924 AMD Ryzen 9 5900X 24threads BMI2 ankan
A new second high result with this CCC System ! (Computer Chess Championship System)
Thanks for these benches Robert ;)Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
72.819.338 Intel Core i9 10980XE @4.4GHz 36threads BMI2 Robert
70.737.943 Intel Core i9 7980XE @4.19GHz 36threads BMI2 Robert
70.216.142 Intel Core i9 10980XE @4.4GHz 36threads pop Robert
68.110.994 Intel Core i9 7980XE @4.19GHz 36threads pop Robert
A bigger update..Thanks for all these benches :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
206.770.348 AMD Ryzen Threadripper 3 3990X @3.8Ghz 128threads pop+LP FastGM
193.904.849 2x AMD EPYC 7742 128threads pop vondele
159.701.854 2x AMD EPYC 7502 128threads pop Patrick @ ServeTheHome.com
157.136.270 AMD Ryzen Threadripper 3 3995WX Pro 128threads pop+LP Marco Zerbinati
144.533.088 AMD Ryzen Threadripper 3 3990X @3.8Ghz 64cores pop+LP FastGM
77.092.270 AMD Ryzen Threadripper 3 3970X @4.1Ghz 32cores pop+LP Michael Byrne
72.777.886 2X Intel Xeon Gold 6132 @2.6-3.7Ghz 56threads BMI2 Marco Zerbinati
65.577.112 AMD Ryzen R9 3950X @4.15hz 32threads pop+LP jjosh
64.318.393 AMD Ryzen R9 3950X @4.05hz 32threads pop+LP jjosh
60.127.556 2x Intel Xeon E5-2678 v3 @ 2.50GHz 48threads BMI2 Xaggard
59.884.654 AMD Ryzen R9 3950X @4.0hz 32threads pop jjosh
35.963.718 AMD Ryzen 9 5900HS @3.30Ghz 16threads pop+LP MikeB
31.954.375 Intel Core i7 10700K @4.6Ghz 12threads BMI2 SwiftSnips
26.765.110 AMD Ryzen R7 3700X @4.1Ghz 2166Mhz 16threads pop Andrew Grant
17.271.137 AMD Ryzen R7 3700X @4.1Ghz 2166Mhz 8cores pop Andrew Grant
12.793.350 AMD Ryzen 5 3400G @3.7Ghz 8threads pop Ras
Time for a update ,also with new I9 12900K ,i7 12700K & i5 12600K :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
270.659.065 2x AMD EPYC 7742 256threads pop vondele
89.726.955 2x Intel Xeon E5-2698 v4 @2.6Ghz 80threads pop Jin38
79.388.555 AMD Ryzen 9 5950X @4.6Ghz PBO 32threads BMI2 janne
78.574.335 AMD Ryzen 9 5950X @4.4Ghz 32threads BMI2+LP sesse
65.485.392 Intel Core i9 12900K ddr4 3600 CL16 W11 24threads BMI2+LP GCP
61.402.926 Intel Core i9 12900K 5.1Ghz ddr5 6000 CL36 W11 24threads BMI2 Monstru
59.839.994 Intel Core i9 12900K ddr4 3600 CL16 W11 24threads BMI2 GCP
59.366.933 Intel Core i9 12900K 5.1Ghz ddr5 6000 CL36 W10 24threads BMI2 Monstru
59.271.189 Intel Core i9 12900K 5Ghz ddr5 6000 CL40 24threads BMI2 Monstru
58.788.508 Intel Core i9 12900K 5.1Ghz ddr5 6000 CL36 W10 24threads pop Monstru
58.746.885 Intel Core i9 12900K 5.1Ghz ddr5 6000 CL36 W11 24threads pop Monstru
58.052.082 Intel Core i9 12900K 5Ghz ddr5 6000 CL40 24threads pop Monstru
57.300.255 Intel Core i9 12900K 5Ghz ddr4 3200 CL14 24threads BMI2 Monstru
55.018.576 Intel Core i9 12900K 5Ghz ddr4 3200 CL14 24threads pop Monstru
49.371.476 2x Intel Xeon E5-2650 v4 48threads pop Jin38
47.793.887 Intel Core i7 12700K 5Ghz ddr5 6000 CL36 20threads BMI2 Monstru
47.716.662 Intel Core i9 12900K ddr4 3600 CL16 W11 16threads BMI2 GCP
46.541.532 Intel Core i7 12700K 5Ghz ddr5 6000 CL36 20threads pop Monstru
44.745.816 Intel Core i9 10900KF @5.1Ghz 20threads BMI2 MMarco
44.004.094 Intel Core i9 10900KF @5.0Ghz 20threads pop MMarco
36.332.117 AMD Ryzen 9 5900HS @3.30Ghz 16threads BMI2+LP MikeB
36.187.026 Intel Core i5 12600K @4.9Ghz ddr4 6000 CL36 16threads BMI2 Monstru
34.539.883 Intel Core i5 12600K @4.9Ghz ddr4 6000 CL36 16threads pop Monstru
29.290.220 Intel Core i9 12900K ddr4 3600 CL16 W11 8threads BMI2 GCP
29.158.378 AMD Ryzen 9 4900H @4.0Ghz ddr4 3200 CL22 W11 16threads pop MMarco
28.356.962 AMD Ryzen 9 4900H @4.0Ghz ddr4 3200 CL22 W10 16threads pop MMarco
27.475.832 Intel Core i7 10870H 16threads BMI2 MMarco
20.137.011 Intel Core i7 980 @ 4.03Ghz 12threads pop dorszcz
5.726.799 AMD A10-7860K 3.6GHz ddr3 1600 CL9 4threads pop GCP
List updated on first page.
New benches adding with AMD Ryzen 9 7950X & AMD Ryzen 5 7600X :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
93.038.665 AMD Ryzen 9 7950X @4.7Ghz DDR5 6000 32threads pop Monstru
92.761.833 AMD Ryzen 9 7950X @4.7Ghz DDR5 6000 32threads BMI2 Monstru
38.641.304 AMD Ryzen 5 7600X @4.7Ghz DDR5 6000 12threads pop Monstru
37.800.104 AMD Ryzen 5 7600X @4.7Ghz DDR5 6000 12threads BMI2 Monstru
List updated on first page!
And now also Intel Core i9 13900K & Intel Core i5 13600K added to list :up:Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
93.583.673 Intel Core i9 13900K ddr5 6000 CL30 32threads BMI2 Monstru
92.188.800 Intel Core i9 13900K ddr5 6000 CL30 32threads pop Monstru
54.619.380 Intel Core i5 13600K ddr5 6000 CL30 20threads pop Monstru
53.503.665 Intel Core i5 13600K ddr5 6000 CL30 20threads BMI2 Monstru
Happy New Year 2023!!
As always i continue to get these benches from any system ,even it's a extra thing i add on my website and 44years into computer chess ,i'm known as a very long time chess engine tester..
I keep this list updated but ofcourse i try to follow up the changes in this computer chess world.
I'm already a time busy (as a request) to create a new bench list with Stockfish (Nr1 engine in the world) even with a Cluster version.
And as a early New year gift i got a bench with 131.072threads !!
For people who are interested can follow this bench list on my website: https://ipmanchess.yolasite.com/amd-...-stockfish.php
And people who wants their system be added ,well any bench is always welcome!
The list you see here is also on my website: https://ipmanchess.yolasite.com/amd-...hess-bench.php
And for the rest you can look around ,there is alot data & spreadsheets i use for my testings..
If some guys are a little sportif ,then you can click on Contact and try to do better when you have my age :up:
My best wishes & a good health for 2023!!
A other big update!Code:Nodes/second CPU Cores/Threads BMI2/popcnt Member
193.595.452 AMD Ryzen Threadripper Pro 5995WX @2.7Ghz ddr4 2133 128threads BMI2 windfishballad
191.770.585 AMD Ryzen Threadripper Pro 5995WX @2.7Ghz ddr4 3200 128threads BMI2 windfishballad
141.482.921 AMD Ryzen Threadripper Pro 5995WX @2.7Ghz ddr4 3200 64cores BMI2 windfishballad
135.543.334 AMD Ryzen Threadripper Pro 5995WX @2.7Ghz ddr4 2133 64cores BMI2 windfishballad
95.553.534 AMD Ryzen 9 7950X @5.1Ghz DDR5 6400 CL32 32threads BMI2 Lemon
94.847.905 AMD Ryzen 9 7950X @4.7Ghz DDR5 6000 Bios up 32threads BMI2 Monstru
93.879.074 AMD Ryzen 9 7950X @4.7Ghz DDR5 6000 Bios up 32threads pop Monstru
93.747.570 AMD Ryzen 9 7950x @4.5Ghz (PBO=ON) DDR5 6000 CL30 32threads pop Dangerous_Ride
93.191.862 AMD Ryzen 9 7950X @5.1Ghz DDR5 6400 CL32 32threads pop Lemon
91.222.692 AMD Ryzen 9 7950X3D @5.0Ghz ddr5 6000 CL30 32threads BMI2 Monstru
79.168.663 AMD Ryzen 9 7945HX @4.0Ghz DDR5 5200 CL42 32threads BMI2 Ipmanchess
76.566.445 AMD Ryzen 9 7945HX @4.0Ghz DDR5 5200 CL42 32threads pop Ipmanchess
64.814.193 AMD Ryzen 9 7900 @5.45Ghz ddr5 6000 CL30 Bios upd. 24threads BMI2 Monstru
64.296.055 AMD Ryzen 9 7900 @5.45Ghz ddr5 6000 CL30 24threads BMI2 Monstru
62.728.807 AMD Ryzen 9 7900 @5.45Ghz ddr5 6000 CL30 Bios upd. 24threads pop Monstru
49.590.991 AMD Ryzen 7 7700 @3.7Ghz ddr5 4800 CL40 Bios upd. 16threads BMI2 Monstru
48.655.316 AMD Ryzen 7 7700 @3.7Ghz ddr5 4800 CL40 Bios upd. 16threads pop Monstru
48.338.568 AMD Ryzen 7 7700 @3.7Ghz ddr5 4800 CL40 16threads BMI2 Monstru
48.323.637 Intel Core i9 10900KF @5.1Ghz 20threads BMI2 MMarco
48.108.968 AMD Ryzen 7 7800X3D @4.8Ghz ddr5 6000 CL30 16threads BMI2 Monstru
47.897.807 AMD Ryzen 7 7800X3D @4.8Ghz ddr5 6000 CL30 16threads pop Monstru
46.842.345 2x Intel Xeon E5 2680 v2 @3.1Ghz 40threads pop Desvelemosafrica
46.601.909 AMD Ryzen 7 7700 @3.7Ghz ddr5 4800 CL40 16threads pop Monstru
40.388.630 AMD Ryzen 7 5800X3D 16threads bmi2 Monstru
39.757.126 AMD Ryzen 7 5800X3D 16threads pop Monstru
37.677.523 AMD Ryzen 5 7600 @3.8Ghz ddr5 6000 CL30 Bios upd. 12threads BMI2 Monstru
37.325.116 AMD Ryzen 9 5900HX 16threads BMI2 MMarco
36.815.580 AMD Ryzen 5 7600 @3.8Ghz ddr5 6000 CL30 12threads pop Monstru
36.565.222 AMD Ryzen 5 7600 @3.8Ghz ddr5 6000 CL30 12threads BMI2 Monstru
36.479.446 AMD Ryzen 5 7600 @3.8Ghz ddr5 6000 CL30 Bios upd. 12threads pop Monstru
14.692.753 Intel Core i7 980 @ 4.03Ghz 6cores pop dorszcz
I have just buyed a new laptop with as cpu: AMD Ryzen 9 7945HX 16c/32t
and it's amazing that this laptop is faster then my i9 7980XE @4.2Ghz 18c/36t overclocked and using custom water-cooling loop!
Just to show a compare:
List is updated on first page!Code:asmFish
67.586.192 Intel Core i9 7980XE @4.2Ghz 36threads BMI2 Ipmanchess
SF14.1
49.020.942 AMD Ryzen 9 7945HX @4.0Ghz DDR5 5200 CL42 32threads vnni256 Ipmanchess W11
44.128.312 Intel Core i9 7980XE @4.2Ghz ddr4 3200 CL16 36threads avx512 Ipmanchess W10
List getting longer and longer..more systems added!
Check these benches with a New High nodes/sec. !!Code:asmFish
434.173.828 AMD EPYC™ 9754 DDR5 6400 256threads BMI2 denuit
431.403.814 8x Intel Xeon Platinum 8168 8x24c/48t 384threads BMI2 noobpwnftw
388.100.391 AMD Ryzen™ Threadripper™ PRO 7995WX DDR5 6400 192threads BMI2 denuit
382.741.861 AMD Ryzen™ Threadripper™ PRO 7995WX DDR5 6400 192threads pop denuit
SF14.1
311.761.149 AMD EPYC™ 9754 DDR5 6400 256threads vnni512 denuit L
274.450.083 AMD Ryzen™ Threadripper™ PRO 7995WX DDR5 6400 192threads vnni512 denuit L
The AMD Epyc 9754 is a single cpu with 128cores/256threads and first cpu that can pass this 8x Intel Xeon Platinum 8168 384threads system after so many years that had the lead..
A amazing progress in speed for a single cpu!
And got from the same person benches with also a great cpu AMD Ryzen™ Threadripper™ PRO 7995WX
Thank you very much denuit ;)
Both benchlists asmFish & Stockfish are updated
asmFish: https://ipmanchess.yolasite.com/amd-...hess-bench.php
Stockfish: https://ipmanchess.yolasite.com/amd-...-stockfish.php
